yusynth
Posted: Sat Oct 03, 2009 3:14 pm Post subject:
Hey, that´s quite a useful little rascal you have there.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Sebo
Posted: Sat Oct 03, 2009 6:05 pm Post subject:
Wonderful Yves!!!
Another great module!!!
Thanks. _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Mon Oct 05, 2009 4:29 am Post subject:
another to add to the list  |
Thalassa
Posted: Mon Oct 05, 2009 5:42 am Post subject:
Just one question...
On the wiring diagram there are two level pots , is it the same pot but just doubled wired ?
The bad thing about this module it's that I'm starting to full my cabinet and I want to build a lot of modules more
Great work Yves _________________ http://www.corsynth.com |
yusynth
Thalassa
Posted: Mon Oct 05, 2009 6:05 am Post subject:
Thanks for your fast reply , Will be on my "things to do" list . By the way i also saw the modular synth that is selling on Ebay ( you make a comment on the matrixsynth ). I was cehcking the wesite also and at least the front panels are copies of your designs I think that they should said something that is based on your designs. _________________ http://www.corsynth.com |
yusynth
Posted: Mon Oct 05, 2009 6:13 am Post subject:
From what I saw on their site the PCB have been slightly redesigned : same drawing but spread over a large PCB.
I agree they could have mentioned that it is based on the yusynth design. _________________ Yves |
numbertalk
Posted: Tue Oct 06, 2009 4:52 pm Post subject:
| Great news and a great looking module. Definitely going into my ever-growing queue. |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
6079smith
Joined: Jan 18, 2007 Posts: 95 Location: Mark of the Dane
Posted: Fri Oct 09, 2009 12:21 am Post subject:
Finished this last night, and it works just great. Thanks Yves!
A. |
yusynth
Posted: Fri Oct 09, 2009 12:35 am Post subject:
| 6079smith wrote: | Finished this last night, and it works just great. Thanks Yves!
A. |
Yes it is quite an easy project to build, it works straight away !
Have fun with it.
Cheers _________________ Yves |
synthmonger
Posted: Tue Oct 13, 2009 5:14 pm Post subject:
Hi Yvves,
On your Quadrature LFO page you mention Shepard tone generation with 4 VCOs.
Is it as simple as sending the phase outputs to 4 VCOs that are octaves apart?
I believe you need two of the VCOs amplitude being controlled by a sawtooth oscillator that has 0 and 180 degree outputs. It would also need to run at twice the frequency. I assume you would need that kind of setup to make the transition between pitch smooth. _________________ Youtube!
modular demos!
Whacky tunes! |
yusynth
Posted: Tue Oct 13, 2009 11:32 pm Post subject:
| synthmonger wrote: | Hi Yvves,
I believe you need two of the VCOs amplitude being controlled by a sawtooth oscillator that has 0 and 180 degree outputs. It would also need to run at twice the frequency. I assume you would need that kind of setup to make the transition between pitch smooth. |
I gave a clue of a possible use of the Quad-VCLFO, then one has to dig things up by oneself.
With four sinewaves you have only one part of what is required for true shepard tone generation, but nevertheless one can already obtain some fun effects with the sinewaves only. _________________ Yves |
synthmonger
Posted: Wed Oct 14, 2009 7:09 am Post subject:
| yusynth wrote: |
With four sinewaves you have only one part of what is required for true shepard tone generation, but nevertheless one can already obtain some fun effects with the sinewaves only. |
Ah! I wasn't sure if it was as easy as plugging them into 4 VCOs octaves apart. I did some googling then found out what you needed exactly and while it is simple you do need a lot more than what I originally thought.
Thanks for clarifying Yvves  _________________ Youtube!
modular demos!
Whacky tunes! |
numbertalk
Posted: Wed Oct 14, 2009 7:33 am Post subject:
Mind sharing a link(s) to what you found?
Thanks.
| synthmonger wrote: | | yusynth wrote: |
Thanks for clarifying Yvves  |
synthmonger
Posted: Wed Oct 14, 2009 8:00 am Post subject:
http://www.youtube.com/results?search_query=shepard+tone&search_type=&aq=f
I did some "simulations" in ableton like the guy did in his youtube demos. It's fun to mess around with and get a feel for it. Though I barely know the program and it probably could've taken me less time to build it on breadboard then figure out in Ableton.
The links on Yusynth's page about the Quadra VCLFO also work. _________________ Youtube!
modular demos!
Whacky tunes! Last edited by synthmonger on Wed Oct 14, 2009 10:43 am; edited 1 time in total |
numbertalk
Posted: Wed Oct 14, 2009 8:29 am Post subject:
Awesome, thanks!
| synthmonger wrote: | http://www.youtube.com/results?search_query=shepard+tone&search_type=&aq=f
I did some "simulations" in ableton like the guy did in his video on Youtube. It's fun to mess around with and get a feel for it. Though I barely know the program and it probably could've taken me less time to build it on breadboard then figure out Ableton.
The links on Yusynth's page about the Quadra VCLFO also work. |
Sine
Joined: Sep 10, 2007 Posts: 111 Location: Netherlands
Posted: Sat Oct 17, 2009 12:23 pm Post subject:
It's tricky to do
I experimented a bit with my modular but the imprecision of the dual gang pots and the least bit of tracking errors in the VCO's ruins the effect. |
yusynth
Posted: Tue Dec 08, 2009 12:37 pm Post subject:
UPDATE
I have corrected the wiring diagram where the connections of the dual gang pot were mixed up. Now it is fine  _________________ Yves |
klstay
Joined: Jun 02, 2008 Posts: 7 Location: Salt Lake City, Utah - USA
Posted: Wed Apr 28, 2010 9:30 am Post subject:
PCB source |
| Has anyone done a run of PCBs for this? (Any bridechamber plans for PCBs and panels?) |
yusynth
Posted: Wed Apr 28, 2010 11:40 pm Post subject:
Re: PCB source |
| klstay wrote: | | Has anyone done a run of PCBs for this? (Any bridechamber plans for PCBs and panels?) |
Scott Deyo did not express interest for this module, I will ask him if he is interested. _________________ Yves |
littlem4tt
Posted: Fri Sep 06, 2013 4:19 am Post subject:
| Can you confirm if there a 3 or 4 wire links in the design?. There are 4 in the diagram but the text says 3 |
littlem4tt
Posted: Fri Sep 06, 2013 6:23 am Post subject:
I have connected all 4 and all is good.
I have adapted the original design for eurorack 12v. (no modifications!)
Because the board is so long i used photoshop to cut the design in half and placed each half next to each other. And then re connected the breaks.
I also added solder pads for the pots so i could mount the board easily.
Thank you so much Yves for sharing. This is my second yusynth module and i have already made a clock divider pcb.
[/img]
120.13 KB |
| Viewed: |
571 Time(s) |
680.04 KB |
| Viewed: |
584 Time(s) |
139.36 KB |
| Viewed: |
585 Time(s) |
yusynth
Posted: Fri Sep 06, 2013 7:07 am Post subject:
Nice eurorack adaptation  _________________ Yves |
