radek tymecki
Posted: Thu Oct 08, 2009 11:31 am Post subject:
Yamaha CS30 OSC SYNC modification? Subject description: 24db mod - SOLVED! |
I've found CS15 modification guide
http://homepage.mac.com/synth_seal/html/ds_cs15mod.html
Found some similarities with cs30 and did LFO mod. Still I'm curious how to make this full 24db mod in CS30? Anyone? Last edited by radek tymecki on Thu Jul 29, 2010 8:13 am; edited 3 times in total |
yusynth
Posted: Sat Oct 10, 2009 3:15 am Post subject:
Hi Radek
I have no CS30 but from the schematics if I wanted to add a 24dB/octave LP function here is what I would do :
| Schematics modification, the connection from the HP output of VCF1 to VCF2 is broken and a toggle switch is inserted to switch between the LP and HP outputs of VCF1. Obviously if you use a three voices switch you could also add the BP output of VCF1 |
34.83 KB |
| Viewed: |
504 Time(s) |
155.6 KB |
| Viewed: |
573 Time(s) |
_________________ Yves |
radek tymecki
Posted: Sat Oct 10, 2009 6:12 am Post subject:
Hey
Thanx Yves! |
radek tymecki
slacker
Posted: Sun Oct 11, 2009 2:46 am Post subject:
I don't think there is a trimmer to adjust. The VCF 2 volume knob in the VCA section is PVR2 on page 11 of the service manual, this is wired as a voltage divider and when turned all the way down should give no sound from VCF2.
I would check all the solder connections to that potentiometer to make sure they are good. If you can also check that when the volume is turned all the way down the wipe (the middle pin) is connected to ground. |
radek tymecki
Posted: Sun Oct 11, 2009 4:43 am Post subject:
| ok i'll chceck that. when i turn it to 0 it has same volume as vcf1 set to 10. when i turn vcf2 to 10 it is few times louder |
tiego
tiego
yusynth
Posted: Sat May 15, 2010 7:58 am Post subject:
Re: CS30 Filter in series |
| tiego wrote: | | I was surprised to see the filter specs on the schematics: 6DB slope for HP and LP, 12DB for BP only! |
It is a typo of this manual, actually the corrrect legend should be LP 12dB, HP 12 dB and BP 6dB. _________________ Yves |
tiego
Posted: Sat May 15, 2010 11:46 am Post subject:
Thanks for that precision
that LP sounded a bit steep for 6db/oct...
Anyhow, reading your previous post about chaining the 2 Filters thoroughly, assuming i was going to have the BD VCF to the VCF2 thru that 3 position switch,I am wondering: where should I solder the switch pin to on the PCB? ( Dohh)
sonically
Tiego |
radek tymecki
Posted: Tue May 18, 2010 2:02 pm Post subject:
i've managed to perform vcf mods that Yves showed
radek tymecki
Posted: Thu Jul 29, 2010 4:51 am Post subject:
I've contacted Eric about his modifications in CS15. He sent me those pics. hope that they'll be helpful to some of You. anyone knows how to transfer SYNC mod to CS30?
ATGANI
Posted: Fri Nov 12, 2021 3:55 am Post subject:
| tiego wrote: | Hi there
New to this forum, thanks to it and the people posting I managed to do the LFO speed hi range adjustment mod and the external sequencer gate mod altogether. I may add that I am no tech at all. I had to check on the net for the polarity of a transistor and had a problem when it came to measure the voltage out of the module to mod!
I am now interested in the Filter yusynth mod, but I was surprised to see the filter specs on the schematics: 6DB slope for HP and LP, 12DB for BP only! |
Hi there - sorry to dig this up from 10 years back! Do you happen to have the instructions for the sequencer clock input mod on the CS30? I found one online but not sure it's correct as someone tried it and had no success (could be them or the mod though of course!), thanks, Dan |
