djthomaswhite
Posted: Tue Oct 06, 2009 6:56 pm Post subject:
"can I use the CV mixer and have a separate direct CV In by connecting points 1 and 2 to point 3 on the CV Jumpers?
If you want to have multiple CV jacks or inputs you have to "mix them" in the mixer section as it has a 100K input node to bring all signals together.
Thomas _________________ Thomas
www.naturalrhythmmusic.com/diy.html |
recompas
Joined: Jun 06, 2005 Posts: 16 Location: Charlottesville, VA
Posted: Wed Oct 07, 2009 1:25 pm Post subject:
odd offset cv behavior |
So I put my first lpg clone board together a few months ago, but only recently have I really started doing a lot more with it, since I put it into my main modular rig. I've noticed a few things that are kind of weird. First, my resonance level is really weak....you can tell it will resonate, but not with the same effect as on the video, and doesn't self-oscillate.
the second problem i'm having, is that when i control the offeset with a + - 5v sine wave, it often makes a little pop and then no audio comes out for a few seconds, until i move the offset control, or it just comes back on its own. Its possible there's a grounding problem on the module, since evertying has been changed over to some banana jacks, and the LFO module is getting power off of a different rail, but i'm just not sure. curious if anyone else has experienced any weirdness.
-Travis _________________ http://www.recompas.com |
djthomaswhite
Posted: Wed Oct 07, 2009 6:59 pm Post subject:
Sounds Like a short of some kind. Double check all of your solder joints ro make sure you have clean joints with no solder bridges. I would bet this is your issue!!!
Also, if you run your sine signal thru an attenuator you may have a bad pit. Pots can go bad if you overheat them when attaching wires. Long shot, but hey, trying to help. _________________ Thomas
recompas
Posted: Mon Oct 12, 2009 1:35 pm Post subject:
ahh, thanks. there actually was a bad solder joint on a pot that was doing the cv attenuation. Sounds back to normal now....although like I said, it never truly self-oscillated, i still get some nice resonance. Anyway, thanks...this is quickly becoming one of my favorite filters. _________________ http://www.recompas.com |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Tue Oct 20, 2009 12:11 am Post subject:
| haricots wrote: | Thanks to some friendly folks on Muffs site I have the LPG working. It's seems the signal for the deep portion needs a really hot signal because all I get is a really low rumble.
The only thing I'm not sure about is I connected the CV jack and Control to the same pad on the PCB. Seems to work fine for both but I'm unclear if this was the right thing to do.
I'm very happy with this beautiful sounding module! |
Can you link the thread over at Muff's regarding the sum jumpers, I registered but it won't let you use the search feature with post counts lower than 1, and I don't want to start a duplicate thread if there is already one there.
Failing that, is there any definitive documentation regarding the sum jumper wiring? It seems to be hardly covered in the official documentation.
At a guess it goes something like this:
SM1 > AUD IN
SM2 > CV IN
Also how to wire the attenuator pots? There seems to be no panel wiring, or sum jumper examples that I can find.
I basically want to use all 3 ins from both audio and CV, each with variable pots, I'm building each separate board into a 2U panel, so I want to make use of as much space as possible. Like this example:
 _________________ LektroiD |
numbertalk
Posted: Tue Oct 20, 2009 6:27 am Post subject:
| LektroiD wrote: |
SM1 > AUD IN
SM2 > CV IN
That's exactly right, if you plan on using the CV and Audio mixers.
| LektroiD wrote: |
These are standard input attenuators and I think there is an example in the lower left part of the schematic. Basically CCW lug to ground, wiper to one of the input pads on the board, CW lug to the input signal of the relevant jack. |
Posted: Tue Oct 20, 2009 10:50 am Post subject:
| numbertalk wrote: | | These are standard input attenuators and I think there is an example in the lower left part of the schematic. Basically CCW lug to ground, wiper to one of the input pads on the board, CW lug to the input signal of the relevant jack. |
i have had a hard time in past, when it came to pin numbers, CW, CCW of potentiometers. this may help:
Tech Buddy at Random*Source |
nerdware
Posted: Tue Oct 20, 2009 12:44 pm Post subject:
Very nice diagrams. Thanks, Matthias. _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
LektroiD
Posted: Tue Oct 20, 2009 9:27 pm Post subject:
Thanks Matthias, excellent diagrams as always. _________________ LektroiD Last edited by LektroiD on Sun Oct 25, 2009 9:43 am; edited 1 time in total |
LektroiD
Posted: Sun Oct 25, 2009 9:43 am Post subject:
Just finished building my first one (also my first completed module - yay). I have a problem with the resonance going crazy (self oscillation) past 2 O'Clock on the dial, it nearly sent my speaker cones across the room! Any ideas what might cause this?
Also, in the 2U design... Where does the "CTRL" wire up to on the PCB? _________________ LektroiD |
LektroiD
Posted: Tue Oct 27, 2009 2:31 am Post subject:
A couple of other findings (as well as the questions posed above);
1) Should I lose resonance control in 'both' mode? The resonance seems to be non existent in both mode. I would have assumed 'both' meant VCA + VCF (which would include resonance).
2) The deep switch cuts the sound completely (as has been reported many times on this thread), is there a recommended resistor value to get this working? _________________ LektroiD |
Posted: Tue Oct 27, 2009 10:09 am Post subject:
| LektroiD wrote: | | 1) Should I lose resonance control in 'both' mode? The resonance seems to be non existent in both mode. I would have assumed 'both' meant VCA + VCF (which would include resonance). |
Resonance IS available in LoPass mode only, so everything works as it should here.
Don't know about the deep-mod though. did not implement it on my modules. _________________
djthomaswhite
Posted: Fri Oct 30, 2009 7:46 pm Post subject:
Deep Switch = Turn it on, put Offset all the way up and hit the module with CV's. The CV's will bring the sound through from the depths into existence. Should be if it was built right. I use it with amplified, and as short as possible of triggers.
Boards are in and will ship as scheduled next week!!!
Brogram
Posted: Wed Nov 04, 2009 7:06 pm Post subject:
I'm currently mounting 3 LPGs in one panel and have a silly question....
If I wanted an extra output that combines the 3 LPG outs could I simply run the signal from each of the three boards and connect them at one output jack? Or could this present any issues?
Thanks,
Eric |
numbertalk
Posted: Wed Nov 04, 2009 7:14 pm Post subject:
You would need to run these into a mixer circuit, something like this:
http://www.cgs.synth.net/modules/cgs04_mix.html
| Brogram wrote: | I'm currently mounting 3 LPGs in one panel and have a silly question....
Thanks,
Eric |
djthomaswhite
Posted: Wed Nov 04, 2009 8:33 pm Post subject:
Or better yet, you could use one of the mixer sections on one of the PCB's to mix the three outputs. This would mean one module has no CV or Audio mixer on the inputs, but it might be worth the sacrifice. Mixer sections on the pcb are jumpered in and out of the circuit. Otherwise they are two independent 3 input mixers.
Tasmanian Alkaloid
Joined: Jun 29, 2008 Posts: 116 Location: Isle De Mort
Posted: Wed Nov 04, 2009 9:56 pm Post subject:
| LektroiD wrote: |
2) The deep switch cuts the sound completely (as has been reported many times on this thread), is there a recommended resistor value to get this working? |
I had that problem also, as well as weak resonance (nothing like what i heard in Thomas' videos). After a while i wondered if i'd gotten a capacitor value wrong, so i made 3 changes-
1. swapped the cap i originally used for '1.0n' (which was a green tantalum cap, the markings on which i can't remember, but it didn't sound right) with a polyester cap marked 1n (i suspect this was the culprit)
2. swapped the cap i originally used for 1uf (which was a non-polarised electrolytic) for a polyester 1uf cap (probably didn't make any difference)
3. changed the 51k resistor i originally used for the resonance mod to a 49,9k (.1%) resistor
It works much, much better now (like it should!)
But also, the deep switch seems to only allow certain kinds of signals through, so it will also depend on that, as to whether or not the switch will cut off the sound. |
Posted: Thu Nov 05, 2009 2:02 am Post subject:
| Tasmanian Alkaloid wrote: | | But also, the deep switch seems to only allow certain kinds of signals through, so it will also depend on that, as to whether or not the switch will cut off the sound. |
the amplitude is of interest here, i think? the deep switch is part of the CV circuitry only. _________________
djthomaswhite
a100user
Posted: Fri Nov 13, 2009 8:10 am Post subject:
Hi Thomas,
My boards arrived today.
Many thanks for a great service.
David |
nerdware
Posted: Fri Nov 13, 2009 9:24 am Post subject:
I got mine, too. Excellent service, thanks. _________________ http://soundcloud.com/nerdware/
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Sat Nov 14, 2009 12:17 am Post subject:
hi thomas
are there any plans to be doing any more board runs for these in the future ? as it seems to hint from the post heading this may be the final run
I already know that i will be wanting quite a few more of these  |
djthomaswhite
Posted: Sat Nov 14, 2009 8:32 am Post subject:
Thanks for the inquiry. Due to personal stuff and family plans changing (kid coming) I'll be moving to other newer board designs. After three batches I think everyone who needs one has one (or four). The last 40 are essentially sitting and orders have slowed dramatically now. However, strange things happen and they could go in a weekend due to people buying from two to six on average.
I don't plan to make more at this point. But frankly I didn't plan to make this batch until demand rose to a level that made it worthwhile. One forgets just how much time it takes to package, address, make customs form, and ship PCB's from the post office (long line this time of year). Just don't know if I can continue to commit to shipping in a window of time that is acceptable to me. _________________ Thomas
joshco
Posted: Sat Nov 14, 2009 8:34 am Post subject:
Boards arrived, thank you very much for this project  |
Dave Kendall
Posted: Sat Nov 14, 2009 12:24 pm Post subject:
Hey Thomas, Thanks for doing a final run. I had missed the last runs due to being broke, and am really glad I got another chance.
I'll maybe try them with some home-rolled vactrols...... could be interesting......
Dave _________________ "Everything in moderation, including moderation" |
