Resonator Section of Polymoog ...
Page 4 of 6 [129 Posts]
Interested?
Interested
95%
 95%  [ 43 ]
Not intersted
4%
 4%  [ 2 ]
Total Votes : 45
jhaible
PostPosted: Fri Sep 18, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Bill Of Materials is online:
http://www.jhaible.de/resonator/resonator_bom.pdf
http://www.jhaible.de/resonator/resonator.html
JH.
davebr
PostPosted: Sun Sep 20, 2009 10:32 pm    Post subject: Polymoog Resonator
Subject description: Panel Designs
My PCBs have been shipped, I've finished and ordered my Living VCO panel, so it's time to be thinking about finalizing my resonator panel. I've narrowed my thoughts down to three designs that are on my web page.
I've add modifications for a single Mix control replacing the individual resonance and dry controls, and three inputs and attenuators.
I favor a slightly non-traditional design where each of the three resonators sections is slightly offset forming a low, mid, and high visual (right image).
http://modularsynthesis.com/jhaible/resonator/polyres.htm
Luka
PostPosted: Sun Sep 20, 2009 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
middle one looks cool dave
problemchild
melbourne australia
/mr
PostPosted: Mon Sep 21, 2009 1:15 am    Post subject: Re: Polymoog Resonator
Interesting twist.
I'd definitely choose the right one before the cluttered middle one. Smile
davebr
PostPosted: Sat Sep 26, 2009 2:16 pm    Post subject: Re: Polymoog Resonator
Interesting twist.
It took me a bit to figure out that the middle picture was wrong. Frontpage didn't catch the fact that I had replaced the photo. I've fixed the picture so it matches the FrontPanelDesigner file. However, I changed to new panel design based on playing with a functional prototype.
davebr
PostPosted: Sun Sep 27, 2009 6:39 pm    Post subject: Polymoog Resonator
Subject description: Working Prototype
I finished the PCB and got my protoytpe running - pretty nice. I found that the gain controls can really overdrive and clip. Headroom is also reduced a bit since the resonator cells are referenced to +5 volts.
I thought about going back to the separate controls for Dry and Resonator levels except the Resonator level control is after the clipping. You can avoid clipping by adjusting the individual gain controls or reducing the input level. One option is to move the Resonator level to the input of the resonator cells.
I decided to add three inputs and individual attenuators, add a Level control on the input to the resonator cells, add a Mix control, and add a clipping indicator on the resonator output. It's a bit more hand wiring than I want to do so I've designed a small add-on PCB.
This design now has 15 controls so I've arranged in 3 rows by 5 columns. I've moved all my previous panel designs to a separate page for reference.
I added more information and photos to my page including waveform images. Now to go play some more ...
jhaible
PostPosted: Sun Sep 27, 2009 11:31 pm    Post subject: Re: Polymoog Resonator
The individual Gain potentiometes for each filter band are at the filter inputs already.
Having control over post-filter gain (i.e a resonator level potentiometer, like the original), is a good idea, IMO. If you notice that the balance of the 3 filters is just right, but the oveall level is too low, you can increase the level without touching the 3 individual filter gains that way. The gain reserve that's built into the final amp for that purpose is a good thing - but of course it allows overdrive, and will overdrive if you omit that final gian control and replace it with a wet/dry mix pot.
If you are determined to have a wet/dry mix potentiometer instead, simply reduce the gain of the output amp: make R21 smaller.
JH.
numbertalk
PostPosted: Mon Sep 28, 2009 10:03 am    Post subject: Re: Polymoog Resonator
Would this best be accomplished with an external buffer added after the output of the circuit or by adding a pot somewhere around U3 on the resonator circuit itself? I'm not interested in a wet/dry mix, justin a post-filter gain control.
jhaible
PostPosted: Mon Sep 28, 2009 10:11 am    Post subject: Re: Polymoog Resonator
What I have described is the original (and the unchanged PCB), without a wet/dry mix. Saying, I recommend to build it just as it is.
JH.
numbertalk
PostPosted: Mon Sep 28, 2009 10:25 am    Post subject: Re: Polymoog Resonator
Ah, the RESON connector on the PCB. Sorry, missed that somehow.
JH.
davebr
PostPosted: Mon Sep 28, 2009 2:51 pm    Post subject: Re: Polymoog Resonator
JH.
It must be a bit irritating to do such great design work and then have everyone talk about what they wished it had or why did you do this.
I do want to thank you for your great designs and the effort and energy it takes to provide this for the synth community. I just like to embrace the DIY nature of the projects. Besides, if I don't like it, I can always change it. That's what's so much fun about this hobby. Keep up the great designs.
jhaible
PostPosted: Mon Sep 28, 2009 3:17 pm    Post subject: Re: Polymoog Resonator
JH.
Dave,
I hope you didn't get a wrong impression: I totally encourage any kind of modification / expansion to the PCBs I provide. Remember, I came from all-veroboard stuff and used to only publish schematics, not even clean drawings. And even today, some wish my documentation would be more detailed than it is.
So what I wrote was just a direct answer to a specific question - pointing out that Moog's original design already has the feature in question (post filter level pots) - but no wet/dry mix of course.
For the wet/dry mix version, I recommend decreasing that feedback resistor in the output stage - or wire a potentiometer in parallel to that resistor for a Master volume control.
JH
davebr
PostPosted: Mon Sep 28, 2009 3:24 pm    Post subject: Re: Polymoog Resonator
jhaible wrote:
Dave,
JH
No misunderstanding at all. And yes, I used to look at those schematics with the hand drawn funny shaped "1"s - definitely not American. Too complex for me to want to hand wire, and too much work to lay out a PCB.
I just wanted you to know we all appreciate the work you put into this and the availability of PCBs. The breadboard area on this design is a nice addition.
davebr
PostPosted: Tue Sep 29, 2009 7:43 pm    Post subject: Re: Polymoog Resonator
davebr wrote:
I thought about going back to the separate controls for Dry and Resonator levels except the Resonator level control is after the clipping. You can avoid clipping by adjusting the individual gain controls or reducing the input level. One option is to move the Resonator level to the input of the resonator cells. I decided to add three inputs and individual attenuators, add a Level control on the input to the resonator cells, add a Mix control, and add a clipping indicator on the resonator output.
I've played with this prototype the last two evenings. I am going to reverse myself and agree with Jurgen. The gain controls can be used quite nicely in most cases to control clipping. With input attenuators I can also use those to reduce the signal going to the resonator cells.
The issue I found is that the resonator output (e.g. wet) had a different tonal makeup and the relative loudness compared to the input (e.g. dry). Some resonator waveforms are not symmetric about their virtual ground (e.g. 5 volts) so you can get positive clipping without much negative waveform at all, and others are quite symmetrical. In other words, the pk-pk voltage and relative "loudness" can vary quite a bit which changes the balance in a wet-dry Mix knob.
I think it would be easier to control the overall balance by just having separate wet and dry levels as designed. However, I am definitely adding a clipping indicator. Since the output of the resonator is centered around 5 volts, I think I may just use a pair of comparators to form a window detect at something a bit larger than 10 volts pk-pk, say +12.5 volts and -2.5 volts (centered about +5 volts) to drive the clipping indicator.
I also think I will boost the gain of the dry mixer (e.g. R16) so I can get unity gain with the resonance level at 0.
You just have to play with the prototype enough to get a good feel for it's characteristics. I finally had to make a foamcore panel and mount the controls to it to really test drive it.
nuipb
PostPosted: Tue Oct 06, 2009 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I am a new member and know nothing about DIY but I would really like to have 1 (or maybe 2 separate units or 2 in the same box for stereo) of this resonator.
Jurgen suggested i should contact this forum to see if someone could be interested to build 1 (or 2) for me. So if anyone feels like building it and sell it to me I would be interested to know their price. I would prefer the closest to the original MOOG/Elhardt built. I would also prefer someone located in Europe as I am in France. So please contact me if interested !
Thanks.
morbank
PostPosted: Tue Oct 13, 2009 9:23 pm    Post subject: Mode Switch?
Subject description: Mode Switch?
Hello to all,
Can anyone here tell me what type of 4 way switch I'll need for the mode selector?
Thanks, Clay
davebr
PostPosted: Tue Oct 13, 2009 10:39 pm    Post subject: Re: Mode Switch?
Thanks, Clay
1 pole 4 position. I used a multi-position rotary switch where you move a ring to limit the rotation to 4 positions. The Mouser part number is on my site. http://modularsynthesis.com/jhaible/resonator/polyres.htm
morbank
PostPosted: Wed Oct 14, 2009 7:54 am    Post subject: Mode Switch?
Thanks Dave! I had been checking your progress but I somehow missed the section where you gave the info for the pots.
-Clay
davebr
PostPosted: Sat Oct 17, 2009 4:20 pm    Post subject: Polymoog Resonator
Subject description: Completed module
I finished building my module today. The clipping indicator works great. I've updated the photos and information on my site.
morbank
PostPosted: Fri Oct 23, 2009 3:47 pm    Post subject: Troubleshooting Help
Subject description: Troubleshooting Help
Hello to All,
So I've got my resonator assembled and everything seems to be working well with the exception of both of the Mid and Low Frequency and Emphasis controls. The gain pots appear to be working as they should. However, the Low frequency pot doesn't seem to effect the audio at all and turning the pot fully clockwise results in the audio cutting out abruptly with a low thunk sound. The pot for the Mid Frequency has even more issues as turning the pot causes the audio to abruptly cut in and out at random. It too has the same thunk sound when turning the pot fully clockwise. The Emphasis pots for both the Mid and Low Frequencies have very little if any effect as well.
Can anyone here point me to what I might have done wrong or what I might try to make things right?
Sincerely, Clay
jhaible
PostPosted: Fri Oct 23, 2009 4:12 pm    Post subject: Re: Troubleshooting Help
morbank wrote:
Hello to All,
Sincerely, Clay
The 3 bands are identical circuits, only with different capacitors. So all you have to do is compare the two bad ones against the 3rd, good one.
JH.
adambee7
PostPosted: Sun Oct 25, 2009 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I thnk the modifications dave has done are going to be implemened into mine. Thanks Dave. What does the mod circuit look like underneath. I've seen top side but not bottom side on the board. Got a rough idea just want to be sure i get it right. Really nice panel design to.
adam
Very Happy Very Happy
davebr
PostPosted: Sun Oct 25, 2009 10:39 am    Post subject: Polymoog Resonator
Subject description: modifications
adambee7 wrote:
I think the modifications dave has done are going to be implemened into mine. Thanks Dave. What does the mod circuit look like underneath. I've seen top side but not bottom side on the board. Got a rough idea just want to be sure i get it right.
adam
I thought about taking a photo but didn't. I added tracings to the image that shows the wiring. I think it is correct (but you should re-check it).
I flat the leads to the PCB on the back and route the leads orthogonally to the appropriate pad. I then solder the wire to each of the pads it crosses. These are shown in red.
I added two components on the back. These are shown in white.
I then connect up the various sections with wire. Wires are shown in yellow.
The two resistors for the comparator on the front are bent so their leads are above the PCB and do not touch any pads as they wrap around the IC.
Note that there is a decoupling capacitor below the resistor at the top of the op-amp.
I have a larger image on my site.
adambee7
PostPosted: Mon Oct 26, 2009 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Dave. I do appreciate it. Very Happy Very Happy
davebr
PostPosted: Sat Oct 31, 2009 7:55 am    Post subject: Re: Polymoog Resonator
davebr wrote:
adam
Oops! The schematics are correct but when I created that wiring diagram I connected ground to pin 4 of the LM393 comparator instead of -15V. I updated the picture so it is now correct.
