today> Twyndyllyngs Chez Mosc
Nord Lead 3 Rack Heating Problem?
Page 1 of 1 [9 Posts]
Richard Devine
PostPosted: Thu Aug 20, 2009 3:01 pm    Post subject:  Nord Lead 3 Rack Heating Problem?
Subject description: Nord Lead 3 Rack gets very hot?
Hello, I was just curious if other users, have noticed that the Nord Lead 3 Rack, gets extremely hot? I have the Nord Lead 2 X, Nord Modular G2, and G1. None of the other units get nearly as hot as the Nord Lead 3. Is this common?? I am about to purchase this unit from a friend, just wanted to be sure.
please feel free to message me: rdevine1@gmail.com
Thanks
Richard
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Aug 20, 2009 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Richard Devine
Indeed, I think, although never mesureed it, the NordLead3 is getting a little hotter than the others, which also being rather hot. It is a Clavia thing...
Wout
fac
PostPosted: Sun Aug 23, 2009 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
My NL3 (keyboard) does get a bit hot, too, but nothing serious. I used to have a micromodular and I remember it getting hot also. My G2, in contrast, doesn't seem to have this problem.
The NL3 rack may get hotter than the keyboard due to everything being a little more crammed inside, and also if the rack isn't properly ventilated (e.g. make sure the ventilation holes are not obstructed by some other racked gear).
My music: http://cdbaby.com/all/fac
corazon
PostPosted: Mon Aug 24, 2009 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
My Nord Rack 3 gets noticably hot at the back (almost too hot to touch), but have never had problems with it. I have to stop the cat sitting next to it though Wink
dorremifasol
G2 patch files: 49
PostPosted: Mon Aug 24, 2009 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here. Very hot but no problems. It still worries me though so I don't keep it turned on for a long time, specially now in summer.
Albert
cjomuk
PostPosted: Thu Oct 29, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just bought a Nord rack 3 and I am also very concerned about how hot the casing is after it's been powered on for a short while.
Does anyone have a Nord rack 3 that doesn't run hot?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 29, 2009 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
More Clavia gear has the heating problem, at least the Leads and the Modulars. Haven't met the problem with the Electro serie.
Wout
Richard Devine
PostPosted: Thu Oct 29, 2009 1:14 pm    Post subject: Nord Lead 3 Reply with quote  Mark this post and the followings unread
Yea, I have gotten use to it. I have left mine on for weeks now working it pretty hard everyday for sound design, and I guess the heat isn't too much of an issue. I know my Nord G2, and Nordlead 2 doesn't get nearly half as hot as the NordLead 3. One thing to note is that the Nord 3 has almost 3 X the amount of LED's and lights, which may be the reason that its getting so hot. More power consumption possibly? Still love this synth, wish there was a work around for the heat issue. I don't have any other synth that gets this hot.
Richard
cjomuk
PostPosted: Thu Oct 29, 2009 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ventilation on back and bottom is OK.
I let it cool for 20 mins and opened it to investigate and the casing was still hot to the touch!
The back of the LCD was still a little warm, and the front panel and main pcb's where fine but the power module pcb was still burning hot (specifically the blue transformer on it). I noticed that it's blackened once of the grey ribbon cables that was touching against it.
I'm using it at 115V (it has a switch to convert to 230V).
Maybe it just runs this hot when it's in the 115V setting?
(It's certainly the hottest piece of gear I've ever owned).
