DIY Buchla 200e Cabinet Rip-Off
Page 3 of 4 [81 Posts]
cbm
PostPosted: Fri Jul 10, 2009 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
macumbista wrote:
If I could request one more photo, it would be a close-up of the set screws on the back side, that you mentioned lock it into place (where I thought maybe gravity would do the job by itself).
OK, I'll try and get to that later tonight.
Also....are those audio jacks coming out of the backside of the top boat?
Yeah, there are a few little cutouts where things can be mounted to the boat. The 227e mixer uses one, the 225e midi interface uses one, the charger for the 222e rings uses one.
In the link you posted to Johan's cabinet http://www.synthi.se/bcab/b2.jpg you can see the blanking plates installed on the back of the top and middle boats. If you had a module than uses one of these, the blanking plate would be removed and a little circuit board mounted on a little metal plate would be screwed in there. An awful amount of thought went into this system.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
cbm
PostPosted: Fri Jul 10, 2009 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
macumbista wrote:
And my other question is...with all those cables, and the fact that you have to unplug them before closing the case, what do you do when you have to pack it up for a gig?
Unplug them. I tend to use a standard "base patch," which I've gotten pretty fast at patching, and then patch on top of that.
It does mean that I need about an hour to set up, although I can do a crappy job in about 40 minutes.
Chris Muir
macumbista
PostPosted: Sat Jul 11, 2009 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering what those cutouts were for...thanks!
For USD20K, I would hope so!!!!! Is there anyone on this forum interested in buying one of my (slightly used) kidneys? Reply by PM Wink
I figured "performative patching" would be a big part of using this machine.
best!
D.
macumbista.net
macumbista
PostPosted: Sat Jul 11, 2009 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
cbm wrote:
Hopefully this is end-on enough:
The angle of the boats respective to each other is 143 degrees (i.e. the middle boat is at 37 degrees from the table). Now I have to decide if I want to re-cut my wood or not....
macumbista.net
akrearke
PostPosted: Mon Jul 27, 2009 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am building a clone of a buchla 200 and this cabinet thread inspired me. I have done my own design to day, but the specks are a little different. I would recommend to anyone trying this out to picture it as a square box and then cut away the excess. Very challenging to get the angles right for the 37 degree slant on the cabinet. very cool thanks to everyone who lent a hand in this thread.
PostPosted: Mon Jul 27, 2009 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just for the record;
http://electro-music.com/forum/ntopic-21723.html
The Solidworks version was never finished, as the specification asked for were impossible to realise, as the deeper the boats got, the more out of proportion the whole thing came (Don, you're a genius!), and having to redraw and dimension where holes went (for fixing together) became to much of a chore to repeat over and over again. So in the end I just thought that life was too short and went for a walk instead! Very Happy
If you use the plans in this link, I accept no responsibility whatsoever, if building from it ends, in total disaster! got me? Wink
ACHTUNG!
ericcoleridge
PostPosted: Mon Jul 27, 2009 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
On the 200e, the middle boat is a little deeper than the outside boats-- if I remember right, it's 3.25" deep; the outside boats 2.75".
I was able to use readymade 3" deep alluminum boats (from Mouser), so I made my drawing to accomodate all three boats being 3" deep; However, I don't believe this altered the proportions at all. I can post my 1:1 drawings if anyone is interested. They're not exactly perfect--I'm sure--but useable possibly.
I didn't precisely measure the angles, I just traced the wood panels from a photo, and then scaled them to the right measurements. As I understand it, outstretched/open, the cabinet should measure approx 18" from the front bottom endpanels forward edge to the very back edge of the top endpanels.
macumbista
PostPosted: Tue Jul 28, 2009 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Smart not to accept any liability, v-un-v. Every time I changed just about anything, especially the angle that the case opened up to, I have to fiddle with everything. My advice to anyone trying this out is to use something like Illustrator, Inkscape or Sketchup to draft something that fits the dimensions you are working with. Use the "rotate" tool in the software to pivot the side panel on an axis that you have defined (i.e. where you plan to put the screw hole) and see if it collides with anything! Simply rescaling someone else's drawing has pretty good odds that something won't work!
macumbista.net
macumbista
PostPosted: Sat Aug 29, 2009 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
New photos! Still have a bit of internal wiring to do here, and I discovered that painting metal isn't really my forté, but that's life in the DIY world. Enjoy...
 Filesize:  517.4 KB
 Viewed:  638 Time(s)
 Filesize:  569.3 KB
 Viewed:  579 Time(s)
 Filesize:  607.57 KB
 Viewed:  620 Time(s)
 Filesize:  563.64 KB
 Viewed:  556 Time(s)
 Filesize:  603.83 KB
 Viewed:  587 Time(s)
macumbista.net
Sound
PostPosted: Sat Aug 29, 2009 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uau, you artist Very Happy
ericcoleridge
PostPosted: Sun Aug 30, 2009 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! This is the best DIY cabinet I've seen yet. Just outstanding--It looks perfect! What did you use for the boats? What product did you use for the hammered black paint on the boats?
I'm using the Bud Industries boats from Mouser, but I'm still waiting for a couple more before I can assemble my cabinet. However, I now feel like I'd rather try to get some 6-space boats, rather than the Bud 4-spacers. So, I'm curious, did you make your own aluminum boats?
Here's a picture of my unassembled cabinet:
 Filesize:  1.2 MB
 Viewed:  604 Time(s)
macumbista
PostPosted: Sun Aug 30, 2009 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ ericcoleridge: Thanks thanks thanks. You're much too kind Wink I didn't even think that there might be ready-made boats actually...
I guess I should just go over the process of how I did this in steps:
    1--Calculated boat sizes on paper.
    2--Sheet steel purchased, cut and bent at Modulor in Berlin. Boats are made from 1 C-shaped section for the length and two smaller C sections for the end-caps.
    3--Ordered power supply from Curetronic.
    4--Drilled holes for screws/rivets, XLR gooseneck lamp and power supply.
    5--Designed wooden side panels on the computer in Inkscape (this was probably the most complex part, and I made a few different prototypes before I got the thickness and angle I wanted).
    6--Printed side panel design on A4 paper and redrew onto wood with carbon-copy paper.
    7--Cut wooden panels with electric scroll/decoupier saw. Cut wooden legs.
    8--Drilled holes and screwed in the locking mechanism in the side of the wooden panels (small set screws to keep the boats in place when the case is open).
    9--Sanded/stained wood panels + legs.
    10--Painted metal boats with Hammerite brand "Hammerschlag" black. I gave it several heavy coats with a brush, so the paint job is very rough. I kind of like that handmade feel, but if you wanted it to look more "pro" I'd recommend spraying. I would have liked to bake the finish to harden it, but I didn't want all my cookies to taste like paint afterwards Wink
    11--Assembled metal boats with Pro-forma rails. The boats and rails are riveted, however the handle, legs, latches, power supply, gooseneck XLR and side panels are all screwed/bolted.
I'll try to answer any other questions here when I have time for it...
macumbista.net
macumbista
PostPosted: Sat Sep 05, 2009 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
In case anyone's interested, here's the PDFs for the side panels. These are calculated at 172mm for the height of the boats (4U), and they open to a comfortable angle of 37 degrees.
topIII.pdf
Top side panel
 Filename:  topIII.pdf
 Filesize:  2.4 KB
 Downloaded:  1029 Time(s)
bottomIII.pdf
Bottom side panel
 Filename:  bottomIII.pdf
 Filesize:  2.2 KB
 Downloaded:  1184 Time(s)
macumbista.net
mistercooper
PostPosted: Sat Sep 05, 2009 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
One adopts a 37 degree position for the purposes of astral projection. Coincidence? I think not.
Pehr
PostPosted: Sun Sep 06, 2009 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
YES! That's the kind of blueprint I understand Very Happy
not these &%"¤! cad-files or whatever they're called Rolling Eyes Embarassed Laughing
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Sun Sep 06, 2009 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
It's exactly the same thing, except CAD files contain measurement data that both humans and CNC machines can read. For example, do you know how long that piece of wood is without being told? Do you know how thick it is? Of course you don't! Rolling Eyes Laughing
FWIW, I highly expect that these PDF's were drawn on some sort of CAD system anyway. Idea
Tom Smile
ACHTUNG!
macumbista
PostPosted: Mon Sep 07, 2009 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I drew the whole thing in 2D in Inkscape (FLOSS Adobe-Illustrator clone). Since I'm not a machine, I already knew how big and thick the wood might be Wink
macumbista.net
PostPosted: Mon Sep 07, 2009 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Actually"?
CAD stands for "Computer Aided Design". Most CAD packages are 2D- and that includes Inkscape!! Wink Very Happy
ACHTUNG!
PostPosted: Mon Sep 07, 2009 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
You'll probably appreciate that Buchla has put a lot of consideration into this design. Buchla imo is by proper means of the definition, a genius. And it wasn't just electronics that he was good at. Where I went terribly wrong, is that I assumed that this same design could be made into a "frac-rack". WRONG! Laughing
In the end, I just had too much child care to deal with, than constantly pissing around with these stupid CAD programs. I'm supposed to do this for a living, but it bores me shitless Shocked
Give me a Leica, a summicron and a day out without my screaming children any day! Cool Cool
ACHTUNG!
Pehr
PostPosted: Wed Sep 09, 2009 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just saw that there's a larger cab available from buchla now Very Happy
doesn't look that portable though...
YouTube channel
flickr photostream
frenchyinmunich
PostPosted: Thu Sep 10, 2009 1:50 am    Post subject: Buchla front panels Reply with quote  Mark this post and the followings unread
Hello,
I recently started to built few Buchla modules.
I never seen a Buchla in Europa during the last 25 years, since I am into electronic music playing.
I would like to associate to my boards the original front panel design.
If I would have the possibilty to have a Buchla just near my home, I would do the design myself. Unfortunatly, I don't have one accessible and I don't know how to do the closest as possible...
Could someone help me? In giving some front panel design file or the exact dimension of the panels?
Best regards,
F
lanxe
PostPosted: Mon Nov 02, 2009 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love to see more progress from everybody that is building these style cases. Since it is a difficult design, its interesting to see how we all think a bit differently to solve some problems.
What hinges are you guys using? I just used 1/4" steel shafts cut to length with a 1/4" collars.
macumbista
PostPosted: Mon Nov 02, 2009 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ummm......long threaded screws run through a plastic tube and a nut+washer on the other end Wink
Actually, I see you have an interesting solution to the part I found the hardest, which is the tabs which hold the case open and preserve the angle. Seems like you have a flat panel running across the middle of the wooden sides, where I followed [i.e. tried to follow] the original design with tabs at the very outside and set screws. Note to anyone trying set-screws: it's a pain in the ass to get it all precise!!!! Mine are functional (mostly) but very sloppy.
macumbista.net
macumbista
PostPosted: Mon Nov 02, 2009 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, curious to know what material you used for the boats... you mentioned the boats themselves are pre-fab. Aluminum? How much does your whole case weigh (minus modules)? I'm wondering if I'll be able to keep mine within the 20kg (including Pelicase) allowed by most European airlines....
macumbista.net
lanxe
PostPosted: Mon Nov 02, 2009 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, in the open position there are straps that bolt into the wood (actually into wood anchors made of steel....I tried brass, but it was too soft). Without these straps the case would stay open, but wanted to close if pressure was put on certain portions of the face. The downside is it requires one to bolt the straps in when in the open position, the upside is its rock stable.
The boats are the ones I think ericcoleridge was referring to from mouser. They are the 7"x17"x3" BUD prefab boats. They are great. The total weight is very manageable, I cant say the exact weight as I dont have a scale. But I will say that it is rather light and I dont think there would be any issues with taking it on a plane.
I may build another one with the knowledge that I have gained from this one. Some mistakes were made, and I am not completely satisfied with a few things. I never routed power between the boats either.
