<on air> Various Artists March Equinox concert
 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Benjolin easy battery connect
Post new topic   Reply to topic Moderators: Rob
Page 1 of 1 [14 Posts]
electri-fire
G2 patch files: 4
PostPosted: Mon Nov 02, 2009 3:50 pm    Post subject: Benjolin easy battery connect Reply with quote  Mark this post and the followings unread
Due to lack of time we didn't get to connect the batteries at the workshop building the Benjolin, so the circuitboards were tested with Rob's optional In/out board.
I soldered the battery holders myself later, but made a mistake. So my Benjolin got hot and smelly, I hope it still works.
Here's how it should/could be done (if you do not have the female header connectors that could also be used and make it look more slick)
Looking at the solderside the voltageconverter transistors are at the upper right corner. The left of these is for -9V, the one to the right provides +9V.
The + and - 9 volt voltage regulators need 2-3 volts surplus to work properly so at he header side you could use 12-15 volts.
Batteries need to be connected at the output of the regulators, here two male headers (connectors) are available at the circuitboard.
I included a JPG to indicate how to connect batteries if you do not use the female connectors for the battery headers. Note: the black wire of the + voltage and the red wire of the - voltage battery go to ground.
How to connect batteries to the Benjolin without header connectors.
 Filesize:  29.16 KB
 Viewed:  32311 Time(s)
PostPosted: Tue Nov 03, 2009 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, hot and smelly, now thats not good Wink Nice to have met you at EM09 Wink
It's likely that an IC has been damaged or at best, very degraded. I was very suprised that the kits did not come with sockets so that easy IC changes could be made for such misshapes. For an extra buck or two, it would have saved lots of desoldering at the workshop. I to purchased a Benjolin but will socket all the IC's.
Thanks for saving someone else the grief you went through by clarifying the battery connections Wink
Bill
bugbrand
PostPosted: Tue Nov 03, 2009 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Seeing as I didn't know what a Benjolin was I did a search and found the site - looks interesting!
One thing I noticed from the picture was that the ICs don't all face the same way! That is always a dangerous way to go... especially without sockets. I always provide sockets with workshop orientated kits otherwise people are bound to make mistakes!
PS - electri-fire - I see you're in Breda - do you know Tom Tok Tek?
http://www.bugbrand.co.uk
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my Completed case for the Benjolin.
I agree that sockets would have been greatly appreciated. The PCB was very high quality for a home etched unit. Kudos to Rob and Joker for the workshop.
 Filesize:  1.78 MB
 Viewed:  1020 Time(s)
 Filesize:  1.78 MB
 Viewed:  968 Time(s)
 Filesize:  1.76 MB
 Viewed:  896 Time(s)
 Filesize:  1.76 MB
 Viewed:  864 Time(s)
 Filesize:  1.68 MB
 Viewed:  876 Time(s)
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple more...
 Filesize:  1.8 MB
 Viewed:  905 Time(s)
 Filesize:  1.8 MB
 Viewed:  911 Time(s)
 Filesize:  1.76 MB
 Viewed:  900 Time(s)
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the labels for the knobs.
 Filesize:  1.76 MB
 Viewed:  844 Time(s)
Audio files: 280
PostPosted: Tue Nov 03, 2009 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that is nice work, you were right about the case Cool
PostPosted: Tue Nov 03, 2009 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy cow Dan !!! That is really beautiful. I love it. Looks like a hard drive enclosure. Nice idea !! Now you have no excuse not to jam at EM 2010 Wink
I have mine and studied the circuit one more time ...
Bill
electri-fire
G2 patch files: 4
PostPosted: Tue Nov 03, 2009 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa Danno, you're fast, we built this board last saterday.
Anyway, labeling seems a good idea, I scribbled the names on my board with a marker for lfuture reference. Saves me from checking the schematic later.
(note: Dan's cicuitboard is mounted with the two headers on the left side)
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
Yes it is a Hard Drive enclosure. The USB circuit in the enclosure had failed. Seemed just perfect use for the thing.
Worked on the case two days straight. I rather like it.
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just figured out that in my haste, I put the knob labels on incorrectly. I've replaced the photo. Sorry for the fuzzy image.
electri-fire
G2 patch files: 4
PostPosted: Tue Nov 03, 2009 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, lables according to Dan:
Benjolin circuitboard with the knobs labeled
 Filesize:  59 KB
 Viewed:  712 Time(s)
Danno Gee Ray
PostPosted: Tue Nov 03, 2009 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, see this link for verification:
http://web.me.com/klangbureau/DIY/making_of.html
mono-poly
PostPosted: Wed Nov 04, 2009 1:07 pm    Post subject:   Reply with quote  Mark this post and the followings unread
I want a Benjolin to.
