Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Wed Dec 02, 2009 1:56 pm Post subject:
Les,
I think your intuition is correct..64 seconds is a little short. I'd go for the longer 16 minute version. The compromise...does that mean less note variation? If so, I don't think that's a bad thing. _________________ Synth DIY since 1977! |
Inventor
Audio files: 267
Posted: Wed Dec 02, 2009 2:04 pm Post subject:
| Dan Lavin wrote: | Les,
I think your intuition is correct..64 seconds is a little short. I'd go for the longer 16 minute version. The compromise...does that mean less note variation? If so, I don't think that's a bad thing. |
I agree. There are certain patterns that we'll be missing, but overall it's all there. On a future larger version of the board we'll have a logic matrix of all 12 switches for many terms, perhaps 8 or so. For now, however, we are just doing a test run of small boards. So this works.
Les
p.s. yes, the compromise leads to less variation but there is still plenty of variation to be had. _________________ "Let's make noise for peace." - Kijjaz |
electri-fire
Joined: Jul 26, 2006 Posts: 536 Location: Dordrecht NL
G2 patch files: 4
Posted: Wed Dec 02, 2009 2:28 pm Post subject:
| Inventor wrote: | with only 8 bits, and clocking at 4 Hz, we get a 64 second song which is kind of short. Using all 12 bits we get a song 16 times longer, or 16 minutes. ...
With the existing arrangement there is not as much that you can do with those 12 bits of song compared to six 8-bit terms.....
Do you think I should leave the board as-is or change it to six 8-bit terms? |
I could have the patience to listen to a 16 minutes development If the device was out of reach. If not I would use those switches way before 16 minutes have passed. Also I like some repetitiveness, like an old fashioned "song structure".
Six 8-bits seems like the better option to me.
Parts may come cheaper in bulk. Buying a large amount of 8xDIP switches could be more useful than having to buy the less practical 12 and 4 switch versions.
(also keeping in mind your lunetta interest)
Inventor
Audio files: 267
Posted: Wed Dec 02, 2009 2:51 pm Post subject:
These are good points Mathe, I can switch it back to 6x8 no problem, just some effort (sigh) but hey it's worth it.
The real problem here is that we are fighting against the board size limit of free EAGLE CAD. Later (some day) I can buy a full version and make bigger boards, but for now we are just making do with what works.
electri-fire
G2 patch files: 4
Posted: Wed Dec 02, 2009 3:30 pm Post subject:
| Inventor wrote: | The real problem here is that we are fighting against the board size limit of free EAGLE CAD...
now we are just making do with what works. |
Not a problem, an opportunity. Making use of the limitation could be your big strength.
Now you're forced to getting the maximum effect out of your components, keeping cost, building time and required building skill to a limit, and board size standardized, thus facilitating stacking, and bulk buying of enclosures.
I just love the simple e-ChucK Lunetta board in all it's small and modest glory. We've got the beginning of a user base going haven't we?
Inventor
Audio files: 267
Posted: Wed Dec 02, 2009 5:54 pm Post subject:
Yes, "Love the constraints" was the advice that and old engineer gave me in my youth. He was right.
Dan Lavin
Audio files: 21
Posted: Thu Dec 03, 2009 12:41 pm Post subject:
Les,
On a lighter, non-technical side, I put my marketing hat on and came up with some product name suggestions:
For the Bass Guitar:
Karplus Strong = One Mean Bass Guitar! (Kar + Strong, get it?!)
For my planned Chord Guitar:
Karplus Strum
I wanted to use Karplus Strongbad, but I think the fairly stringent copyright/trademark in this country would prevent that.
Maybe others can come up with more amusing or useful names!  _________________ Synth DIY since 1977! |
Inventor
Audio files: 267
Posted: Thu Dec 03, 2009 12:56 pm Post subject:
You know, it's funny Dan, but I feel that "Karplus Strong" stands alone on it's own merits. Besides the fact that we give credit to the creators of this algorithm, the ring of Strong preceding Karplus is just sweet to my ears. Perhaps we should plan a multi-timbre board with multiple feedback loops that does a chord, would you like that?
Dan Lavin
Audio files: 21
Posted: Thu Dec 03, 2009 1:45 pm Post subject:
Les,
well you're the boss! You can name these things whatever you like!
My idea for the power chord guitar was to use 3 voices with 2 delay triggers so you get a quick 3 note adjustable strum. You tune two of the voices an octave apart with a fifth in the middle, of course. Stand back Angus/Pete/Richie/(insert your favorite guitar hero here)!
If you can do that with one board, that would be great, but I think you need the individual envelopes on each note or it just sounds too much like a synth chord....not that there's anything wrong with that , but then I don't think you need K-S. _________________ Synth DIY since 1977! |
Inventor
Audio files: 267
Posted: Tue Dec 08, 2009 1:28 am Post subject:
Since we decided to go with 6x8 switches, tonight I made the appropriate changes as shown in the pdf files attached. The board autorouted much more easily and there are eight fewer components - worked out well.
Les
 Download (listen) |
| Filename: |
BS10sch.pdf |
38.34 KB |
| Downloaded: |
352 Time(s) |
| BS10 Printed Circuit Board |
 Download (listen) |
| Filename: |
BS10pcb.pdf |
85.44 KB |
| Downloaded: |
326 Time(s) |
electri-fire
G2 patch files: 4
Posted: Tue Dec 08, 2009 5:13 am Post subject:
| Dan Lavin wrote: | My idea for the power chord guitar was to use 3 voices with 2 delay triggers so you get a quick 3 note adjustable strum...../
If you can do that with one board, that would be great, but I think you need the individual envelopes on each note or it just sounds too much like a synth chord....not that there's anything wrong with that , but then I don't think you need K-S. |
Les, if you think this is feasible, by all means do so, but...
I think one KS circuit per module would be more practical for most users, and having just one version probably keeps cost down.
Envelope on the KS is not a separate function is it? It is determined by the nature of the stim and the filter and feedback amount, so you can adjust these to your liking for each voice.
Might a simple trigger delay be made by slurring the puls slope with a capacitor, then Schmitt-trigger it to square again? Some schematic is likely to be around here at the forum somewhere...
Dan Lavin
Audio files: 21
Posted: Tue Dec 08, 2009 3:20 pm Post subject:
Electri-fire,
My power chord guitar would be a subset of Les' creation. I would explore how to do it and publish my results. This would be more of a mod rather than what most people would want. _________________ Synth DIY since 1977! |
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Tue Dec 08, 2009 4:24 pm Post subject:
When testing the board I'll add a 1V/Oct in. So I can use it with the modular. If you add such a circuit on each board, you can get a power chord by adding 0.583 Volts to another to get the root and the fifth.  |
Inventor
Audio files: 267
Posted: Tue Dec 08, 2009 5:17 pm Post subject:
The boards should arrive and get shipped out one week from today (Wed. 12-16-09) or shortly thereafter.
Dan Lavin
Audio files: 21
Posted: Tue Dec 08, 2009 8:00 pm Post subject:
wmonk,
yes, that is what I had in mind. If we both publish our mods, it will help Les and anybody following the thread. I think these KS modules will have more applications as people work with them. I'm wondering if Les knows what he has unleashed on the world?
I suppose a 1v/octave output could be added to Les' Boolean Sequencer as well to use it with std modular equipment. _________________ Synth DIY since 1977! |
Inventor
Audio files: 267
Posted: Tue Dec 08, 2009 8:16 pm Post subject:
Guys, if you publish your expo mods that would be of great help to us all. I don't know how to do expo, and though I've skimmed a web page on one circuit, I have no really intuitive understanding of how they work. That's a real stumbling block for me.
Now that you mention it, the BS board could use a pot in place of each term's summing amp input resistor to weight the bits, creating different notes precisely. There is no room on the board for six pots, but in the future with a larger board, sure.
As to knowing what I have unleashed upon the world, nope! I feel from the level of interest that there is something good going on here but I don't have much experience in this arena so I really don't know the impact. Thanks very much for the compliment though, Dan!
I am now beginning to wonder about future products, though there is plenty of work left on the existing boards. I wonder if we can make other instruments like a flute or a saxophone by using the ChucK STK models and implementing them in analog form. Interesting...
electri-fire
G2 patch files: 4
electri-fire
G2 patch files: 4
Posted: Wed Dec 09, 2009 5:13 am Post subject:
| electri-fire wrote: | | Not very hard to come up with, but for your convenience: |
Actually this was hard to come up with.
In doubt about the proper wiring at the pots ( to get low to high response) I replaced the attachment 4 times.
My head's not working today. Hope I got it right this time.  |
Inventor
Audio files: 267
Posted: Wed Dec 09, 2009 5:39 am Post subject:
Yes, Mathe, for panel mount pots your solution will work nicely. I was thinking of PCB mount pots when I made that statement, but I guess I should be more open minded, heh.
Inventor
Audio files: 267
Posted: Wed Dec 09, 2009 5:45 am Post subject:
Oh, and one more thing, if we use an expo converter on the input of the KS board, then there is no need for an expo converter on the output of the BS board (if I understand it correctly). This is because the 1V/octave is linear in the note circle, and the input expo converter will scale the linear output of the BS board into the exponential frequency spread required by the human ear. Does that make sense?
wmonk
Audio files: 15
Posted: Wed Dec 09, 2009 5:55 am Post subject:
Yes!
And it's better to have an exponential input, as it can except any voltage source and scale it.
(Try to calculate linear-out to exponential-out, that'll produce big voltages, and without a converter on the output of the BS, you can use the output voltage as linear (by bypassing the expo converter of the KS) or exponential input.
In fact, all CV sequencers put out a voltage, and the VCO (voltage controlled oscillators) have the expo-converter. |
Inventor
Audio files: 267
Posted: Thu Dec 10, 2009 11:29 am Post subject:
I have received payment or otherwise reserved nine boards now, so there is only one remaining. So if you would like a board, please send paypal of $21 + shipping ($5 US, $10 International) to lester.hall@comcast.net. If I run into the awkward situation of more than one more order placed, I'll try to make arrangements, with the worst case scenario being that there may be a wait for second run boards.
Thankfully nobody ordered parts kits, as I am just getting started with this and making a perfect kit without reorders would be a bit of a risk. This is because some of the footprints are not fully verified against available parts, meaning some creative soldering may be required in one or two places.
Four of the booards (including the one for myself) are assembled boards, meaning that I will assemble them and figure out the appropriate charge for that service. I figure it will be parts cost x 1.50 + labor at $20 or so an hour. I think that's very fair in that I won't be losing money this time and yet the overall cost will be low for an assembled board. Please let me know if that billing rate is appropriate.
Thanks to everyone who has made suggestions, caught errors, and especially to those making the commitment of buying a board or two. The teamwork and DIY spirit are alive and well at electro-music!
Inventor
Audio files: 267
Posted: Wed Dec 16, 2009 5:38 pm Post subject:
I just got the bubble mailers today and put together five circuit boards for mailing out to customers - you know who you are! I will mail them tomorrow. Soon I will put together an updated BOM with DigiKey part numbers so you can place an order and get exactly the right parts. I will post that BOM here.
My thanks go out to everyone who helped out on this project so far and in the future, and also to those who placed orders. I'm not making a profit, but the extra 50% you are paying covers my part of the hobby costs so who can ask for more than that on a first run board?
So keep an eye out for the mailbox, you'll be getting your board soon!
Inventor
Audio files: 267
Posted: Fri Dec 18, 2009 6:04 am Post subject:
I am exhausted, simply exhausted. My car broke down and needed a $440 repair (two fuel pumps) which was a great discount but put a damper on projects. I simply do not have the wherewithal to get to the post office today so it will have to be Monday when I do the mailing, sorry.
Also because of the car repair, I cannot order parts to build Karplus Strong boards until next month's check arrives. So it's an off month for the project in my little corner of the world.
Inventor
Audio files: 267
Posted: Wed Dec 23, 2009 3:13 am Post subject:
I have good news and bad news, first the bad news:
Well I couldn't get to the post office yesterday because my car is still broken down. After a total of $1200 or so in it, now it won't start at all. The mechanic suggests a relay. sigh. I am going out shopping with Sunshine tomorrow so I'll try again to visit the post office.
The good news is that I received a $1,000 check from my old company for a patent royalty, whew! Now I can upgrade my studio, fix my car, and still have enough left over to buy Karplus Strong parts! woohoo! It's a merry Christmas holiday after all...
