today> Twyndyllyngs Chez Mosc
 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Gliss
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [10 Posts]
Audio files: 505
PostPosted: Tue Jan 19, 2010 12:46 pm    Post subject: Gliss Reply with quote  Mark this post and the followings unread
These vids show some of the basic functionality of the app, but you can do a lot more with it - load your own samples (and it is easy via wifi), set the range and choose from a few pre-set scales, put a master delay on the mix, define a longer (much longer) sequence length, move around specific events, etc.
It also makes good use of the accelometer, you can set gravity and friction to define playback speed, play it backwards (including the samples) and more.
Very fun!
BobTheDog
PostPosted: Wed Jan 20, 2010 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the look of this one.
Audio files: 281
PostPosted: Sat Jan 23, 2010 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
just got this, very cool, but weird, which I like Smile
Audio files: 505
PostPosted: Sun Jan 24, 2010 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I must say that the weirdest thing about this app by far is the increasing port number every time you load samples via wifi. Every time I open the wifi connection, the port increases by one. Confused
But I still love it!
Audio files: 281
PostPosted: Sun Jan 24, 2010 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
the instructions on the teatracks site says this is a security measure
been trying to find out what pitch to load samples in at
what do you use rob?
Audio files: 505
PostPosted: Sun Jan 24, 2010 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean do I use a reference pitch? I don't, really, because I love the way the events slide around after having been played once. But I do experiment with the range of the samples, and also make sure they sound good in reverse before I load them. I have not been using the scales in Gliss atall though, I imagine that a ref pitch makes sense in that context.
But I'm not sure if I have understood the question...
Audio files: 281
PostPosted: Mon Jan 25, 2010 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I just want to know what pitch samples should be loaded in at for the scales to work properly.
I did a bit of experimenting last night and C looks it works, now i just need to work out how gliss deal with long samples
Audio files: 505
PostPosted: Mon Jan 25, 2010 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I would think that any pitch works OK, as long as all the samples are in the same pitch, or in a perfect octave relationship. I have to try this at some point.
Audio files: 281
PostPosted: Mon Jan 25, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, this is true if you are only using gliss, but what if you want to use it with something else?
Audio files: 505
PostPosted: Mon Jan 25, 2010 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I suppose you could play around with the pitch range settings, or base pitch in scaleName settings until you have something workable, at least in an improvisational setting. But yeah, for serious work I would start with C as you did, then try A. It's hard to work out what "base pitch" is on the interface itself, I guess a bit of trial and error is needed here.
Have you tried some of the Indian and Chinese scales? I love them!
