Joined: Apr 24, 2009 Posts: 2528 Location: Bristol UK
Audio files: 512
BobTheDog
Posted: Wed Jan 20, 2010 8:34 am Post subject:
| I like the look of this one. |
Joined: Feb 04, 2005 Posts: 2886 Location: Nottingham, UK
Audio files: 281
Audio files: 512
Posted: Sun Jan 24, 2010 9:04 am Post subject:
I must say that the weirdest thing about this app by far is the increasing port number every time you load samples via wifi. Every time I open the wifi connection, the port increases by one.
But I still love it! _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 281
Posted: Sun Jan 24, 2010 9:55 am Post subject:
the instructions on the teatracks site says this is a security measure
been trying to find out what pitch to load samples in at
what do you use rob? _________________ Jez
music | adventures in sound | gear for sale |
Audio files: 512
Posted: Sun Jan 24, 2010 12:27 pm Post subject:
| modulator_esp wrote: | the instructions on the teatracks site says this is a security measure
what do you use rob? |
Do you mean do I use a reference pitch? I don't, really, because I love the way the events slide around after having been played once. But I do experiment with the range of the samples, and also make sure they sound good in reverse before I load them. I have not been using the scales in Gliss atall though, I imagine that a ref pitch makes sense in that context.
But I'm not sure if I have understood the question... _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 281
Posted: Mon Jan 25, 2010 3:39 am Post subject:
I just want to know what pitch samples should be loaded in at for the scales to work properly.
I did a bit of experimenting last night and C looks it works, now i just need to work out how gliss deal with long samples _________________ Jez
Audio files: 512
Posted: Mon Jan 25, 2010 6:07 am Post subject:
I would think that any pitch works OK, as long as all the samples are in the same pitch, or in a perfect octave relationship. I have to try this at some point. _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 281
Posted: Mon Jan 25, 2010 9:14 am Post subject:
| Muied Lumens wrote: | | I would think that any pitch works OK, as long as all the samples are in the same pitch, or in a perfect octave relationship. I have to try this at some point. |
yes, this is true if you are only using gliss, but what if you want to use it with something else? _________________ Jez
Audio files: 512
Posted: Mon Jan 25, 2010 10:28 am Post subject:
| modulator_esp wrote: | | Muied Lumens wrote: | | I would think that any pitch works OK, as long as all the samples are in the same pitch, or in a perfect octave relationship. I have to try this at some point. |
yes, this is true if you are only using gliss, but what if you want to use it with something else? |
I suppose you could play around with the pitch range settings, or base pitch in scaleName settings until you have something workable, at least in an improvisational setting. But yeah, for serious work I would start with C as you did, then try A. It's hard to work out what "base pitch" is on the interface itself, I guess a bit of trial and error is needed here.
Have you tried some of the Indian and Chinese scales? I love them! _________________ Muied Lumens Sub Forum
Bandcamp |
