<on air> Sorry, no show today/tonight Chez Mosc
new revision DUAL 281 PCB
Page 1 of 10 [227 Posts]
Goto page: 1, 2, 3, ..., 8, 9, 10 Next
toppobrillo
PostPosted: Thu Mar 11, 2010 3:49 am    Post subject: new revision DUAL 281 PCB Reply with quote  Mark this post and the followings unread
what kind of interest is there really? i did alot on it the other night. What this is is a double-sided, dual 281 PCB, based on the previous work done on this project. It uses an LM13700 and a single CD4016 IC shared between both generators. Also, the "or'd" out, or "peak" output has been improved.
Wiring will be considerably cleaner, but no PCB mt. pots this time. The final measurements will be 3"x4.2" and will include Euro and MOTM header pwr header. Is there interest in a group buy? Also, I would be interested in doing a quick-turnaround proto build if anyone is game to iron out any kinks.
rosch
PostPosted: Thu Mar 11, 2010 4:13 am    Post subject: Re: new revision DUAL 281 PCB Reply with quote  Mark this post and the followings unread
Very Happy yes there is!
edit: 2 please
zthee
PostPosted: Thu Mar 11, 2010 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for a few!
johans121
PostPosted: Thu Mar 11, 2010 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Depending on the price I would buy 2 or 4 boards.
Don't feed me Indian, you WILL regret it!
-Jim
synthi
PostPosted: Fri Mar 12, 2010 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
YES! Cool
numbertalk
PostPosted: Fri Mar 12, 2010 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be up for a couple of these - when you say you fixed the "OR" problem, was this the issue with it having a slight DC offset? Were you able to eliminate this?
toppobrillo
PostPosted: Fri Mar 12, 2010 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah the new one uses an opamp circuit as I was able to smoosh everything together much tighter, works perfect Cool
[/quote]
DGTom
PostPosted: Sat Mar 13, 2010 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
In for 4 Very Happy
I think I'll build the 4 single boards I have as 4 one frac unit modules instead.. I'm a sucker for function generators!
ericcoleridge
PostPosted: Sat Mar 13, 2010 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great; I'd be in for 2 to 4 double boards, depending on price.
a_guy_called_tom
PostPosted: Sat Mar 13, 2010 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, definately interested in 2 of these
jaidee
PostPosted: Sun Mar 14, 2010 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll be in for one , thanks.
intercorni
PostPosted: Mon Mar 15, 2010 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
1 please Smile
/mr
PostPosted: Fri Mar 19, 2010 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful! The single boards were too big for me when making quads.
Now I want some 281s! Very Happy
Funky40
G2 patch files: 5
PostPosted: Fri Mar 19, 2010 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
guess i take 4
newdendrite
PostPosted: Fri Mar 19, 2010 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for four boards! Thanks.
loydb
PostPosted: Fri Mar 19, 2010 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll grab a few for sure, 2-4 depending on price.
The Peasant
PostPosted: Fri Mar 19, 2010 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd definitely take a couple.
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
emdot_ambient
PostPosted: Sat Mar 20, 2010 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd go for 2 as well.
emdot_ambient
PostPosted: Sat Mar 20, 2010 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Double post.
henrikgo
PostPosted: Sun Mar 21, 2010 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for two!
ach_gott
PostPosted: Tue Mar 23, 2010 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for between 2 and 4, depending on the price.
diablojoy
PostPosted: Tue Mar 23, 2010 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
+2 here please Smile
reve
PostPosted: Wed Mar 24, 2010 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for one or two.
StoneRose
PostPosted: Fri Mar 26, 2010 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for two (or four, depending in the price)
Funky40
G2 patch files: 5
PostPosted: Sat Mar 27, 2010 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
me too, two or four
