Intro to Lunettas - Document
Page 2 of 2 [41 Posts]
Goto page: Previous 1, 2
RF
Audio files: 28
PostPosted: Thu Mar 11, 2010 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
droffset wrote:
... I like the idea of 4017 based dividers that give really nice synchronous /2 /3 /4 /5 etc divisions ...
Yes! These are really useful!
The document is coming along nicely, Dr.!
bruce
www.sdiy.org/rfeng
PostPosted: Thu Mar 11, 2010 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree!
electri-fire
G2 patch files: 4
PostPosted: Fri Mar 12, 2010 5:55 pm    Post subject:
Subject description: divide timing in lunettas
I've used a 4017 counter, indeed hardwired to 8 steps. The 4040 is nice and does many even divisions (divide by 2, 4, 8, 16 etc) you might want.
It's the odd divisions that are not so easy to come by. Well, there's divide by "n" counters (wich I don't have) and may be not as straightforward to use.
I want to come up with a fairly small and versatile portable setup, so I'm reducing the amount of in/outs for each CMOS chip.
At any rate (well known lunetta builder speak, hehe, hi Rych), my next version 4017 will have just a clock in, a DPDT switch to select two different reset points and simultaneously send the right step pin to the output banana.
I can have two of those and still use less panelspace than my current 4017 that has 8 outs.
Also a much simpler build (aargh, all those wires) and for cheaper as well, considering the cost of multi rotary switches if you'd want adjustable reset.
I haven't built it yet, but should work. If you want to see how I planned this, I posted a little layout at the Lunetta designs thread.
MirlitronOne
PostPosted: Thu Apr 08, 2010 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice set of articles Doc, but for the sake of the beginner could you please change the reference to the "7085 voltage regulator" to the correct "7805"?
Wink
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
droffset
PostPosted: Thu Apr 08, 2010 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha, I missed that one, thanks for bringing it up! Smile
Hey folks out there, if you're looking for specific info in the document and can't find it, please email me so I can get it added.
Edit: Spelling mistakes.
Audio files: 236
PostPosted: Thu Apr 08, 2010 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Droffset, I apologize for not commenting on your excellent introduction doc before now. Somehow I missed this topic until now.
It's a great read. Very useful. Thanks for sharing.
I have a comment but I need to get my thoughts together first.
droffset
PostPosted: Fri Apr 09, 2010 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem at all Mosc, just glad to give a bit back to the forum after it's helped me learn so much. Smile
I'm no engineer though, so if you see blatantly wrong information let me know.
slugger
PostPosted: Fri Apr 09, 2010 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice, thanks for this, droffset! Very handy.
the synthgeek pages - samples & stuff
my blog
tjookum
Audio files: 26
PostPosted: Sat Jun 05, 2010 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
hi droffset,
great document, it really helps having a lot of clear info in one place.
Ive been searching the forum for this, but I can't seem to get a definitive answer about power supply's. You say use the 7805 and run it at 5v, but ive seen anything form +/- 9v to +15v. Since the different power supply's dictate different parts it would be nice to have a clear list on what the pro's and con's are.
Hunter S. Thompson
movies
noise
RF
Audio files: 28
PostPosted: Sat Jun 05, 2010 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
tjookum -
my 2 cents -
The CMOS does fine at 5 volts - if you are going to stay all CMOS that would be fine.. 9 is handy if you want to power it from batteries... and a bi-polar supply with 9 volt batteries is easy...
I've used 12 quite a bit - either cause I had the regulators, or because I wanted a + and - 12 volt supply to use with bipolar circuits in the Lunetta. My other equipment used + and - 12 as well. I have not seen any advantage to 15 volts...
Your mileage may vary... Smile
have fun
bruce
www.sdiy.org/rfeng
droffset
PostPosted: Sat Jun 05, 2010 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
What Bruce said. Smile
One thing more, a lot of the drum modules I'm looking at work with +-15volts, so that's the kind of power supply I have for that stuff. My Lunetta (which all runs on 5v, sends triggers and gates to the bigger system and it all seems to play nicely, as long as the grounds are connected. )
Rykhaard
PostPosted: Sat Jun 05, 2010 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
In my first modular building days in about '92, I went with +/-9V. Coming to wishing for a far more stable power source, I moved to a well regulated Power One +/-15V 1.5 amp supply.
For my noise machine that I started building a year ago February, I started with +/- 9V. Within a month, I tried everything in it, with my +/- 15V supply and it all worked just the same - just with higher otuput voltages. (But it will all still work with +/- 9V as well. And the -9V is only needed in the very few places that have bipolar opamps. The rest runs on the +9.
When I start building things with my PICs, they and everything connected to them will be strictly +5V.
tjookum
Audio files: 26
PostPosted: Sun Jun 06, 2010 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
Im currently just testing stuff, so for now a 9v battery works perfect. I think im going to stick with 5v for the actual modular though, I have an arduino laying around here somewhere wich I want to use later on.
Hunter S. Thompson
movies
noise
telstarmagikistferrari
Audio files: 43
PostPosted: Mon Apr 18, 2022 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anybody have access to the Intro to Lunetta document? I need it!
View user's profile Send private message Visit poster's website Yahoo Messenger
droffset
PostPosted: Tue Apr 19, 2022 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Oops! Didn't realize this link went dead. I'm surprised anyone still knows it exists! Very Happy
Here it is
Audio files: 43
PostPosted: Wed Apr 27, 2022 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot! I'm revisiting building up a Lunetta system. Will post progress here!
