Nord Lead 2x Sound Editor
Page 1 of 2 [34 Posts]
thekingofsting
PostPosted: Tue Jun 08, 2010 2:57 pm    Post subject: Nord Lead 2x Sound Editor Reply with quote  Mark this post and the followings unread
Right I want to be able to upload patches to my lead aswell as save settings I create. What can I use, from looking at some threads I have come across NordGen but whenever I open a .ngf file the windows error send do not send to microsoft error comes up and closes.
Am I doing something wrong? Is there something else I can use?
Thanks.
Jack
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 08, 2010 3:05 pm    Post subject: Re: Nord Lead 2x Sound Editor Reply with quote  Mark this post and the followings unread
welcome thekingofsting
Have you copied the drivers to the Windows System folder? See http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/nordgen[dll].zip
Wout
thekingofsting
PostPosted: Tue Jun 08, 2010 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah right silly me - ok, as in control panel -> system?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 08, 2010 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm not much of a computer man, but mostly I copy these drivers to C > Windows > System or System 32 and paste there. I never know which one to choose, so I paste them in both folders Smile
Wout
thekingofsting
PostPosted: Tue Jun 08, 2010 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok I've done that but it still doesnt seem to work - do you have any links for other files I can open with it.
Thankyou so much for your help btw Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 08, 2010 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
More Patches are at http://nm-archives.electro-music.com/020_NordLead2/021_Patches/
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 08, 2010 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I have to know more...
Windows version?
Midi cables right?
Midi interface installed (MidiPorts visual in NordGen?) and which one?
NordGen settings right?
Which 'send' command?
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 08, 2010 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also take a look at http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/Nord_Generator.htm
The text isn't finished yet...
Wout
thekingofsting
PostPosted: Tue Jun 08, 2010 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
that is awesome
I use windows xp, I havent tried to upload anything yet through the cables and interface, I believe that should be fine.
there are alot of patches there - im sorry for being a bit of a noob :/ and I am very grateful for your help.
How do I go about saving a few select patches off my keyboard before putting one of the whole libraries on it?
how many patches can you upload to it? can you mix and match?
thanks again x
thekingofsting
PostPosted: Tue Jun 08, 2010 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok also - i've figured how to dump the first 100 patches and save them - really only a 14kb file?
But for some reason it is not recieving anything - the interface detects midi out but the nord doesn't change or make any signs. It is a lead 2x btw Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 09, 2010 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reaction, but I have a nasty habit... I want to sleep sometimes Wink
… I use windows xp, I havent tried to upload anything yet through the cables and interface, I believe that should be fine.
Okay Smile
To noob or not to noob, there are always questions… Wink
Uploading single files from the computer into the NordLead is done using the buffer memory. You can play the sound and decide if you want save it internally. If it is not your kind of solund, just upload another into the buffer. In the heat of the battle (Dutch expression translated) you easily press Store, just reset by pressing any Slot button.
This means you don’t need to destroy your banks in the synth the first time you explore sounds. To save single Programs see below (to get NordGen reveive SysEx…)
4x99 in the NordLead2X. In the NordLead2 40, or on a PCMCIA card 3x99, but you can use as many cards as you need which results in 99xUnlimited…
By using the buffer memory described above. Beware: Uploading a complete bank replaces the bank in the memory!. The buffer method is much better to use! BTW NordGen can't send complete banks. To check out sounds I use the computer arrows and the return. It does receive bank downloads from the synth. Not Performances. To save these I use Borne’s Send SysEx, which has no interface showing parameters like NordGen.
Each single Program is only 139 bytes!!! Only fly-droppings Wink
In NordGen go to [SysEx] and enable [receive]. On the synth using [Shift+OctShiftUp] will result in changing parameters in NordGen.
Keep in mind the Lead is a grand dame of 16 years in production! Is there a synth which became older? And NordGen is created around 1998, you know, in those days coal provided the power of the computer… Wink
Wout
thekingofsting
PostPosted: Fri Jun 11, 2010 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm somewhat getting there - it dumps the seperate sounds that I want to save (that I made myself) - still can't preview a sound or make the nord 'recive' sounds from the editor - are you ever on chat dude?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jun 11, 2010 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have the right Midi Ports selected?
Wout
thekingofsting
PostPosted: Fri Jun 11, 2010 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah - ok I seem to be getting there slowly but surely - for some reason I need to change the midi out and re select the correct one in order for it to work - now tryin to get my head around downloading your full libraries and uploading them - how do you do it so that you do not the wrong bank? Say for instance I want to keep my first hundred but want to replace the second hundred.
Glad I've started to understand - thanks to you Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jun 11, 2010 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
... - for some reason I need to change the midi out and re select the correct one in order for it to work -
If you have more Midi ports, this is a known bug Confused
now tryin to get my head around downloading your full libraries and uploading them - how do you do it so that you do not the wrong bank? Say for instance I want to keep my first hundred but want to replace the second hundred. ...
Lets assume you want this bank http://nm-archives.electro-music.com/020_NordLead2/021_Patches/0600_Library02_Bank03/
There is a file called 'n2lib2b3.mid' Drag&Drop this into NordGen and all 99 will be there. What I do is using the computer keyboard Up&Down arrows to select Program (Patch) one. You can click the [send] button and the data is in the Buffer memory, so not in the real memory yet. Play the sound and use the Wheel to. You want to save this in the synth press [Store] and scroll to the memory location you want to be overwritten. Press [Store] again and you are done Smile Scroll to the next Program in NordGen. I use the [return] and not [send]
I suggest to play the files first and running all 99 again, so you know what you want and what not. And make notes. In the archive there is a 'doc' file. Use this!
Uploading the 'n2lib2b3.mid' file in a software sequencer will upload the complete bank into the memory, destroying it as a result… And we don’t want that to happen, do we? Smile Oops... Told you already... Embarassed Take your time and enjoy it. I always find it much fun to explore a Program, change parameters and if I like it I make an upload into NordGen [DumpOne = Shift+OctaveUp], so I won’t lose that sound. There is a risk you create a complete new song Very Happy
Wout
PS And maybe the next [in beta] text you want to read...
http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/Prgm_Lay_Perf_01.htm
Dynaudio82
PostPosted: Wed Jun 23, 2010 10:49 am    Post subject: Re: Nord Lead 2x Sound Editor Reply with quote  Mark this post and the followings unread
Hello to everyone, Some one can Help me to get the Download of the NordGen please? Razz
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 11:38 am    Post subject: Re: Nord Lead 2x Sound Editor Reply with quote  Mark this post and the followings unread
welcome temptation_07
... Some one can Help me to get the Download of the NordGen please? Razz
Wout
Dynaudio82
PostPosted: Wed Jun 23, 2010 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very very much! i already download but, i think i need some use guide Rolling Eyes after read every word here i think i have the same problem of the creator of this topic, but in my case i dont have any idea of how i use and syncronize with my Nordlead, i dont want break your patience, but can you Help me with this? Embarassed
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
First, what is your computer? It won't work on a Mac...
Second, what OS? Vista, XP or earlier?
Then, do you have a Midi interface connected with two Midi cables between the synth and the computer?
I important to understand it's not a real time editor, so changing a knob doesn't show in the tool until you preformed the command [Shift+DumpOne] on the synth.
Be reading you...
Wout
Dynaudio82
PostPosted: Wed Jun 23, 2010 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Be reading you...
Wout
Hello again Wout, thanks for the fast answers Razz ... I use Windows XP, the Nordlead is connected in Motu interface, there i have connected the Midi cables Out with In, and In with Out, i know how works that, but im totally new on the syx world, i dont have any idea of what i should do first Embarassed
By the way... one of the Midi cables need be connected from the synth to the computer? because i dont have midi (out - in) there Confused ... only in the Motu and both are connected there...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
We will work it out...
No, the Motu is your interface! Are you using M-Audio USB Uno MIDI interface or another one? And in what did you connected the audio cables?
Start the tool and go to Midi In. Is the drop down menu showing the Motu?
And so does the Midi Out?
Wout
Dynaudio82
PostPosted: Wed Jun 23, 2010 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
in the past i use a Tascam, now i only use the Motu 828mk2, is audio an card too, there i have connected the audio cables in Analog 1 and 2
This one i have:
http://www.majormusic.com.au/images/motu_828mkii_small_rgb.jpg
About your question of the menu, you mean this?
 Filesize:  87.83 KB
 Viewed:  17717 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
... About your question of the menu, you mean this?
Yes, that's what I mean Smile
Are those 'Yoke' ports special Midi ports? I would select [828mk2] in both menu's. If you check it again, they will probably have been changed. That's a bug in NordGen. Select at MidiIn the [828mk2].
Is the Midi In on the Motu connected with the Midi Out of the synth?
If so, perform [Shift+DumpOne] see if the parameters (knobs) in NordGen has changed...
Wout
(fingers crossed)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just for others who are following this thread:
This is the Motu we are talking about...
 Filesize:  279.76 KB
 Viewed:  244 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 23, 2010 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
temptation_07!!!
I forgot to tell you to open [Sysex] and select in the menu [receive]!!!
Embarassed
Wout
