VCA-1 using 12 volts
Page 1 of 1 [8 Posts]
adambee7
PostPosted: Thu Jun 24, 2010 8:09 am    Post subject:  VCA-1 using 12 volts Reply with quote  Mark this post and the followings unread
Has anyone used this with +/-12v instead of +/-15v. Very Happy Very Happy
drapdap
PostPosted: Fri Jun 25, 2010 5:12 am    Post subject: Re: VCA-1 using 12 volts Reply with quote  Mark this post and the followings unread
Absolutely. Works just fine. Smile
adambee7
PostPosted: Fri Jun 25, 2010 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers man. Very Happy Very Happy
Sound
PostPosted: Fri Jun 25, 2010 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
But you should change the value of R23 for unity gain.
At first look , if R12=100K for unity gain at 5V.
R23 should be 240K for unity gain at 12V.
adambee7
PostPosted: Fri Jun 25, 2010 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks sound. I did wonder if one or few values would change. Very Happy Very Happy
alanwilder81
PostPosted: Mon Sep 04, 2017 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
hello guys,
i am also running my VCA 1 with 12 V.
Although working, it's output volume is very quite.
it's not clear to me what the R 23 and R 12 should be Smile
and, what's the unity gain?
thanks Smile
wackelpeter
Audio files: 10
PostPosted: Mon Sep 04, 2017 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
unity gain: 1:1 amplification
put in 10V p/p and get 10V p/p out, for example...
alanwilder81
PostPosted: Mon Sep 04, 2017 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Bastian,
i run the VCA 1 with 12 V instead of 15 V.
and now i sorted it out by lowering R 23 to 200 k
