Buchla 218 VC-able Portamento - Works!
Page 2 of 2 [39 Posts]
Goto page: Previous 1, 2
probablyjoel
PostPosted: Sun Dec 07, 2008 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much! This will really help, and I'm really excited to try it out!
probablyjoel
PostPosted: Sun Dec 07, 2008 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am assuming that the manual control is the power source to the V+... is that right?
funkyfarm
PostPosted: Tue Dec 30, 2008 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Shall we use 1N5224 2.8V Zener diode or 1N5233 6V, as stated in schematic ?
Thank you.
neandrewthal
PostPosted: Tue Dec 30, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I used 6v and it works fine.
vtl5c3
PostPosted: Tue Dec 30, 2008 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Use the 6V zener. I need to update my parts layout. Sorry for the confusion.
funkyfarm
PostPosted: Fri Feb 20, 2009 4:24 pm    Post subject: Re: Buchla 218 VC-able Portamento - Works! Reply with quote  Mark this post and the followings unread
vtl5c3 wrote:
I may have to do a bit of fine tuning... if nothing else I will try smaller cap values, since it's pretty easy to get way too much portamento going.
Can you get on/off effect with 5V steps from a sequencer ?
Buchla CV are 0-15V ?
ff
funkyfarm
PostPosted: Mon Mar 02, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can get on/off effect with 12V steps from an CGS step sequencer !
Slew pot fully ccw.
I've added a pot on cv input, and put 33kR in parallel with 68k input resistor to have a cool range curve.
But I have to invert the incoming cv signal because positive voltages reduce slew fx...
I've measured 0,002v offset at the worst potentiometer position !
I use it on v/o
Two midi transposed klee voices ; you can hear 218 slew on the higher one. oakley vco + hot input 291 and a lot of 292.
3 minutes, and maybe not the better sample as an illustration, but,
That rocks !
http://sslstudiodesign.free.fr/218/
LektroiD
PostPosted: Fri Sep 17, 2010 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there anything I can replace the 1N5233 with?
LektroiD
neandrewthal
PostPosted: Thu Sep 23, 2010 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I`m sure any 6V zener (or close enough) would work.
RSFC
PostPosted: Fri Feb 25, 2011 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Curious if these could be used to make a DIY pseudo buchla 255?
ericcoleridge
PostPosted: Fri Feb 25, 2011 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, I'm sorry, that would break every DIY rule in the book. you can't use this vclag and an attentuverter to mimick the functionality of a 255.
RSFC
PostPosted: Fri Feb 25, 2011 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hahaha, no I wasn't asking for permission. I was just curious if my thoughts were correct, which it sounds like they are. Sometimes buchla descriptions of their own modules are cryptic. I wanted to make sure I was thinking about it in the right way.
bubzy
Audio files: 64
PostPosted: Sat Feb 26, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
what book?
surely theres no problem if the schematics are freely available.
incidentally i have used a 6.2v zener and it works ok.
roman_f
PostPosted: Wed Mar 21, 2012 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have it working but the only issue is that the working range of the pot is maybe 7-10. before 7 - nothing happens, then it starts slewing
did anyone experience that? should i put the negative rail instead of a 0 on the CCW lug?
