2010 Build Pictures
Page 19 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, ..., 17, 18, 19, 20, 21, 22, 23, 24 Next
sduck
PostPosted: Mon Oct 18, 2010 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Four pages back you can see my first Son of Storm Tide Flanger build - but I recently built another one for someone else, and took the opportunity to tweak the panel a little. I moved the pots around, so that the ones I was using the most were all at the top, and added the v/oct tracking knob I completely forgot on the first one.
Son of Storm Tide Flanger II front
Son of Storm Tide Flanger II back 1
delayed
PostPosted: Thu Oct 21, 2010 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
MFOS 16 step sequencer project I build for a person.
 Filesize:  249.38 KB
 Viewed:  35312 Time(s)
 Filesize:  172.79 KB
 Viewed:  35310 Time(s)
 Filesize:  171.66 KB
 Viewed:  35309 Time(s)
TekniK
PostPosted: Thu Oct 21, 2010 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
nice look,nice colors !
PostPosted: Thu Oct 21, 2010 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
is the panel realy that brownish? how did you do it? looks awesome!
andrewF
PostPosted: Thu Oct 21, 2010 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
lucky person, hope you will be suitably rewarded
reminds me of the a bit of the Korg SQ10
PostPosted: Thu Oct 21, 2010 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
not finished yet, but i thought to share it anyways. i bought a mixer rackcase to house the next modules i build.
the lower 4U panel already holds my on-beat divider, the attenuverter, and the breakdown stepped filter (consisting of 8 multimode filters).
delayed
PostPosted: Thu Oct 21, 2010 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it is a rust brown color. It is enamel paint. I am learning silk screening and finger joining wood. I got a sheet of AL, cut it to size, 3 coats primer, 6 coats paint, then silk screened the text. The box is ebony stain. Thanks for the nice comments.
TekniK
PostPosted: Thu Oct 21, 2010 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
sexy
philpeery
PostPosted: Thu Oct 21, 2010 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Delayed!
Great job on the silk screening! The rust brown color is very cool! Can you tell us some more details on how you did the screen printing? What kind of ink did you use? Did you have the screen made and coated with emulsion for you? I am thinking of trying this as well, hope you can give some guidance!
Phil
delayed
PostPosted: Fri Oct 22, 2010 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing fancy because I am cheap. I am using normal quart/gallon enamel paint you get at any home store for the text and enamel spray paint for the primer and main color. I found that you really need plenty of coats of primer or the nuts will chip the paint easy. I leave it a day between coats for the primer and main color and 2-3 days for the text to dry.
Made my own screen with Speedball emulsion (I picked speedball because you can get 40-50% coupons from different hobby stores. It makes it the cheapest option. Nazdar it suppose to be the better brand to use for paint and emulsion) and got used screens off ebay and craiglist. You need over 200 for the text 300+ is better for the screens. I used light bulbs for the first panels I made. That works fine for sizes under 8x10. Over that you need another lamp/bulb for each 8x10 area. It takes lots of trial and error to figure out the burning of the screen. I got lucky and found a UV light table on craigstlist for this one. Which worked better than the hanging lights because this is almost 30 inches long. But as long as you are working under 8x10 a photobulb works fine.
This process takes a lot of time and effort for a single print. Silk screening is not really made for this. The set up fee on the cheap side is about 100+ dollars buying mostly used items. But on the other side I have lots of time at the moment and like learning new things. A print this size would have been 100s of dollars to get one made from the normal places that people use. This method also gives you nice results, (better with more practice) and a chance to pick out mostly any colors you want. The little things like tape, wood, hinges, cleaners, towels, squeegee add up the cost. Since you are in NJ I would think that you could find used items easy on the cheap to try it out.
Hopefully that helps a bit. There are lots of videos on the web for printing tees and posters but little about metal. The method is the same, just a change in the paint/clean up items.
"Can you tell us some more details on how you did the screen printing? What kind of ink did you use? Did you have the screen made and coated with emulsion for you? I am thinking of trying this as well, hope you can give some guidance! "
PostPosted: Sat Oct 23, 2010 5:58 pm    Post subject: Just finished some CGS wave shapers
Subject description: The CGS38 and CGS29
When I decided to order PCBs from CGS, I made a relatively large order to save on shipping costs. I included the CGS38 and CGS29 PCBs.
While designing the panels, I discovered that the CGS29 was too large to fit on one 9x3 panel and that the CGS38 would only use about half of a panel. Thus, I decided to design a double-width module containing both PCBs and all of the functions.
The result is to have four wave-processing functions on one 6"x9" panel.
These are all fun modules -- the most flexible is the Wave Multiplier (the left half of the panel) however all the modules will be useful.
The front panel. The CGS38 is the Saw Shifter/Wave Multiplier section. All other functions are from the CGS29.
 Filesize:  1.07 MB
 Viewed:  260 Time(s)
This view of the back shows the two PCBs -- the CGS29 is the larger one in front and you can see the edge of the smaller CGS38 board behind the large board.
 Filesize:  927.55 KB
 Viewed:  253 Time(s)
Taylor
PostPosted: Sat Oct 23, 2010 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's my WTPA? sampler/looper/glitch machine:
Official website for the designer here and my build report here.
I know it's very much the antithesis of the extremely clean (visually) modular synth stuff that makes up most of this thread, so sorry if it offends anyone! Smile The truth is that I build nice electronics as my day job, so for my own stuff I just want to make it NOW instead of taking the time to make it really nice-looking. But I think this box has a certain appeal of its own...
PostPosted: Sat Oct 23, 2010 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, of course, no offense! In fact, I'd never heard of the WTPA project and clicked through to the website. Appreciate you sharing this.
There are many different approaches to synth-building and I enjoy it all.
Once I decided to "back burner" my current build (which is focused on expanding the original Aries synth) I want to do some Lunetta-based building -- which is certainly a different approach.
I'm also interested to learn about programmable chips (I am a systems programmer by day). Thus, I appreciate your post and those of other people.
sduck
PostPosted: Tue Oct 26, 2010 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished this -
MOTM e350 Morphing Terrarium front
MOTM e350 Morphing Terrarium back
PostPosted: Tue Oct 26, 2010 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
you're a machine, aren't you? Shocked
BTW i finished a VC RingMod with a new panel running on 12V yesterday, using a SMD board:
TekniK
PostPosted: Tue Oct 26, 2010 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Steve,this one looks hot!
LektroiD
PostPosted: Wed Oct 27, 2010 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Update on my progress.. Thanks to my friend Robbie for the incredible craftsmanship on the cabinet. If anyone is looking for a cabinet of this quality, please feel free to PM me and I'll pass on the contact details.
 Filesize:  969.29 KB
 Viewed:  3399 Time(s)
LektroiD
frequencycentral
PostPosted: Wed Oct 27, 2010 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
A 14 stage FET phaser, the wires are kinda long cos I assumed for a debug which wasn't needed. I went for a 70's synth feel for this one.
TekniK
PostPosted: Wed Oct 27, 2010 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
sweet
jordroid
PostPosted: Wed Oct 27, 2010 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice Frequency Central, i'm going to try out your "parity" modulation on a super mu-tron biphase (modular biphase with selectable # of phase and regen stages, and odd/even regen, kind of a stripped down Scott Stites multiphase) i have on the breadboard, i quite like the sounds you are getting on the DIYstompboxes thread, fading between odd and even regen really puts it over the top.
Everybody makes such nice stuff here!
-minus-
PostPosted: Thu Oct 28, 2010 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished this... a DR-One Quadrone. Sorry about the low resolution phone photography... AGAIN! Laughing
 Filesize:  176.45 KB
 Viewed:  3405 Time(s)
 Filesize:  230.47 KB
 Viewed:  3334 Time(s)
TekniK
PostPosted: Thu Oct 28, 2010 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice.
Oto Biscuit style graphics
-minus-
PostPosted: Fri Oct 29, 2010 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! I had no idea what you meant with the oto biscuit reference. I just googled it... I was expecting a biscuit tin! Laughing I can see the similarity though! Laughing
loydb
PostPosted: Tue Nov 02, 2010 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally completed my MFOS combo mini-controller and v/oct calibrator. Padauk, bloodwood and ebony carcase with a custom MFOS glass marble as a knob. For the full build blog, see my sig below.
bod
PostPosted: Tue Nov 02, 2010 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
wow! that glass knob is a work of beauty!!!
