drapdap
Posted: Tue Oct 26, 2010 9:43 am Post subject:
Quadrature VC-LFO Subject description: thanks Yves! |
Hi Yves!
Just built this recently, works perfectly, one of my favourite things now...
The 4 leds still missing, i need to finish that, and i messed up the arrow,
but anyway...
Thought i'd say a thank you!
róbert
196.56 KB |
| Viewed: |
358 Time(s) |
220.77 KB |
| Viewed: |
355 Time(s) |
drapdap
Posted: Tue Oct 26, 2010 10:08 am Post subject:
Re: Quadrature VC-LFO Subject description: thanks Yves! |
Also have a question: Would it be hard to add CV to the direction switch?
I have lots of fun just messing with that... |
yusynth
Posted: Tue Oct 26, 2010 10:58 am Post subject:
| drapdap wrote: | Also have a question: Would it be hard to add CV to the direction switch?
Well I suppose, a gate signal could be used to drive a dual CMOS analogue switch instead of the mechanical toggle switch... _________________ Yves |
drapdap
Posted: Tue Oct 26, 2010 1:53 pm Post subject:
| yusynth wrote: |
Well I suppose, a gate signal could be used to drive a dual CMOS analogue switch instead of the mechanical toggle switch... |
Could you help with an example? Did you do such thing on a module of yours,
so i could cannibalise that part?  |
dstrength
Joined: May 23, 2010 Posts: 17 Location: Mobile, Alabama, USA
Posted: Wed Oct 27, 2010 8:50 pm Post subject:
I'm no expert, but perhaps this will help.
The CMOS switches Yves is refering to are widely available with pretty decent data sheets. Maxim makes nice ones...vishay has some pretty affordable ones. Something like this:
http://www.vishay.com/docs/70049/dg401.pdf
is about $3.00 US. There are certainly cheaper versions...just make sure to select one where the input is triggered by the gate voltage (5v), and where the power supply is compatabile (+-15v).
From there, you can pretty much tie directly to the pins as identified on the datasheet. The only other thing you might want to do is a place a decoupling capacitor (like the 100nf Yves uses next to all his Opamps) accross the power rails in close proximity to the IC. |
yusynth
Posted: Thu Oct 28, 2010 12:11 am Post subject:
The DG403 shown on the datasheet will suit your needs (see the application part, fig.9 _________________ Yves |
drapdap
Posted: Thu Oct 28, 2010 12:59 pm Post subject:
Great, thank you for the suggestions!
Anything against using something cheaper like a CD4053?
Matthias used these for the LPG switchboards he was selling recently, so i'll buy some tomorrow, and try to get it going...
robert |
yusynth
Posted: Thu Oct 28, 2010 1:50 pm Post subject:
| drapdap wrote: | Great, thank you for the suggestions!
robert |
Yes, DG403 can be used directly because they can handle a large voltage range. Using CD4053 would require additional circuitry to attenuate then amplify the signals because the cannot handle the voltages (the signals oscillates between -8V and +8V). _________________ Yves |
