5-channel Attenuverting Mixer 2nd run
Page 9 of 9 [214 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9
PostPosted: Sat Aug 28, 2010 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Does this mean you're no longer making this module (or others) available for DIY?
Laughing no!
since the publishing of the prebuilt module i did the VCPS-8 PCB, and i am currently working on the CV ringmod PCB Wink
i just wanted to try out offering a professional built complete module. it worked out well and i will offer more, i believe. however, DIY rules!
sonicwarrior
PostPosted: Thu Oct 21, 2010 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
the board is not changing. i just replace R30 by a Z-diode. oh, and i incorporated the missing 100k resistor to GND for the AC mode - but i didn't change anything to the actual boards layout or part numbers.
What about updating the rev2 documentation to include the Z-diode as an option?
Are the 10nF ceramics critical or is it safe to use e.g. 22nF or 47nF instead?
I have currently no 10nF lying around but I want to finish soldering my boards.
PostPosted: Thu Oct 21, 2010 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
IMHO it is not that critical. it is for filtering noise, and taking the tolrances into account i would say it is oky to use a 22uF.
anyways, i think i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum?
sonicwarrior
PostPosted: Thu Oct 21, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then I'm curious why you chose 10 nF caps instead of the usual 100 nF.
mark_olson
PostPosted: Thu Oct 21, 2010 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
...i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum?
Indeed it would! Just two nights ago I was breadboarding a circuit and found myself wishing I understood decoupling better. Confused
Mark
PostPosted: Thu Oct 21, 2010 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
because i had them ;-P
(you will find both versions in various of designs around here)
sonicwarrior
PostPosted: Thu Nov 04, 2010 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Regarding the Zener:
The direction is towards R29 (black line)?
PostPosted: Thu Nov 04, 2010 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes. replace R29 by a 1k, and replace R30 by a Zener from GND to R29
(GND -->|-- R29). this will clamp the 15V down to the Zener value.
sonicwarrior
PostPosted: Sat Nov 06, 2010 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks. Smile
jnuaury
Audio files: 9
PostPosted: Tue Dec 07, 2010 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
if i dont have trimpots, what would be the best value to replace the trimpot and the 10k resistor before it? 50k?
thanks
az/gde
YouTube
PostPosted: Wed Dec 08, 2010 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
no. the best value would be the actual value of the potentiometer. so match the resistor to the pot (potentiometers have quite a huge tolerance...
RSFC
PostPosted: Sat Feb 05, 2011 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Am I right to think I could use a 3PDT as opposed to a 3PST just wired differently? PST's are f*ing expensive from mouser while PDTs aren't too bad...
PostPosted: Sun Feb 06, 2011 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
you are correct.
tazer
PostPosted: Thu Apr 14, 2011 10:56 am    Post subject: attenuverting mixer pcb Reply with quote  Mark this post and the followings unread
please please please can you do a small run of these when you do the 4046 vco pcb run-i would so appreciate that i have been trying to track this pcb down to no avail-I'm sure others would be interested also, my modular isn't complete without it Wink
I would certainly take a few pcb's of this mixer, see what you can do...............
many thanks
Ian
