| Author | Message |
| fonik
|  Posted: Sat Aug 28, 2010 10:41 am    Post subject: |    |
|  	  | LektroiD wrote: |  	  | Does this mean you're no longer making this module (or others) available for DIY? |
  no! since the publishing of the prebuilt module i did the VCPS-8 PCB, and i am currently working on the CV ringmod PCB
   i just wanted to try out offering a professional built complete module. it worked out well and i will offer more, i believe. however, DIY rules!
| Back to top |  |
| sonicwarrior
|  Posted: Thu Oct 21, 2010 1:10 pm    Post subject: |    |
|  	  | fonik wrote: |  	  | the board is not changing. i just replace R30 by a Z-diode. oh, and i incorporated the missing 100k resistor to GND for the AC mode - but i didn't change anything to the actual boards layout or part numbers. |
 What about updating the rev2 documentation to include the Z-diode as an option?
 Are the 10nF ceramics critical or is it safe to use e.g. 22nF or 47nF instead?
 I have currently no 10nF lying around but I want to finish soldering my boards.
| Back to top |  |
| fonik
|  Posted: Thu Oct 21, 2010 1:28 pm    Post subject: |    |
|  	  | sonicwarrior wrote: |  	  | Are the 10nF ceramics critical or is it safe to use e.g. 22nF or 47nF instead? I have currently no 10nF lying around but I want to finish soldering my boards.
 IMHO it is not that critical. it is for filtering noise, and taking the tolrances into account i would say it is oky to use a 22uF.
 anyways, i think i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum?
| Back to top |  |
| sonicwarrior
|  Posted: Thu Oct 21, 2010 2:06 pm    Post subject: |    |
| Then I'm curious why you chose 10 nF caps instead of the usual 100 nF. |  |
| Back to top |  |
| mark_olson
|  Posted: Thu Oct 21, 2010 2:26 pm    Post subject: |    |
|  	  | fonik wrote: |  	  | ...i need much more knowledge about all this filtering and decoupling stuff - wouldn't this be a great issue for an thread in the main DIY forum? |
 Indeed it would! Just two nights ago I was breadboarding a circuit and found myself wishing I understood decoupling better.
 Mark
| Back to top |  |
| fonik
|  Posted: Thu Oct 21, 2010 3:31 pm    Post subject: |    |
|  	  | sonicwarrior wrote: |  	  | Then I'm curious why you chose 10 nF caps instead of the usual 100 nF. |
 because i had them ;-P
 (you will find both versions in various of designs around here)
| Back to top |  |
| sonicwarrior
|  Posted: Thu Nov 04, 2010 1:04 pm    Post subject: |    |
| Regarding the Zener:
 The direction is towards R29 (black line)?
| Back to top |  |
| fonik
|  Posted: Thu Nov 04, 2010 3:37 pm    Post subject: |    |
|  	  | sonicwarrior wrote: |  	  | Regarding the Zener:
 yes. replace R29 by a 1k, and replace R30 by a Zener from GND to R29
 (GND -->|-- R29). this will clamp the 15V down to the Zener value.
| Back to top |  |
| sonicwarrior
|  Posted: Sat Nov 06, 2010 8:22 am    Post subject: |    |
| Ok, thanks.  |  |
| Back to top |  |
| jnuaury
 Audio files: 9
|  Posted: Tue Dec 07, 2010 7:12 pm    Post subject: |    |
| if i dont have trimpots, what would be the best value to replace the trimpot and the 10k resistor before it? 50k?
 thanks
 az/gde
 YouTube
| Back to top |  |
| fonik
|  Posted: Wed Dec 08, 2010 12:32 am    Post subject: |    |
|  	  | jnuaury wrote: |  	  | if i dont have trimpots, what would be the best value to replace the trimpot and the 10k resistor before it? 50k? |
 no. the best value would be the actual value of the potentiometer. so match the resistor to the pot (potentiometers have quite a huge tolerance...
| Back to top |  |
| RSFC
|  Posted: Sat Feb 05, 2011 7:32 pm    Post subject: |    |
| Am I right to think I could use a 3PDT as opposed to a 3PST just wired differently? PST's are f*ing expensive from mouser while PDTs aren't too bad... |  |
| Back to top |  |
| fonik
|  Posted: Sun Feb 06, 2011 6:18 am    Post subject: |    |
| you are correct. _________________
| Back to top |  |
| tazer
|  Posted: Thu Apr 14, 2011 10:56 am    Post subject:
attenuverting mixer pcb |    |
| please please please can you do a small run of these when you do the 4046 vco pcb run-i would so appreciate that i have been trying to track this pcb down to no avail-I'm sure others would be interested also, my modular isn't complete without it
 I would certainly take a few pcb's of this mixer, see what you can do...............
 many thanks
 Ian
| Back to top |  |
