Joined: Apr 03, 2004 Posts: 24468 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu Dec 30, 2010 2:14 pm Post subject:
BUTT, a streaming tool for win, mac and linux |
EDIT: see http://electro-music.com/wiki/pmwiki.php?n=Radio.BroadcastingInfo for more on how to broadcast on electro-music.com.
MrCold pointed me to a new (FREE ) streaming tool that seems to be capable to replace edcast. It seems suitable for Windows, Linux and Mac. I've tested a bit under Windows Vista, and Cody tried it on Linux - it seems to work.
BUTT
http://butt.sourceforge.net/
then navigate a bit to something like :
http://sourceforge.net/projects/butt/files/butt/butt-0.1.12/
for the windows exe and the mac dmg - the unix source seems to be available directly from the first link. _________________ Jan
Audio files: 297
Posted: Thu Dec 30, 2010 2:19 pm Post subject:
Oh .. and it works with sc_trans too! (just use username:password for the password then). _________________ Jan
DES
Posted: Thu Dec 30, 2010 3:51 pm Post subject:
Good news!
Do you think it safe enough to use for the Streaming Concert? (assuming the initial connection test is ok)? _________________ Dave
www.davesneed.com |
Audio files: 297
Posted: Thu Dec 30, 2010 4:04 pm Post subject:
If you now have edcast up and running and tested with that I'd use edcast .. if you don't have anything yet ... it better be good (the butt thing)
I tested it for maybe 15 minutes, that worked ok. _________________ Jan
DES
Posted: Thu Dec 30, 2010 4:08 pm Post subject:
Makes sense. Edcast is known to work. _________________ Dave
www.davesneed.com |
shanemorris
Audio files: 92
Posted: Thu Dec 30, 2010 6:52 pm Post subject:
looking forward to testing this after nye  _________________ ElectroCasa |
nobody
Posted: Thu Dec 30, 2010 8:25 pm Post subject:
I'll be checking this out, fo shizzle! Anything called "butt" has to be alright... |
Audio files: 297
Posted: Fri Dec 31, 2010 10:19 am Post subject:
For people wanting to experiment with sc_trans, there is an sc_trans testport set up. To connect to it use:
port : 9878
password : public:public
To listen if it works you can tune in to port 8054.
The test port can be used at all times, but only one connection at a time of course. _________________ Jan
nobody
Posted: Fri Jan 07, 2011 7:13 pm Post subject:
BUTT segfaulted when I tried to run the native Linux binary.  |
Audio files: 297
Posted: Fri Jan 07, 2011 8:07 pm Post subject:
There seem to be some issues under windows too, with chipmuks on some audio in selections. Didn't have that myself though. _________________ Jan
nobody
Posted: Sat Jan 08, 2011 10:28 am Post subject:
When I ran it through Wine, I could see the meter bouncing without having put anything through it. Maybe this is the same thing you've heard of. |
nobody
Posted: Sat Mar 19, 2011 10:00 am Post subject:
Will try the Unix source. There's also IDJC, which I've installed but haven't used yet. |
Posted: Fri Jul 15, 2011 11:50 am Post subject:
I've wanted to check out how to setup butt a couple of times. Instinctively I open the "Streaming Radio Station" forum and do a text search for "butt", expecting to find a thread called something with butt. No such luck.
Sure, there are other ways to find this thread, but still - would it be possible to add the magic word "butt" to the subject of this thread, in addition to the rather anonymous and increasingly inaccurate current title? _________________ Antimon's Window
Audio files: 297
Posted: Fri Jul 15, 2011 11:51 am Post subject:
That may me possible .. let mew try. _________________ Jan
Audio files: 297
Posted: Fri Jul 15, 2011 11:53 am Post subject:
It worked :-) _________________ Jan
Joined: Feb 04, 2005 Posts: 2865 Location: Nottingham, UK
Audio files: 278
Audio files: 297
Posted: Thu Sep 22, 2011 6:24 am Post subject:
What do you want to do exactly Jez?
The answer may not be BUTT ... _________________ Jan
Audio files: 278
Posted: Thu Sep 22, 2011 6:41 am Post subject:
I'm not sure exactly what I want to do, but I seem to recall people talking about being able to play files on the server, probably using sc_trans or something, but I don't really know where to look to find info on how this is done _________________ Jez
music | adventures in sound | gear for sale |
Audio files: 297
Posted: Thu Sep 22, 2011 11:07 am Post subject:
You'd do that by creating a playlist on the server, and then set sc_trans to play that playlist. I'll see if there is something written about that in the stream-ops forum, if not I'll write up a lil something. _________________ Jan
Audio files: 278
Audio files: 297
Posted: Thu Sep 22, 2011 3:41 pm Post subject:
Done, it's a sticky in the stream ops forum. _________________ Jan
Posted: Sat Dec 03, 2011 6:38 am Post subject:
Before I go testing my port for NYE 2011, BUTT is still the preferred streaming software right now? Been off the air for a while and out of touch and want to make sure. Also, to make changes to the artist info and picture that appears at the top of the main radio page, where do I go to do that? I use to have a link with a PW to do this.
Thanks for being patient with my questions.
Bill |
Audio files: 297
Posted: Sat Dec 03, 2011 8:25 am Post subject:
BUTT is OK, except on 64 bits windows for some it seems. Also sent you a PM Bill. _________________ Jan
Posted: Sat Dec 03, 2011 10:57 am Post subject:
Quote: | BUTT is OK, except on 64 bits windows for some it seems. Also sent you a PM Bill. |
OK so one last dumb question, I still have Edcast installed and was streaming just fine the last time I used it, can I use that? It is Shoutcast compatable also.
Bill |
