cappy2112
Joined: Dec 24, 2004 Posts: 2501 Location: San Jose, California
Posted: Tue Jan 18, 2011 11:13 am Post subject:
| GovernorSilver wrote: | | buzzr wrote: | I can't afford it right now  |
And the G3 will be affordable? |
Vaporware is always affordable. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Tue Jan 18, 2011 1:09 pm Post subject:
This analog delay pedal is starting to interest me more than the latest iteration of the EHX Deluxe Memory Man:
http://acapella.harmony-central.com/showthread.php?2728614-It-s-official-the-Malekko-Ekko-919-Analog-Delay
Features:
• 40 millisecond to 1.00 second BBD Delay using NOS BBDs.
• Largest dynamic range possible from a BBD Delay using -15V BBD ICs.
• Tap Tempo footswitch control of echo delay time with tempo rate LED.
• Knob control of echo delay time.
• Soft takeover between tap tempo and knob control. Tap the footswitch, its delay time is in control. Move the knob, the knob delay time is in control. Move freely between the two controls.
• True Bypass, Active Bypass and Active “Trail” Bypass, letting you hear the echo trail after switching to bypass mode.
• Mix from 100% Dry, 50/50 Mix to 100% Wet.
• Tone Equalization control.
• Specially tuned flat feedback response to below 100 Hz.
• Excess Feedback includes a limiter in the feedback loop for infinite sustain echo without annoying feedback howl.
• The combination of feedback limiter, tilt tone filter and modulation options make this a wild synthesized tone generator. No input is necessary except a dummy jack to activate the power circuit.
• LFO Speed and Modulation Depth controls and modulation enable switch.
• Wide range of LFO modulation shapes: sine, square, sample & hold and diffusion
• Diffusion is an exclusive mode never before heard from any BBD delay, spreading the sound into a “cloud-like” atmosphere.
• Powered by +9.6 V 500 mA or greater power supply.
Looks like a great candidate for an analog delay that can be used for experimental sounds. _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
GovernorSilver
GovernorSilver
cloudscapes
Posted: Wed Jan 19, 2011 5:11 pm Post subject:
the new Malekko and Eventide definately have my interest!
I've also preordered the teenage engineering OP-1
I've been looking forward to it for years!  _________________ Sonic Crayon DIY effects lab |
Electrica
brontosaurus19
Posted: Thu Feb 17, 2011 1:26 pm Post subject:
| Man, that Ekko 919 delay looks pretty awesome! |
