TekniK
Posted: Fri Mar 04, 2011 4:12 am Post subject:
| My mate told me the layout,yes its abouth the sine shape |
spitfire
Posted: Sat Mar 05, 2011 4:23 am Post subject:
| my sine wave doesn't work at all |
Posted: Sat Mar 05, 2011 5:31 am Post subject:
so if no-one who built itwith ryk's layout wants to chime in, i recommend doing a debug as usual. grab out the original schematic from thomas henry and check the board against it, starting with the sin shaper portion. check all connections and values, transistor orientation an so on. i call this greenlining, since i use a green pen to check off everything on the schematic that is okay. _________________
Tech Buddy at Random*Source |
Badcluster
Posted: Mon Mar 07, 2011 7:19 pm Post subject:
Vco Subject description: Vco |
Fonik can you share your PCB?
Tks |
magneticstripper
Joined: Jan 12, 2009 Posts: 25 Location: San Francisco
Posted: Mon Mar 07, 2011 10:12 pm Post subject:
| There is an error in the sine shaper with the connection of the 10k feedback resistor. |
Posted: Wed Mar 16, 2011 3:22 pm Post subject:
Re: Vco Subject description: Vco |
| Badcluster wrote: | Fonik can you share your PCB?
Tks |
i got a go from thomas! so i will start to work on it. for me i made two layouts, one for the core and one for the waveshapers. i could combine them (which would safe money and logistic efforts), or leave them seperate (which would allow the usage of the shaper for other saw core vco's).
suggestions? _________________
a100user
whomper
Posted: Fri Mar 18, 2011 6:26 am Post subject:
I would very much like to have shapers stand alone as I am looking to add 2-3 shapers to my already crowded modular. _________________ Erez Yaary
Buy my CDs at http://www.mellowjet.de |
Posted: Fri Mar 18, 2011 11:57 am Post subject:
this is how the PCBs look like (without any changes). if most would be fine with them i could make them available next month...
mattias
Posted: Fri Mar 18, 2011 12:13 pm Post subject:
Re: Vco Subject description: save energy |
| fonik wrote: | so i will start to work on it. for me i made two layouts, one for the core and one for the waveshapers. i could combine them (which would safe money and logistic efforts), or leave them seperate (which would allow the usage of the shaper for other saw core vco's).
suggestions? |
I'm selfish and vote for the solution that consumes the least energy of fonik, so he can come up with further cool projects.  _________________ Red is black and plus is minus. http://www.bild-schall.com |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Fri Mar 18, 2011 5:39 pm Post subject:
The way they are now would be good for me.
I second Mattias' sentiments ! |
vtl5c3
Posted: Sun Mar 20, 2011 9:30 am Post subject:
Frikkin Awesome!!! I'll order at least two sets.
| fonik wrote: | this is how the PCBs look like (without any changes). if most would be fine with them i could make them available next month...
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Sun Mar 20, 2011 9:18 pm Post subject:
good enough for me too mathias
will of course also take 2
perhaps a short announcement on your forum page listing a link back to here
for interest to be expressed if it's ok with thomas of course
i almost didn't see it
i think many might be interested and may miss it |
dnode
Posted: Tue Mar 29, 2011 4:10 am Post subject:
I would definitely be interested in two boards! With separate waveshaper boards I would even buy two shapers extra!
Thomas, Scott and Matthias, great work!
grtz, dnode |
Posted: Tue Mar 29, 2011 5:58 am Post subject:
i just came back from a business travel and will take care of this project from now on... _________________
reve
Posted: Tue Mar 29, 2011 11:34 am Post subject:
Awesome!
I'd be in for 2-8 cores depending on price and a couple shapers. _________________ - r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik |
raoulblues
Joined: Oct 31, 2007 Posts: 16 Location: paris france
Posted: Thu Mar 31, 2011 10:47 pm Post subject:
| 2 of each for me as well, thanks Matthias |
spitfire
Posted: Sat Apr 23, 2011 6:56 am Post subject:
hello again.
I get about one octave with my x4046. Is that because I didn't matched the transistors, or because not +-15V, but -+12V, or because my CD4046 is not the right IC ? |
MirlitronOne
Posted: Mon May 02, 2011 5:04 pm Post subject:
Scott, did you ever test the RCA 4046s? Apologies if I missed the results somewhere. _________________ Life is like an analogue sequencer. Twiddle the knobs to avoid boredom. |
Rykhaard
Posted: Thu May 26, 2011 2:28 pm Post subject:
Now that I've come back to designing and building again a few weeks ago, I found the quad PnP printout of the 4046 VCOs of mine. I searched for the error mentioned (in the Sinewave section).
In case it matters to anyone that still has one of their's lying around with the non-working Sinewave output - there's a 10k feedback resistor at the opamp connected to the transistor pair. It's wired between (on the PCB) the + and - pins of the opamp. It should be the - and output pins instead.
As to the error mentioned about the power supply connections to the opamps being incorrect - all of those connections, were just double verified, as correct.
I'll be building at least 1 of these VCOs as well as soon as I finish the alpha version of my Moog 960 sequencer clone / upgrade. (Hopefully within a few days from now.) |
Sebo
Posted: Thu May 26, 2011 4:52 pm Post subject:
Thanks Rykhaard for the update, I etched a PCB from your layout, and will start to build the VCO soon. _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
Aum Generator
Posted: Sat Sep 10, 2011 8:44 am Post subject:
hello everyone
is there some easy way, how to build these with voltage controled SKEW of the rampoid?
( am going to build on fonik's pcbs) |
warpboy
Posted: Tue Oct 04, 2011 8:14 am Post subject:
| Aum Generator wrote: | hello everyone
replace the skew pot by two vactrols.
while the resistane of one vactrol increases the other has to decrease, so you would need additional opamp circuitry to drive the diodes. _________________
