MOTM Blacet Time Machine
Page 1 of 1 [3 Posts]
PrimateSynthesis
PostPosted: Wed May 11, 2011 10:05 am    Post subject: MOTM Blacet Time Machine
Subject description: custom panel with unique mods
Blacet Time Machine in MOTM format
Built on a billet Stooge Industries panel from a Frac Rack PCB and board parts from a Blacet kit, with Bourns sealed conductive-plastic steel-shafts pots, genuine Alco knobs, and Switchcraft jacks.
Functions 100% as designed with the following mods:
Alias knob to control the amount input aliasing, provides original unmodified function at lowest setting. This unit does not have a Bypass switch, but the Bypass jack still functions as a VCA on the wet signal.
Ext/Mod uses switched TRS jack to provide envelope follower output and a third modulation input at the same time, requires use of insert cable, will replace with regular switched jack on request.
Includes Assembly and Users Manual, custom power cable, and a spare LM13600.
$600 plus shipping from U.S.
 Filesize:  211.8 KB
 Viewed:  259 Time(s)
 Filesize:  354.27 KB
 Viewed:  258 Time(s)
 Filesize:  275.89 KB
 Viewed:  249 Time(s)
 Filesize:  296.32 KB
 Viewed:  260 Time(s)
 Filesize:  553.37 KB
 Viewed:  247 Time(s)
Last edited by PrimateSynthesis on Fri May 27, 2011 8:20 am; edited 1 time in total
PrimateSynthesis
PostPosted: Wed May 11, 2011 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just went and edited the description to include that his module uses the Frac Rack PCB, not the 5U PCB. So the assembled board would fit behind a Frac Rack panel if someone really wanted it in Blacet format.
PrimateSynthesis
PostPosted: Fri May 27, 2011 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Price dropped.
