PrimateSynthesis
Posted: Wed May 11, 2011 10:05 am Post subject:
MOTM Blacet Time Machine Subject description: custom panel with unique mods |
Blacet Time Machine in MOTM format
Built on a billet Stooge Industries panel from a Frac Rack PCB and board parts from a Blacet kit, with Bourns sealed conductive-plastic steel-shafts pots, genuine Alco knobs, and Switchcraft jacks.
Functions 100% as designed with the following mods:
Alias knob to control the amount input aliasing, provides original unmodified function at lowest setting. This unit does not have a Bypass switch, but the Bypass jack still functions as a VCA on the wet signal.
Ext/Mod uses switched TRS jack to provide envelope follower output and a third modulation input at the same time, requires use of insert cable, will replace with regular switched jack on request.
Includes Assembly and Users Manual, custom power cable, and a spare LM13600.
$600 plus shipping from U.S.
211.8 KB |
| Viewed: |
257 Time(s) |
354.27 KB |
| Viewed: |
255 Time(s) |
275.89 KB |
| Viewed: |
247 Time(s) |
296.32 KB |
| Viewed: |
258 Time(s) |
553.37 KB |
| Viewed: |
245 Time(s) |
Last edited by PrimateSynthesis on Fri May 27, 2011 8:20 am; edited 1 time in total |
PrimateSynthesis
Posted: Wed May 11, 2011 2:38 pm Post subject:
| I just went and edited the description to include that his module uses the Frac Rack PCB, not the 5U PCB. So the assembled board would fit behind a Frac Rack panel if someone really wanted it in Blacet format. |
PrimateSynthesis
Posted: Fri May 27, 2011 8:20 am Post subject:
| Price dropped. |
