see a message indicating we are on the new server.
Hardware MIDI CLOCK to gate/pulse converter
Page 2 of 3 [61 Posts]
jojjelito
PostPosted: Thu May 12, 2011 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for a couple of PCBs at any rate. My modular gizmo would benefit from this useful addition Cool
Dave Kendall
PostPosted: Thu May 12, 2011 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all.
Can't get the camera to talk to the computer properly, so have recorded a quick audio demo. In this example, The M2C is being used to gate an audio signal via a VCA.
The stage 2 divider toggles are being switched in and out live while the beat is running. A daughter board to allow gate control of the toggle action would seem a logical first add-on I reckon....
It's a rough demo, and simple, but gives an idea of how easy it is to set up rhythms and patterns with the toggles.
More later (when I can get the video done, which looks like it may be a while.....)
M2C DEMO 1.mp3
 Filename:  M2C DEMO 1.mp3
 Filesize:  2.96 MB
 Downloaded:  987 Time(s)
"Everything in moderation, including moderation"
diablojoy
PostPosted: Thu May 12, 2011 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
absolutely orsm and exactly what i hoped it would be like
I think the sync daughter board i have been working on should be able to sync fonik's PWM master clock to this which would be outstanding
I will need to make some output multiples i think Wink
PostPosted: Thu May 12, 2011 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
That demo was great. Thanks for posting it.
What's the eta for the printed boards? No rush since I'm still working on other projects, but I'd like to know when you think they will be ready.
tommi
PostPosted: Fri May 13, 2011 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Great demo! Short but effective. It's even clearer that this module will opens up the road for new special patterns!
http://soundcloud.com/mister-vommi
http://tideofsound.net
brother303
PostPosted: Fri May 13, 2011 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked WANT! Shocked
Please
Best regards
Greg
Dave Kendall
PostPosted: Fri May 13, 2011 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
Mathias is the boss where PC boards are concerned. I think we need to get around 30 or more pre-orders to make it viable, and get the price down to something reasonable. I reckon we have around 10 or so folks who want one so far.....
brother303
PostPosted: Thu May 19, 2011 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
FOOOONIK,can you hear us? Wink
Perhaps ask over at Muffwigglers? Maybe some more folks are interested there...
Edit: Started a thread on this over at Muffs.
Best regards
Greg
rosch
PostPosted: Thu May 19, 2011 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, i better say 2 instead of the previously 1 board.
would be cool to see this happening.
JoeMorris
I would def take one.
bigbluewave
PostPosted: Thu May 19, 2011 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, yes, yes!
I'm up for one of those board for sure!!!
Aaaagh, so many great designs to build already and now another belter...
Top stuff guys, a great collaboration indeed it seems.
Ben
www.bigbluewave.co.uk
emdot_ambient
PostPosted: Thu May 19, 2011 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yeah! As I read through I thought a simple build would be all I need for syncing sequencers to MIDI...now I know a full build is essential.
Definitely in for this one (or two)! Wink
diablojoy
PostPosted: Thu May 19, 2011 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
definitely up for one however
dave just to bring up the question
would 2 or more of these be usefull really in the context of a single modular even a really large modular ?
I was thinking to have a form of buffered multi's on the output to increase the number of outputs to what i would need,
is there an additional benefit to multiple modules that i haven't figured out yet ?
I will need a reasonably good arguement in favour, so i can justify the expense to my wife Laughing
PostPosted: Thu May 19, 2011 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 would be good to divide the rate differently for different devices. You can put me down for 2 now that I think of it. I might only build one right away, but I'm sure I will need the second in the future as I create more lunetta type devices and sequencers.
PostPosted: Thu May 19, 2011 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
now there is some momentum here?
i think we will have to start a list...
diablojoy
PostPosted: Fri May 20, 2011 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm yes i think i can see how that may be preferable to just using other dividers afterward though i can see i will do that also anyway
dave would a midi thru be reasonably easy to implement for chaining a few of these together ? no biggy i do have quite a few spare midi outs on my interface rack still.
mathias i may go to 4 of these possibly now. will need to recheck the budget first though Laughing
PostPosted: Fri May 20, 2011 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
a decent MIDI thru circuitry needs another IC, and the board is rather large already.
Dave already said something about another reason for MIDI thru off: MIDI clocks are woven in the MIDI data stream. So you don't want to use MIDI clock data and other MIDI data on the same output.
For distributing a MIDI clock to multiple instruments a simple multiple would do, i bet.
diablojoy
PostPosted: Fri May 20, 2011 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
yes i just reread that post
i was thinking more along the lines of having one dedicated midi out from my interface rack just for midi clocks rather than say having to use up 4 outputs if i were to build 4 of these modules
was thinking i could do a small add on board . as long as the midi clock data can be accessed . I think dave suggests later on all midi data is available on headers so it shouldn't be a problem just wanted a conformation that it includes the clock data
that would be great but not sure if it would be all that simple.
midi can be horribly finicky especially on longer cable runs
bigbluewave
PostPosted: Fri May 20, 2011 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Erhm,
MIDI is based on a current loop, so you would need to buffer this rather than just split it. The spec of MIDI is also very particular about grounding and to avoid earth loops and hum, hence being an opto isolated current loop.
I'm sure it wouldn't be too tricky to come up with a little distribution circuit if you wanted to send the same clock to several boards, maybe it could be after the MIDI decode, like a master/slave scenario?
Ben
PostPosted: Fri May 20, 2011 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
bigbluewave wrote:
Erhm,
you are correct, ben. nevertheless a simple split works. you do not want to distribute it this way to several instruments over long distances though, right?
Dave Kendall
PostPosted: Fri May 20, 2011 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
If you wanted to distribute MIDI CLOCKS to more than one M2C, a 1-in 4-out MIDI thru box would be the easiest way. That way, The MIDI input only gets buffered and re-sent once.
Diablojoy - the best reason for having more than one M2C, would be that you have one in the rack to clock things with, and another on the test bench for developing new widgets with. Once you have got another set of dividers for instance, you can add them to the rack M2C as an expander module and keep experimenting..... Unplugging it each time an idea comes along would be a pain Wink
As far as outputs go, there is a header on the PCB that carries;
24PPQN CLK
START
STOP
CONTINUE
ACTIVE SENSING - and a couple of others. It can be used without affecting the basic operation of the board. The signals are all fast positive-going +5V signals, and are unbuffered. A CMOS out put has a large fan-out, so could drive quite a few more IC's directly, but as you suggested, it might be a good idea to buffer the signals. A 74HC244 or 74HC245, or their regular CMOS equivalents would probably be good for this.
The good folks on the [sdiy] list pointed me towards some info on DIN-SYNC. It seems a small amount of extra logic would be needed - a 4013 flip-flop or 4027 could perhaps be used to generate the RUN/STOP gates that DIN-SYNC needs.
If Matthias is up for it, should we go ahead with a PCB run?
BTW - Matthias - I'll order one too for the test bench to make new devices with - lots of ideas already Very Happy
brother303
PostPosted: Fri May 20, 2011 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
jackson dancing party time! jackson dancing
Yeah,make it happen!
thanks
Best regards
Greg
emdot_ambient
PostPosted: Fri May 20, 2011 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
flower PCB run would indeed be orsome flower
PostPosted: Fri May 20, 2011 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would suggest another output, along with start/stop/etc, if it's possible to add:
System Message: Song Position Pointer = 0
0xF2 xD1 xD2
If D1 = 0x00 and D2 = 0x00, then the song pointer is set to the beginning. This is VERY useful in synchronizing multiple sequencers DURING PLAYBACK. Most Seq. ignore the START command once playback has begun. (START is also interpreted to reset the song pointer). This can then be used to reset sequencers, LFOs, OSCs, etc in the analog realm.
Maybe you can recognize Song Pos Pointer, and toggle Start again?
wmonk
Audio files: 15
PostPosted: Fri May 20, 2011 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Certainly one pcb for me. Excellent project guys! Smile
I've been waiting for this. Cool
I could provide part kits for those who want that, if you, Dave and Matthias, agree on that.
Woody
Weblog!
