overdrive/distortion tips
Page 1 of 1 [17 Posts]
cebec
G2 patch files: 31
PostPosted: Fri Feb 11, 2005 2:13 pm    Post subject: overdrive/distortion tips Reply with quote  Mark this post and the followings unread
i'm still hanging on to my distortion pedals since I really like the range, grit, and hands-on-ness of an analog pedal.
however, i'm always trying to come up with another way to shape or distort an audio signal in the digital realm. besides chaining shapers or just adding MORE of something, e.g., more gain, more bass/mid/treble, i'm stumped as to any other implementations or tweaks.
i've looked at Rob's OD patch and he uses a technique that I don't understand just by staring and following cables around. and even though I have the patch, i don't know where it came from or where a description of it's workings might be.
can anyone offer patches or tips on achieving different types of both harmonic and nonlinear distortion and overdrive using the G2s shapers or other less obvious modules? anything out of the ordinary is most welcome!
if you come up with something, post it over in the building blocks section Wink
thanks in advance...
Audio files: 235
PostPosted: Fri Feb 11, 2005 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
The frequency shifter and the pitch shifter modules are fabulous and these are effects you won't find in stomp boxes. The ring modulator (multiplier) is great too. Be creative, just put stuff in and play with the knobs. You'll discover great stuff.
If you put monophonic audio into the pitch follower module, it works really well.
mother misty
G2 patch files: 130
PostPosted: Tue Feb 22, 2005 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm really interested in this stuff aswell, especially harmonic distortion... anybody got some tips?
ik
G2 patch files: 25
PostPosted: Tue Feb 22, 2005 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
... using the G2s shapers or other less obvious modules? anything out of the ordinary is most welcome ...
Two quick notes:
1)
y=tanh(x) gives nice overdrive curve. One of the pre-made shapers may already have that, not sure. It is possible to approximate tanh(x) but one needs use a (I think) Taylor polynom ... I'll look into that.
2)
Clavia included 1-(1-x)^2 and 1-(1-x)^3 curves and they called them
Inv x2 and Inv x3.
A simple experiment could be to try y=1-(1-x)^4 or even higer....
It is simple to generate these curves, and just experiment with them.
ik.
mother misty
G2 patch files: 130
PostPosted: Tue Feb 22, 2005 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks ik!
(some new stuff to try out tonight too much coffee )
ik
G2 patch files: 25
PostPosted: Tue Feb 22, 2005 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
... some new stuff to try out tonight ...
Just a note:
For negative x values you need to multiply the output by -1.
So, the way to do it, get y=f(abs[x]), then monitor the x input,
and multiply y by 1 for positive input and by -1 for negativ input,
so to get the curve symmetrical.
ik.
cebec
G2 patch files: 31
PostPosted: Tue Feb 22, 2005 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi!
could you post some examples? maybe in the building blocks section? the math is over my head, i'm afraid...
ik
G2 patch files: 25
PostPosted: Tue Feb 22, 2005 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a "workbench" to try these things ...
Use only the 'yellow marked' units for tweaking.
Inv x2, Inv x3, Inv x4, and Inv x5 calcd. (more blocks could be added ...)
In addition ShpStatic is there to compare Inv x2 and Inv x3.
Feed either with constant signal (to monitor values) or audio (to hear) the outputs.
In addition a "peak catcher" added to memorize min and max values.
You need to copy/paste the actual unit into a patch to hear any "musical".
ik.
dist bench.pch2
calcd. Inv x2 ... Inv x5 distortion. (+ some extra to monitor the signals)
 Filename:  dist bench.pch2
 Filesize:  1.89 KB
 Downloaded:  1444 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Tue Feb 22, 2005 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
A few tips:
1. Try using different types of distortion on different sections of the audio spectrum - run the signal through a multimode filter and connect the HP, BP, and LP outs to three different types of distortion circuits (maybe a shaper module for the lows, an overdrive for the mids, and a clipper with feedback mixer for the highs) and then mix all of these back together.
2. In addition to controlling the amount of distortion (like the the amount control on an overdrive module), add a crossfader to control the MIX of distorted vs. clean signal.
3. Play around with asymetrical distortion - where the positive half of the wave gets distorted differently from the negative half. To do this, you can use a set of diode modules to split the upper & lower halves of the wave, or connect the audio wave to both the audio input and the control input of a panner module. This will "pan" the positive half to one output and the negative half to the other output. Try leaving one half undistorted and running the other half through a shaper or whatever, then mix the two halves back together.
4. Place the distortion in different points along the audio path - the CVA, the poly area, before & after a phaser, before & after the filter, etc. One neat idea for making a nicely distorted 24dB filter - use a pair of 12dB filters in series, and put the distortion in the middle, between the two filters.
I made some NM1 example patches a while ago, which should be in an archive. Check out "EXT UpToEleven.pch" and some called '12dB filter flavors' and '24dB filter flavors'.
Dave Peck
jksuperstar
G2 patch files: 18
PostPosted: Tue Feb 22, 2005 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
On a related note, is there a way to selectively filter only even or only odd harmonics? Much of the "Tube Warmth" comes from a fundamental difference in the way tubes handle odd harmonics.
Audio files: 309
PostPosted: Tue Feb 22, 2005 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could probably use a comb or a phase filter, but it might be easier to selevctiively generate the wanted harmonics rather than suppressing the unwanted ones. For generation the templates posted up a bit from here by ik might be usefull (from theory, I didn't try 'm yet).
Jan.
Audio files: 309
PostPosted: Tue Feb 22, 2005 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some other things to try :
A string oscillator can be used as a resonator.
A percussion osc trigered at audio rates gives a rich spectrum, read : nice dirt.
An oscillator set to zero Hz with audio connected to a phase or linear FM input .
Jan.
mother misty
G2 patch files: 130
PostPosted: Wed Feb 23, 2005 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering...
Would it be possible to make something like a 'harmonic splitter'?
(a module with an input and several outputs for the harmonics)
Would be very usefull (maybe something for the whishlist Smile
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed Feb 23, 2005 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
I was wondering...
I've done this using the band pass outputs of a group of 12dB multimode filters with high resonance settings. You need to set the filter keyboard tracking to 100% so that the filters accurately track the oscillator pitch and always pass the proper harmonics.
BTW, this trick really works! Sending only the 2nd & 4th harmonics through a saturator module & then mixing them back into main signal sounds very nice!
Dave Peck
Chet
G2 patch files: 35
PostPosted: Mon Feb 28, 2005 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's an FX patch that duplicates the Saturator module in NI Reaktor. When the input is zero, the gain is 1. As the input increases to 1, the gain is reduced in a linear manner from 1 to 1/2. As the input increases past 1, the output remains limited to 1/2.
ReaktorSaturator.pch2
 Filename:  ReaktorSaturator.pch2
 Filesize:  1.25 KB
 Downloaded:  1550 Time(s)
cebec
G2 patch files: 31
PostPosted: Mon Feb 28, 2005 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this patch 605.3 % for the VA Cycles and 7.0 % for Memory for anyone else!?
Audio files: 309
PostPosted: Mon Feb 28, 2005 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes it is for me as well .. nice one for Clavia ...
Not withstanding the overload it does seem to work ...
Jan.
