The site will be down to cut over to a new server on Tuesday, May 26, at 10 PM EDT (May 27, at 2 AM GMT)
We will be down for about 2 hours. Check back and you see a message indicating we are on the new server.
Posted: Wed Jul 06, 2011 9:38 pm Post subject:
My CMOS/Lunetta challenge digital logic sound making machine Subject description: (pic heavy with descriptions of circuits <--- Added more notes)
This is the sound making thing I made using the random assortment of CMOS chips from Electronic Goldmine. As you know, the IC assortment included 25 CMOS chips. I selected 6 of them and built the below.
In addition to a photo, I wanted to include my notes so that anyone just starting out could easily build these circuits (and modify or improve them!).
The chips I used are:
MC14069UBCP Hex Inverter (x2)
MC14040BCP 12-Bit Binary Counter (x1)
CD4020BE CMOS 14-Stage Ripple-Carry Binary Counter/Divider (x1)
CD4019BE CMOS Quad AND/OR Select Gate (x2)
The 1st panel includes 5 oscillators (1 high, 2 mid, 2 low) using the 4069 ICs.
The 2nd panel includes 2 frequency dividers using the 4040 and 4020 ICs.
The 3rd panel includes a bunch of logic gates using 2 4019 ICs. Also, there is a 3 input resistor mixer and 3 input diode mixer.
The 4th panel includes 2 filters using 2 inverter gates from the 4069 IC in panel one. There is also a passive mixer with volume control and an output jack.
This was a really fun project to work on and I'm going to continue with my remaining chips (I've already started building the 2nd case). I'm also looking forward to seeing what other people are building with their assortments (a few of the chips have me stumped, and I need ideas!).
Filesize:
153.06 KB
Viewed:
469 Time(s)
Filesize:
108.35 KB
Viewed:
521 Time(s)
Filesize:
130.65 KB
Viewed:
531 Time(s)
Thanks for sharing, it's great to see the entire process and not just the end product(wich looks amazing).
one question though...what does it sound like? _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson movies noise
excellent work and documentation! thanks for sharing. I second tjookum; how about some video/audio? how do those filters sound? _________________ http://www.youtube.com/user/borisandfef
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
Posted: Thu Jul 07, 2011 4:56 pm Post subject:
Great work there man! I have built panels for a 4052 as well as a 4512 but they just HAD to go into my current lunetta . Will be working on my project hopefully in a week after my back heals up.
Looking forward to a clip soon! _________________ Zontar Prevails!
The 4020 and 4040 are very similar. The 4020 has 14 stages while the 4040 has only 12. The 4020 does not have a divide by 2 or a divide by 4 stage, but it does go lower (all the way down to divide by 8192).
I just shot a quick video today in an attempt to demonstrate the filter. The sound is very low on this video so keep an eye on the oscilloscope to see how the filter changes the square wave as I adjust the 2 pots.
The pot on the left is VR1 in the above schematic and controls how much input enters the filters inverter. The pot on the right is VR2 which controls the resistance to ground.
Posted: Fri Jul 08, 2011 11:04 am Post subject:
Nice Work! Those are some interesting waveforms your getting for such a simple set up.
I see you are using CMOS in linear mode for the filters. Do you happen to know what the current draw is for the whole circuit? I always thought they would draw to much current to use in battery powered devices.
That is a nifty little scope. Are you happy with it? I'm in the market for a new scope and the size of that one is very appealing. Where did you pick that up?
Thanks for sharing, this is good stuff.
More vids please!
The scope is a DSO Nano that I picked up at the Maker Faire. You can also buy it online for around $100. I've been very happy with it as it is very small, uses a rechargeable battery and is open source so you can even upgrade the firmware. It was very helpful in building CMOS oscillators and filters.
I didn't have to calculate the oscillator frequency because the DSO Nano has a frequency display.
I don't know how much current the filter draws as that is not something I measured. I'm using a single 9 volt battery for power (with a 7805 voltage regulator).
The filter was actually the most fun part to build. Using the scope was very helpful in seeing how replacing various components effected the filters response. I'm sure the filter can be improved upon. I'd like to build a version that can be modulated by other sources as opposed to just using the 2 pots.
Joined: Jun 11, 2010 Posts: 116 Location: Northampton, UK
Posted: Sat Jul 09, 2011 1:09 pm Post subject:
Thanks Sndbyte - that is really helpful. Good of you to go to the trouble of scanning and posting your notes. Gives a great insight into what's going on and how and why. I shall be going over them making sure I understand at least a fair proportion of it.
I have a couple of 4001s and 3 4011s so have the potential for 20 inverters just in those 5 chips. Gives me some oscillators, amplifiers and filters. I'm almost tempted to see what I could do with just a handful of 4001s!
Ian
I just finished using the chips from my grab bag (actually, I used at least one of each type in my bag, there were a number of duplicates). Anyhow, here are 2 photos of the thing below. I'm also going to scan my notes so you can see how I made the circuits. I'll post a video once I get my order of banana plugs. I need to make some longer patching cords now that I have 2 units.
Filesize:
161.09 KB
Viewed:
293 Time(s)
Filesize:
200.62 KB
Viewed:
411 Time(s)
Im very impressed, you really took on the challenge and made it into a succes.
And thanks so much for sharing your findings, I don't have the time right now but I'll definately look into them later.
and where did you get that sketchbook? It looks like an excellent tool for putting down ideas. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
I'm impressed too, very nice work sndbyte. Like your Lunetta and am looking forward to hearing something from it. Also impressed with your notebook - I've always wondered how people can create such nice neat and tidy notes and drawings.
The notebook I'm using is the Maker's Notebook. I got it for free when I bought my DSO Nano at the Makerfaire. I'm pretty sure you can buy the notebook in the Maker Shed. The cool thing about it is that the last 20 pages or so of the notebook is all sort of reference material (including resistor & capacitor codes, ohm's law, etc).
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Thu Aug 25, 2011 2:37 am Post subject:
Will be devouring your notes when i get a chance, many thanks for posting.
Still cant believe how quickly you threw together a basic modular system (with panels) from some random parts. I have some overlapping parts, which i (quite honestly) haven't got a clue what to do with, so as part of the learning experience, will 'cheat' and look at how you've done things.
Many thanks
Ben
Thanks, that is why I posted the notes... so people could breadboard them, test the circuits out and even improve on them. That's pretty much how I learned how to build these things, by looking at what other people had made here in the forum. For example, the 4503 chip. I had no idea what I was going to do with it. I got the idea for using it as a signal gate from the posting that Brock made on the original Challenge thread. He also posted a schematic which really made it clear how the circuit worked. I found that to be very helpful.
Posted: Wed Aug 31, 2011 1:39 am Post subject:
Well, I started yesterday after much faff. Built a mini amp and test leads to hear it first, to save croc clips, was my first boxed up project, interesting in itself, fitting in all the jacks and pots was interesting, and figuring out the wiring for an indicator LED.
Anyway, then spent about 2 hours trying to get a nand oscillator to work, but failed miserably. So decided to go thru your notes in detail. Theyre amazing, like a mini text book, so helpful. I found it very useful to rewrite them all out myself, with additional notes and variations. Finally last night got all three oscillators working on the breadboard, a feat in itself. But really useful for someone like me whos new to all this. By the third i got it built really quickly. And started to get loads of ideas. Like switched jacks for inputs and outputs, so you have a nomalised synth, unless you want to plug in other things for modulation etc. Also found a 4011 ring mod schematic on here which i now have 1 of (had two but broke a pin off ! )
Could be a really useful little box when finished, and for peanuts !
So yeah, thanks again for all the notes, going to solder up the oscillators tonight and/or move onto the low pass filter.
Posted: Wed Aug 31, 2011 8:46 am Post subject:
Hi Sndbyte, also a couple of queries if i may please.
I notice your using 5v rather than 9v, any reasons for this? Im just using a battery at this stage, although i do have a 7805 at home, could use that.
Also, for the oscillators, i notice R2 and what ive assumed is an LED (could be LDR?) connected to ground. Circuit seems to work fine with LEDs, so i assumed its that, with a current limiting resistor. Is this purely for visual representation of the speed of each oscillator? I guess i could remove these then?
