_kla_
Posted: Thu Aug 11, 2011 5:07 am Post subject:
nord modular G2 editor DEMO Subject description: Not enough memory to perform requested action. |
Hi all,
after installing Nord Modular G2 editor DEMO, i get an "Not enough memory to perform requested action".
I'm using my new laptop, win7 64bit, 2,5 GHz and 4,00 GByte RAM (3,90 usable...).
on "setup - audio/midi" I'm getting the same message.
does anybody seen this problem?
thank you.
regards
kla |
Joined: Apr 03, 2004 Posts: 24451 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu Aug 11, 2011 6:22 am Post subject:
Others have reported that too, yeah, there are some posts around here dealing with the subject - not too long ago even. I think it had to do with certain audio drivers, you can try to disable 'm one by one to see if you can find an offender. _________________ Jan
_kla_
Posted: Thu Aug 11, 2011 8:05 am Post subject:
it's "idt high definition audio codec".
... if I disable the driver, the editor will work ... but audio is not active  |
Audio files: 297
Posted: Thu Aug 11, 2011 9:20 am Post subject:
Oh .. and _kla_ BTW
I dont think a solution was presnted in that other thread, just using another audio interface there IIRC ...  _________________ Jan
Posted: Thu Aug 11, 2011 9:28 am Post subject:
Guys, I wouldn't bother anymore. The g2 demo is deadware IMO. Rally behind the brilliant SONIGEN modular instead!
http://www.sonigen.com/
Maybe Clavia will do the right thing and buy these guys up?  _________________ ACHTUNG!
Audio files: 297
Posted: Thu Aug 11, 2011 10:13 am Post subject:
Deadware, have you brittons all gone nuts
I use the thing daily & I love it  _________________ Jan
Audio files: 297
Posted: Thu Aug 11, 2011 10:14 am Post subject:
But that sonigen thingie is promising! _________________ Jan
Posted: Thu Aug 11, 2011 11:03 am Post subject:
Yes deadware. And it's been deadware for a long time. (or at least it has if you either have a Mac or only a cheap PC. (I have both).
Sonigen's developers hope to support both platforms, and you can use it with an external keyboard. The latter is a good enough reason to support Sonigen, because let's face it, the G2 demo can't be used with MIDI at all.  _________________ ACHTUNG!
Audio files: 297
Posted: Thu Aug 11, 2011 11:40 am Post subject:
v-un-v wrote: | because let's face it, the G2 demo can't be used with MIDI at all.  |
I do use it with MIDI ... _________________ Jan
Posted: Fri Aug 12, 2011 12:10 am Post subject:
Really???
I've never had it going with MIDI!
It still doesn't work on my Mac though as well as it works on a PC  _________________ ACHTUNG!
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Fri Aug 12, 2011 1:06 am Post subject:
Yes, go to Setup, choose Audio/Midi and select your midi controller/keyboard. |
Roland Kuit
G2 patch files: 127
Posted: Fri Aug 12, 2011 1:15 am Post subject:
Hi Kla, I had that problem too, after having a new mother board installed. I was realy going nuts about this problem. In the end I updated the audio drivers and that worked. I use a RealTek high end btw. But the free Asio4all driver will work fine too. I use Vista. Last edited by Roland Kuit on Fri Aug 12, 2011 1:32 am; edited 1 time in total |
_kla_
Posted: Fri Aug 12, 2011 1:29 am Post subject:
v-un-v wrote: | Guys, I wouldn't bother anymore. The g2 demo is deadware IMO. Rally behind the brilliant SONIGEN modular instead!
Maybe Clavia will do the right thing and buy these guys up?  |
thank you! very good stuff!
silly question number 1: does it work only by midi? i have no problem to use it but I want to use this emulator as virtual modulator: to learn and try.
It could be more easy to use a virtual keyboard...
thanks a lot |
_kla_
Posted: Fri Aug 12, 2011 1:32 am Post subject:
roland kuit wrote: | Hi Kla, I had that problem too, after having a new mother board installed. I was realy going nuts about this problem. In the end I updated the audio drivers and that worked. I use a RealTek high end btw. But the free Asio4all driver will work fine too. I use Vista, |
Thanks
Ther is something strange in mt audio dirver... if I disable the audio driver "idt high definition audio codec", the editor will work ... but audio is not active.
There are no update driver for my audio stuff. I should have more experiments
regards |
Roland Kuit
G2 patch files: 127
Posted: Fri Aug 12, 2011 1:38 am Post subject:
Kla, when you disable the audio driver, there is no sound. My settings are (MME)speakers(Realtek High Def). But the free Asio4all driver will do the job too. |
Audio files: 297
Posted: Fri Aug 12, 2011 6:39 am Post subject:
v-un-v wrote: | It still doesn't work on my Mac though as well as it works on a PC :evil: |
True that, it eats into the processor a bit ... _________________ Jan
BobTheDog
Posted: Sat Aug 13, 2011 12:04 pm Post subject:
Blue Hell wrote: | Deadware, have you brittons all gone nuts
I use the thing daily & I love it  |
Don't worry, some of us are still sane here. |
BobTheDog
Posted: Sat Aug 13, 2011 12:05 pm Post subject:
Blue Hell wrote: | But that sonigen thingie is promising! |
Only for Windows users though  |
Posted: Sun Aug 14, 2011 2:22 am Post subject:
Why are you complaining? I thought you'd rather have a red hot poker shoved up your arse than face an Apple computer?!  _________________ ACHTUNG!
Roland Kuit
G2 patch files: 127
Posted: Sun Aug 14, 2011 3:56 am Post subject:
Be flexible  |
BobTheDog
Posted: Sun Aug 14, 2011 4:10 am Post subject:
v-un-v wrote: | Why are you complaining? I thought you'd rather have a red hot poker shoved up your arse than face an Apple computer?!  |
\No it's only iShit development I hate |
SoulState
Posted: Mon Jul 20, 2020 2:16 am Post subject:
Sonigen is deadware for now too...  |
