today> Twyndyllyngs Chez Mosc
nord modular G2 editor DEMO
Page 1 of 1 [22 Posts]
_kla_
PostPosted: Thu Aug 11, 2011 5:07 am    Post subject: nord modular G2 editor DEMO
Subject description: Not enough memory to perform requested action.
Hi all,
after installing Nord Modular G2 editor DEMO, i get an "Not enough memory to perform requested action".
I'm using my new laptop, win7 64bit, 2,5 GHz and 4,00 GByte RAM (3,90 usable...).
on "setup - audio/midi" I'm getting the same message.
does anybody seen this problem?
thank you.
regards
kla
Audio files: 321
PostPosted: Thu Aug 11, 2011 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Others have reported that too, yeah, there are some posts around here dealing with the subject - not too long ago even. I think it had to do with certain audio drivers, you can try to disable 'm one by one to see if you can find an offender.
_kla_
PostPosted: Thu Aug 11, 2011 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
it's "idt high definition audio codec".
... if I disable the driver, the editor will work ... but audio is not active Sad
Audio files: 321
PostPosted: Thu Aug 11, 2011 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh .. and welcome _kla_ BTW
I dont think a solution was presnted in that other thread, just using another audio interface there IIRC ... Crying or Very sad
PostPosted: Thu Aug 11, 2011 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Guys, I wouldn't bother anymore. The g2 demo is deadware IMO. Rally behind the brilliant SONIGEN modular instead!
http://www.sonigen.com/
Maybe Clavia will do the right thing and buy these guys up? Very Happy
ACHTUNG!
Audio files: 321
PostPosted: Thu Aug 11, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Deadware, have you brittons all gone nuts Shocked
I use the thing daily & I love it Confused
Audio files: 321
PostPosted: Thu Aug 11, 2011 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
But that sonigen thingie is promising!
PostPosted: Thu Aug 11, 2011 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes deadware. And it's been deadware for a long time. Evil or Very Mad (or at least it has if you either have a Mac or only a cheap PC. (I have both).
Sonigen's developers hope to support both platforms, and you can use it with an external keyboard. The latter is a good enough reason to support Sonigen, because let's face it, the G2 demo can't be used with MIDI at all. Exclamation
ACHTUNG!
Audio files: 321
PostPosted: Thu Aug 11, 2011 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked I do use it with MIDI ...
PostPosted: Fri Aug 12, 2011 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Really???
Shocked Embarassed
I've never had it going with MIDI!
Embarassed
It still doesn't work on my Mac though as well as it works on a PC Evil or Very Mad
ACHTUNG!
Roland Kuit
G2 patch files: 127
PostPosted: Fri Aug 12, 2011 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, go to Setup, choose Audio/Midi and select your midi controller/keyboard.
Roland Kuit
G2 patch files: 127
PostPosted: Fri Aug 12, 2011 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Kla, I had that problem too, after having a new mother board installed. I was realy going nuts about this problem. In the end I updated the audio drivers and that worked. I use a RealTek high end btw. But the free Asio4all driver will work fine too. I use Vista.
_kla_
PostPosted: Fri Aug 12, 2011 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you! very good stuff!
silly question number 1: does it work only by midi? i have no problem to use it but I want to use this emulator as virtual modulator: to learn and try.
It could be more easy to use a virtual keyboard...
thanks a lot
_kla_
PostPosted: Fri Aug 12, 2011 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
roland kuit wrote:
Hi Kla, I had that problem too, after having a new mother board installed. I was realy going nuts about this problem. In the end I updated the audio drivers and that worked. I use a RealTek high end btw. But the free Asio4all driver will work fine too. I use Vista,
Thanks Smile
Ther is something strange in mt audio dirver... if I disable the audio driver "idt high definition audio codec", the editor will work ... but audio is not active.
There are no update driver for my audio stuff. I should have more experiments
regards
Roland Kuit
G2 patch files: 127
PostPosted: Fri Aug 12, 2011 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Kla, when you disable the audio driver, there is no sound. My settings are (MME)speakers(Realtek High Def). But the free Asio4all driver will do the job too.
Audio files: 321
PostPosted: Fri Aug 12, 2011 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
It still doesn't work on my Mac though as well as it works on a PC :evil:
True that, it eats into the processor a bit ...
BobTheDog
Audio files: 32
PostPosted: Sat Aug 13, 2011 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry, some of us are still sane here.
BobTheDog
Audio files: 32
PostPosted: Sat Aug 13, 2011 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only for Windows users though Sad
PostPosted: Sun Aug 14, 2011 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Why are you complaining? I thought you'd rather have a red hot poker shoved up your arse than face an Apple computer?! Rolling Eyes Laughing Laughing
ACHTUNG!
Roland Kuit
G2 patch files: 127
PostPosted: Sun Aug 14, 2011 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Be flexible Wink Smile
BobTheDog
Audio files: 32
PostPosted: Sun Aug 14, 2011 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
\No it's only iShit development I hate
SoulState
PostPosted: Mon Jul 20, 2020 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Sonigen is deadware for now too... Sad
