sympleSEQ -- the simple to build analog step-sequencer [PCB]
Page 2 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 11, 12, 13 Next
emdot_ambient
PostPosted: Fri Aug 26, 2011 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the update. At least Reset's a go. I'm sure the answer for stop/start will come to you.
I'm already thinking about a 19" wide panel...2 rows of 16 steps each...plenty of room for jacks and other stuff like dividers and sequential switches. too much coffee
ericcoleridge
PostPosted: Fri Aug 26, 2011 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
HexInverter wrote:
You could cut traces on the board and do some hacking to make it output a different one per step, yes, but then you would have a different output jack for each step. Am I understanding what you're asking? Smile
Yep, that's what I was asking. I suppose if you (or I) were to do this--one might also want to buffer each output---yes?
HexInverter
PostPosted: Fri Aug 26, 2011 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're very welcome! I think I've got it...just gotta meditate on it a bit more and make 100% sure it is okay. Then check and triple check that I've got it right before making the final board revision.
Eep...just to be clear, the sympleSEQ is NOT able to be scaled step-wise out of the box -- only channel wise. In other words, only 2-8 steps are possible, but you can chain many to the same clock to run at the same time. That is more than once now that someone misunderstood that. I should really change the wording I think -- I think people are interpreting it differently than I mean. Me and my crazy usage of words Sad
You could try and make them 16 steps yourself, but that would be a modification you would have to do on your own. Sorry if it was not clear.
HexInverter
PostPosted: Fri Aug 26, 2011 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, any output should be buffered, as far as I know Smile I think I am missing why you might want to do have a different output per step, though?
emdot_ambient
PostPosted: Fri Aug 26, 2011 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
HexInverter wrote:
Eep...just to be clear, the sympleSEQ is NOT able to be scaled step-wise out of the box -- only channel wise. In other words, only 2-8 steps are possible, but you can chain many to the same clock to run at the same time...You could try and make them 16 steps yourself, but that would be a modification you would have to do on your own...
I actually did understand that (though in one of my replies I got confused on the issue a bit). thumb up
HexInverter
PostPosted: Fri Aug 26, 2011 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay! Smile Good stuff -- just want it to be very clear that those modifications will not be documented or included.
You are more than welcome to do them yourself however, and I would reckon it will become a lot clearer once I have released the schematics! Which I AM working on -- just ironing out the kinks in the reset/stop circuitry as we speak. I think it should be just fine Smile
HexInverter
PostPosted: Fri Aug 26, 2011 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: It would appear as though we have pause/stop and reset functionality, now! Smile
A few hours at the breadboard, some resistors, diodes, a pair of caps for switch debouncing and an unused inverter net us switchable and/or externally triggerable pause and reset!!!
When you apply a +V signal to the pause/stop/start, it holds on the current step, and the gate turns off. The clock continues to run, but the gate sends no output, so I do NOT recommend using this sequencer as your main clock source if you plan on syncing it with other stuff and want to stop all of it at once (but then again, why would you be if you're using the features of a better sequencer to provide reset/pause signals? Smile ) Once the pause goes back to GND, the sequencer continues as normal and the gate begins to fire once again!
The reset works just fine as well. It is switchable, or you can input +V to a jack. As long as it stays at +V, the sequencer sits at the first step, and the gate provides no output. Once the input goes low, it continues to step forwards as usual and the gate begins to output again.
To make this work ended up requiring a bit more in the way of board modifications than I had hoped, so it will become a base-feature more than likely. The switches will NOT be included however; only the jack function, as having switches is considered not necessary in my opinion. Of course it is still optional whether or not you actually assemble the function -- it will not harm anything to just leave the jacks unconnected and omit them from your panel layout Smile
HexInverter
PostPosted: Fri Aug 26, 2011 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I'd pop in to share some sounds! I know it's not a video, but hopefully it'll tide ya over until I can borrow a video camera next week Smile
It is driving the sympleSYNTH voice (another project being worked on) -- a super simple VCO/AR on one board. Hence, it is not pure analog goodness, but you get the idea.
One sympleSEQ is driving the voice, and the other is providing cutoff modulation for the MFOS State Variable VCF (old design)
http://soundcloud.com/hex-inverter/symplesynth-w-sympleseq-and
diablojoy
PostPosted: Fri Aug 26, 2011 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats really good to hear Smile
I will continue with working on a way to chain these but in the background hopefully with up to 64 steps available eventually
If I come up with anything viable i will post in a new topic so as not to cloud this one any further.
cheers
HexInverter
PostPosted: Fri Aug 26, 2011 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers
Yay Smile Sounds good to me! ^_^
LektroiD
PostPosted: Sun Aug 28, 2011 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I would love a couple of these when it becomes available Cool
HexInverter
PostPosted: Sun Aug 28, 2011 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Well, they're going to be shipping around the end of November, as the funding campaign ends October 24th, and then I have to get everything ordered and hand assemble everybody's kits. The boards take pretty much exactly a month from the time I place the order to arrive at my door, and by that time all of the components should definitely be here.
But, the project is not going to happen at this price if enough is not contributed to meet the minimum order numbers to meet the quantity discounts I have assessed the costs at (100 boards, 1000 potentiometers), so if you feel like, your early contribution on Indiegogo will very much help fund the project! Very Happy
No rush -- like I said, there are still 58 days left, and we're already at $350 out of $2800 Smile
Here's the link in case you missed it!
http://www.indiegogo.com/sympleSEQ
HexInverter
PostPosted: Mon Aug 29, 2011 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: Bill of materials is posted, thanks to Google Docs (no sign in necessary of course - link below!)
https://docs.google.com/spreadsheet/ccc?key=0AvD8ZRA_UZL8dEFER2dMWXFmVWs5cE11ZnYyVF9LVnc&hl=en_US
LektroiD
PostPosted: Tue Aug 30, 2011 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
the link doesn't work?
HexInverter
PostPosted: Tue Aug 30, 2011 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting...it definitely just worked when I clicked it. Maybe your browser doesn't like the capital letters? Try this other version:
http://igg.me/p/40073?a=227451&i=shlk
emdot_ambient
PostPosted: Tue Aug 30, 2011 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
It's the BOM link that doesn't work for me.
HexInverter
PostPosted: Tue Aug 30, 2011 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Weird...it worked fine for me just now, and I double checked that it's public on Google Docs!
Here's a .PDF copy of the Google Doc in any case.
sympleSEQ_BOM.pdf
 Filename:  sympleSEQ_BOM.pdf
 Filesize:  66.44 KB
 Downloaded:  244 Time(s)
HexInverter
PostPosted: Tue Aug 30, 2011 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: I have successfully re-designed the logic board to be exactly 41mm wide, just like the control board! This means people using MOTM/synthesizers.com formats can place a sympleSEQ vertically in 1U wide panel space! Very Happy
Beta build #2 will be under-way soon, and then I will have some new pictures for all to see, and a video as well Smile
HexInverter
PostPosted: Fri Sep 02, 2011 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have just uploaded the tentative final schematics to my web-space for those that are interested to view!
This should be the final design and will be tested with a prototype PCB in the coming weeks before project completion!
You can find it here (scroll down):
http://hexinverter.net/?projects=sympleseq-v10
PostPosted: Sat Sep 03, 2011 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
good idea to do a PCB for a simple 4017 sequencer!
i would be in for a couple of sets of PCBs if you would add a trigger output (using AND gate to create them from the incoming clock and the summed gates), like i did for the VCPS-8. feature creep, i know Laughing
HexInverter
PostPosted: Sat Sep 03, 2011 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
It is almost a trigger output already, though -- the gate and clock are being ANDed and form a 1/3 clock pulse output that ends before the next note occurs. This way, you can make use of an envelope generator unlike a lot of easy sequencers which simply tie the notes together.
Does that help? Razz
PostPosted: Sat Sep 03, 2011 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i like the triger lenght following the clock pulse width actually, however, having a trigger per step is the main point. so your solution will not be a showstopper for me.
the main reason i would like to have a couple of PCB sets are the on-board potentiometers... Cool
HexInverter
PostPosted: Sat Sep 03, 2011 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hehe, yeah, the PCB mount pots are really the selling point of this project -- 'tis what I designed it for! Smile
PS: I thoroughly enjoy your PCB work, Fonik. I am flattered that you are interested in my work ^_^
Sorry there is no trigger out Sad You could always just build a very simple gate->trigger converter on a piece of strip/vero-board and switch between that and gate yourself pretty easily!
HexInverter
PostPosted: Sun Sep 04, 2011 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Since it's been a little quiet, I decided to take some time to create graphical renderings of the new board layouts Smile
This should be the final revision before production, and I will be prototyping it once my parts get here!
Still $2,375 in funding to go! Share the link with people you might think would like to hear about it to help out Smile I have yet to get a response from Getlofi.com Sad
I've also submitted to some other blogs which have ran with it, but if anybody else can think of other places, do let me know!
synthesist
PostPosted: Mon Sep 05, 2011 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I never bought a pcb cause for me it's not really DIY if I dont build on a stripboard. But this will be my first one, cause the last time I tried to build a baby 8 sequ, I almost died hanging myself with wires...
I would be interested in a double set that fits one a euro rack.
But I dont understand the difference between the "full component kit" and the "minimal kit". Does it contain the same components and the only difference is that you have to mount pots and switches on the board?
NOTE: Every kit contains a set of PCBs of course! -- the only difference is in the components included.
1.) Full component kit -- for new (or lazy) builders
Contents:
- One set of sympleSEQ PCBs
- All of the necessary components required to electrically build the sympleSEQ, including board mount switches, potentiometers, hardware to mount the board and the headers which connect the boards together.
- NO knobs or jacks, as these are dependent on the person's personal taste/system format.
2.) Minimal component kit -- for those that wish to source their own common components
Contents:
- 8x board mount potentiometers
- 8x board mount switches
- Headers to connect the boards together
- Hardware to mount the board to the front panel
