 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - automatic (noodles)
longer notes less likely
Page 1 of 1 [11 Posts]
PostPosted: Mon Mar 07, 2005 3:08 pm    Post subject: longer notes less likely Reply with quote  Mark this post and the followings unread
Just a bounded random thingy with some funny sounds & some loops in it.
It does display occasional fragments of music.
Jan.
05-003-007-a.pch2
 Filename:  05-003-007-a.pch2
 Filesize:  5.42 KB
 Downloaded:  3221 Time(s)
Audio files: 235
PostPosted: Mon Mar 07, 2005 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a wonderful noodle, Jan. I've listened it for an hour. Juli can in from the other room and said, "what's that? I like this one." She made me promise to tell you... Smile
PostPosted: Mon Mar 07, 2005 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please say hi to Juli for me, I remember her from Lodon, a pleasant memory.
Jan.
cebec
G2 patch files: 31
PostPosted: Mon Mar 07, 2005 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is very whimsical and pleasant. it reminds me of dieter moebius' work at some points... thanks, Jan! Cool
paul e.
PostPosted: Mon Mar 07, 2005 8:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
if there is eventually a stand-alone G2 player for mac, like that free softsynth version clavia put out, i could finally hear all this stuff !
is this possible yet and i missed it ?
would love to hear these noodles, as you call them
Spiral Recordings
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Mar 07, 2005 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the mac version is out but if it's like the PC version, very few noodle posts will work on it. This one for example is in poly mode, not supported on the demo.
http://www.clavia.com/G2/demo
BTW Jan, brilliant noodle, love the sounds.
Audio files: 235
PostPosted: Mon Mar 07, 2005 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a softsynth version of the G2 called a DEMO version. It's found here: http://www.clavia.se/G2/demo/index.htm
The demo has a bunch of limitations, like mono mode only, no reverb or midi modules, and maybe a few others. It's documented. I think it lacks the ability to run most of the noodles, but it's worth a try. You'll at least be able to see more of what the G2 is really like to use. Maybe some of the master noodlers will make some just for the demo version. Idea
paul e.
PostPosted: Mon Mar 07, 2005 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah YES..cool...great..will give this a try..thanks guys
Spiral Recordings
PostPosted: Tue Mar 08, 2005 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
Maybe some of the master noodlers will make some just for the demo version. :idea:
Maybe they will ..meanwhile I did a little experiment and removed the reverb modules, the patch will now open in the demo program, but it's mono and the sounds are a bit naked.
Moreover I thought I had a reasonably fast computer overhere but it's not able to run the patch sustained ...
Jan.
05-003-007-a-demo.pch2
demo compatible version of 05-003-007-a
 Filename:  05-003-007-a-demo.pch2
 Filesize:  5.29 KB
 Downloaded:  3095 Time(s)
cebec
G2 patch files: 31
PostPosted: Tue Mar 08, 2005 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Razz
thanks! yeah, the CPU usage rockets 20% just by moving the VA/FX divider.
nice adaptation, regardless.
paul e.
PostPosted: Tue Mar 08, 2005 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
ai yi..my older computer begged for mercy heheh....
Spiral Recordings
