I hate passwords
Page 1 of 1 [17 Posts]
King Rat
G2 patch files: 13
PostPosted: Fri Mar 11, 2005 5:14 pm    Post subject: I hate passwords Reply with quote  Mark this post and the followings unread
OK
No welcome to the forum smiley faces please - having spent the past six months visiting and contributing to this forum every day, my brain chose today to completely forget all my passwords etc. It was a toss up between beating my laptop to death with a large Stratocaster or accepting my fate and creating a new user account. In the end, economics won.
So anyway, I had a question. I want to use the sound of the attached patch in a song with my band. The rhythmic effect is create by modulating the filter frequency. However, I need to be able to sync this to a clock (so I can make it a slave to a drum machine which our drummer uses for a click). Can't work out how to generate the same sound but using a clock module rather than LFOs. Any advice?
Angus
fat bass1.pch2
 Filename:  fat bass1.pch2
 Filesize:  3.06 KB
 Downloaded:  1541 Time(s)
PostPosted: Fri Mar 11, 2005 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is not a welcome smiley :-)
It seems to me that you could set the leftmost column of LFO's to Clk mode instead of BPM. Did I overlook something ?
Jan.
King Rat
G2 patch files: 13
PostPosted: Fri Mar 11, 2005 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah!
I see.
OK - that makes it a bit easier. Didn't know there was a clock sync setting on those modules.
Thanks Jan
Angus (guy who sat drinking beers, smoking tabs and dreaming of a better life at Enschede "airport" - now under the Electro-music nomme de plume of King Rat)
PostPosted: Fri Mar 11, 2005 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah rightt, remamber now, the wether is about the same here to day as then, pretty miserable. Ah well, pretty ain't ugly.
I don't know how this bass sounds "in the wild" but on headphones I llike it.
Jan.
King Rat
G2 patch files: 13
PostPosted: Fri Mar 11, 2005 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
If what you mean by "in the wild" is over a PA system, you make a very good point. So often I come up with cool stuff (or, at least, find cool stuff posted on this forum) only for it to sound terrible over a PA. Wonder why that is?
PostPosted: Fri Mar 11, 2005 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Basically because headphones and PAs treat sound differently, but you knew that I guess.
My stuff might sound not too good on a PA, as when I don't work with headphones I use my 7 dollar speaker system.
I know not much about the subject. Using the search facility of this BB you might be able to find some usefull threads. They can't wait to be discovered, sometimes :-)
Jan.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Mar 11, 2005 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did live sound for years, it’s difficult (understatement) to get it sounding like a home stereo. There is only so much you can do at sound check because an empty venue sounds totally different to one full of bodies. Apart from the dampening effect, the increase in temperature and humidity actually alter the speed of sound which shifts all the peaks and troughs around. I should stop or I will just go on and on about crappy PA’s and Venues.
As far as G2 sounds go, for live use, avoid adding much reverb. Simple and clean helps and most venues have more than enough ambience. High volume tends to exaggerate problems, if it sounds shitty, turn the main volume down, not up.
King Rat
G2 patch files: 13
PostPosted: Fri Mar 11, 2005 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tips.
Funnily enough, did a gig last night and the sound engineer was complaining that the output level from the G2 was really low and that he had that channel set to almost max gain to get enough volume out of it. The output of the G2 does seem to be quite low, but it has never been a problem in the past.
Also find that a lot of harsh, high freq sounds (like if you open a filter "too far") don't work in rock venues over the PA - just sounds like a load of white noise out front.
I suppose even in the high-tech world of virtual analogue synths, it's still 90% art as opposed to science...
And fortunately, our keyboard player plays my Nord so she gets all the blame if things go wrong. Very Happy
King Rat
G2 patch files: 13
PostPosted: Fri Mar 11, 2005 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another question, by the way...
I'm trying to use the arpeggiator in conjunction with an opening filter, but I want trigger the filter envelope when I physically press the key, and not retrigger every time a note plays because the arpeggiator is switched on.
i.e. i want rhythmic notes in time with a click, but with a filter which opens slowly as you hold down the key so the notes get gradually harsher. Evidently, even if you connect the trig input of a filter env to the gate output of the kybd module, the G2 still interprets each arpeggiated note as a new key press.
Confused
Audio files: 235
PostPosted: Fri Mar 11, 2005 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
What a wild bass patch! Got any samples of music using this patch? I suspect I would like it. Wink
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Mar 11, 2005 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd use a pulse module to streach the triggers into one. You need to set the pulse time long enough to blend the pulses, but not so long that you cant retrigger on a new chord.
EnvSweepArp.pch2
sweep FC while arping
 Filename:  EnvSweepArp.pch2
 Filesize:  1.65 KB
 Downloaded:  1963 Time(s)
King Rat
G2 patch files: 13
PostPosted: Sat Mar 12, 2005 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see what you mean.
The problem there though is that if I want the filter to reset every time I change note and, say, each held note is 4/4 bar long, I have to set the pulse length to exactly four quarter notes long, and any change in the tempo at which we decided to play the song or discrepancy between my master clock on my drum machine and the G2 will throw the timing out.
Is there no way of differentiating between a physical key press and an arpeggiator note?
Angus
P.S. Howard - there's some of our music on www.kingrat.net , but this mostly predates my G2 purchase and definitely predates any attempts to hook up our drummer to a click and use some sequenced patches. It clearly also predates my ability to play bass guitar!
PostPosted: Sat Mar 12, 2005 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not that I know of.
You could probably use an LFO set to clk mode, reset it to start the pulse. This will repeat of course after a while but using a suitable rate and a suitable PWM setting that could be delayed. You'll have to play a bit with the settings to get it right, but once set right it should track the clock.
Jan.
Audio files: 235
PostPosted: Sat Mar 12, 2005 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice stuff. Real songs... thumb up
Thanks...
King Rat
G2 patch files: 13
PostPosted: Sat Mar 12, 2005 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Bought the G2 to add some spice to the mix and even though I'm still a complete novice in its use, it has definitely added a lot to our gigs.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Mar 13, 2005 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Angus
Here is another idea, if you have a few % dsp spare in another slot as shown in this prf.
Both slots have key focus but the arpeggio is only set on slot A. Inter slot midi passes the gate signal. You can choose between MONO and LEGATO voice mode in slot B to determine if you retrigger on all new notes or just when you play a new chord.
arpSweep.prf2
single trigger env sweep arp
 Filename:  arpSweep.prf2
 Filesize:  3.69 KB
 Downloaded:  1825 Time(s)
King Rat
G2 patch files: 13
PostPosted: Sun Mar 13, 2005 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Or, I suppose, I should just forget about the arpeggiator in this instance and just use a sequencer module to replicate the arp effect, then the filter env can just be hooked up to the kbd gate.
Filter sweep arpeg.pch2
 Filename:  Filter sweep arpeg.pch2
 Filesize:  1.57 KB
 Downloaded:  1353 Time(s)
