King Rat
G2 patch files: 13
Joined: Apr 03, 2004 Posts: 24590 Location: The Netherlands, Enschede
Audio files: 309
Posted: Fri Mar 11, 2005 5:28 pm Post subject:
This is not a welcome smiley :-)
It seems to me that you could set the leftmost column of LFO's to Clk mode instead of BPM. Did I overlook something ?
Jan. |
King Rat
G2 patch files: 13
Posted: Fri Mar 11, 2005 5:38 pm Post subject:
Ah!
I see.
OK - that makes it a bit easier. Didn't know there was a clock sync setting on those modules.
Thanks Jan
Angus (guy who sat drinking beers, smoking tabs and dreaming of a better life at Enschede "airport" - now under the Electro-music nomme de plume of King Rat) |
Audio files: 309
Posted: Fri Mar 11, 2005 5:51 pm Post subject:
Ah rightt, remamber now, the wether is about the same here to day as then, pretty miserable. Ah well, pretty ain't ugly.
I don't know how this bass sounds "in the wild" but on headphones I llike it.
Jan. |
King Rat
G2 patch files: 13
Posted: Fri Mar 11, 2005 5:53 pm Post subject:
| If what you mean by "in the wild" is over a PA system, you make a very good point. So often I come up with cool stuff (or, at least, find cool stuff posted on this forum) only for it to sound terrible over a PA. Wonder why that is? |
Audio files: 309
Posted: Fri Mar 11, 2005 6:15 pm Post subject:
Basically because headphones and PAs treat sound differently, but you knew that I guess.
My stuff might sound not too good on a PA, as when I don't work with headphones I use my 7 dollar speaker system.
I know not much about the subject. Using the search facility of this BB you might be able to find some usefull threads. They can't wait to be discovered, sometimes :-)
Jan. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Mar 11, 2005 6:53 pm Post subject:
I did live sound for years, it’s difficult (understatement) to get it sounding like a home stereo. There is only so much you can do at sound check because an empty venue sounds totally different to one full of bodies. Apart from the dampening effect, the increase in temperature and humidity actually alter the speed of sound which shifts all the peaks and troughs around. I should stop or I will just go on and on about crappy PA’s and Venues.
As far as G2 sounds go, for live use, avoid adding much reverb. Simple and clean helps and most venues have more than enough ambience. High volume tends to exaggerate problems, if it sounds shitty, turn the main volume down, not up. |
King Rat
G2 patch files: 13
Posted: Fri Mar 11, 2005 7:08 pm Post subject:
Thanks for the tips.
Funnily enough, did a gig last night and the sound engineer was complaining that the output level from the G2 was really low and that he had that channel set to almost max gain to get enough volume out of it. The output of the G2 does seem to be quite low, but it has never been a problem in the past.
Also find that a lot of harsh, high freq sounds (like if you open a filter "too far") don't work in rock venues over the PA - just sounds like a load of white noise out front.
I suppose even in the high-tech world of virtual analogue synths, it's still 90% art as opposed to science...
And fortunately, our keyboard player plays my Nord so she gets all the blame if things go wrong.  |
King Rat
G2 patch files: 13
Posted: Fri Mar 11, 2005 7:34 pm Post subject:
Another question, by the way...
I'm trying to use the arpeggiator in conjunction with an opening filter, but I want trigger the filter envelope when I physically press the key, and not retrigger every time a note plays because the arpeggiator is switched on.
i.e. i want rhythmic notes in time with a click, but with a filter which opens slowly as you hold down the key so the notes get gradually harsher. Evidently, even if you connect the trig input of a filter env to the gate output of the kybd module, the G2 still interprets each arpeggiated note as a new key press.
Joined: Jan 31, 2003 Posts: 18278 Location: Durham, NC
Audio files: 234
Posted: Fri Mar 11, 2005 7:42 pm Post subject:
What a wild bass patch! Got any samples of music using this patch? I suspect I would like it.  _________________ --Howard
my music and other stuff Last edited by mosc on Fri Mar 11, 2005 8:42 pm; edited 1 time in total |
ian-s
Audio files: 42
G2 patch files: 626
King Rat
G2 patch files: 13
Posted: Sat Mar 12, 2005 12:40 pm Post subject:
I see what you mean.
The problem there though is that if I want the filter to reset every time I change note and, say, each held note is 4/4 bar long, I have to set the pulse length to exactly four quarter notes long, and any change in the tempo at which we decided to play the song or discrepancy between my master clock on my drum machine and the G2 will throw the timing out.
Is there no way of differentiating between a physical key press and an arpeggiator note?
Angus
P.S. Howard - there's some of our music on www.kingrat.net , but this mostly predates my G2 purchase and definitely predates any attempts to hook up our drummer to a click and use some sequenced patches. It clearly also predates my ability to play bass guitar! |
Audio files: 309
Posted: Sat Mar 12, 2005 12:51 pm Post subject:
| King Rat wrote: | | Is there no way of differentiating between a physical key press and an arpeggiator note? |
Not that I know of.
| Quote: | | The problem there though is that if I want the filter to reset every time I change note and, say, each held note is 4/4 bar long, I have to set the pulse length to exactly four quarter notes long, and any change in the tempo at which we decided to play the song or discrepancy between my master clock on my drum machine and the G2 will throw the timing out. |
You could probably use an LFO set to clk mode, reset it to start the pulse. This will repeat of course after a while but using a suitable rate and a suitable PWM setting that could be delayed. You'll have to play a bit with the settings to get it right, but once set right it should track the clock.
Jan. |
Audio files: 234
Posted: Sat Mar 12, 2005 12:56 pm Post subject:
| King Rat wrote: |
P.S. Howard - there's some of our music on www.kingrat.net , |
Nice stuff. Real songs...
Thanks... _________________ --Howard
my music and other stuff |
King Rat
G2 patch files: 13
Posted: Sat Mar 12, 2005 8:41 pm Post subject:
Thanks.
Bought the G2 to add some spice to the mix and even though I'm still a complete novice in its use, it has definitely added a lot to our gigs. |
ian-s
Audio files: 42
G2 patch files: 626
King Rat
G2 patch files: 13
