today> Sorry, no program tonight. Chez Mosc
lunetta sound samples
Page 11 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13 Next
jcintheus
PostPosted: Tue Nov 01, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hope no one minds my resurrecting this thread.
The Idea behind this patch was to emulate an electric guitar solo.
I used a 40106 oscillator, into a dual JK flip-flop set up as a divide by 3.
Summed those outputs into a 4051/17 melody gen.
Then I ran that signal into a guitar efx pedal.(digitech rp100)
The ABC inputs on the 4051 were fed by a 4094 getting it's data from an xor ladder. All CMOS Lunetta except for the drums. Embarassed
http://soundcloud.com/bill-chavez/sr-jimi-moron
 Filesize:  1.36 MB
 Viewed:  618 Time(s)
tjookum
Audio files: 26
PostPosted: Wed Nov 02, 2011 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Nailed it! It has that same dreamy character as lets say a jimi song while still very much lunetta, awesome.
Hunter S. Thompson
movies
noise
jcintheus
PostPosted: Wed Nov 02, 2011 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Feedback is greatly appreciated, especially positive feedback.
Audio files: 224
PostPosted: Wed Nov 02, 2011 8:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. I like the clean layout - spacious and easy to follow. Having that little breadboard area in the middle is a great idea.
cheers salut cheers
jcintheus
PostPosted: Thu Nov 03, 2011 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Thanks Mosc!
I really couldn't have done it without this forum, an absolutely essential resource. Such a friendly forum as well. Thanks again! Stay tuned!
jcintheus
PostPosted: Mon Nov 21, 2011 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Some experimenting with noise as percussion.
Used an xor ladder, some vactrols and a 4067.
http://soundcloud.com/bill-chavez/ttime
Audio files: 224
PostPosted: Wed Nov 30, 2011 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good structure, it holds together compositionaly.
Draal
PostPosted: Sat Dec 03, 2011 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
This track was recorded a few days ago using half of a 4015 shift register, some outs of a 4040. a 4011 providing data info for the 4015, and that goes to my r/2r. Finally, that output goes to my 4046 vco (based on slacker's info quite a while ago).
shiftWar by Draal
Zontar Prevails!
jean bender
PostPosted: Sun Dec 11, 2011 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody !
So for the first time i share one my sound !
this was made during a headphone festival...
It's the third time i use my logical noise project, and this is the V.2.
I only use a noise boxe which is between the spooly master and the Yum Yum Box, and two different boolean sequencers.
One of the two boolean sequencer is sent into a karplus strong, and i've put on my mixer's aux a headrush delay... I try to play with the less effects i can use !
enjoy !
you should go to this webpage :
http://stream.cannibalcaniche.com/placard/24_heures_du_manque1/
and use the player to find Jean Bender or right click on Jean Bender and paste the url on your hard drive.
Enjoy !
http://www.pilami.fr/photos/picture.php?/4021/category/229
http://h.a.k.free.fr/
www.electroncanon.org
jcintheus
PostPosted: Fri Dec 16, 2011 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work deadbeat
Here's one I recorded using a 40106, a 4018 set up as a divide by 3,
a NAND gate, and a ribbon controller (500mm softpot).
http://soundcloud.com/bill-chavez/ribbon
It's just a quick improvisation, but it was awful fun to record.
mako
PostPosted: Wed Dec 28, 2011 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, nice sounds
and it has a lot of variation in it too, good job!
I only built this small modulation circuit with 5 oscillators and 8 NAND gates to mix them and modulate even more. It has a great random output but want to get some more 'sound' out of it, because now it are mostly ticking sounds and i am looking for some higher notes.
here is an example of my 'modulator' Wink
http://www.youtube.com/watch?v=fmGCLyyo06E
Audio files: 224
PostPosted: Thu Dec 29, 2011 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great to me. Kinda relaxing...
jcintheus
PostPosted: Thu Jan 05, 2012 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Was trying to make long sequences with a 4015 and an xor,
But ended up with this:
http://soundcloud.com/bill-chavez/2-r-2r
4015 dual 4 stage shift register linked into 8-stage register;
7 parallel outs to R/2R;
stages 6&7 of 4015 to xor (4070) to data A on 4015
here's a photo of the patch
 Filesize:  1.4 MB
 Viewed:  404 Time(s)
Audio files: 224
PostPosted: Fri Jan 06, 2012 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Soundcloud seems pretty brain dead on iPad. I click on your link and it invites me to install the iPad app, which I already have done. There is a button to continue anyway, but it doesn't work.
JingleJoe
PostPosted: Fri Jan 06, 2012 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
sound cloud is working for me and I think you acheived your goal, thats a really long changing tune Smile very nice and bleepy, I enjoyed it Very Happy
Draal
PostPosted: Fri Jan 06, 2012 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
If you want a method to turn those clicks into pitches, check out my Spacenuts track, based on the 4046 pitch tracker from Nic Collins' book. Just a few threads up Smile . Simple to build and very essential in my lunetta.
Zontar Prevails!
PostPosted: Sat Jan 07, 2012 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the CMOS/Lunetta stuff on the back-burner for too long now... got distracted by other projects like the Vidiffektor and triple sinewaves and stuff... and now I'm trying to get back into this stuff, remember how things work, and hopefully enough momentum and time to start soldering stuff, instead of a mess of wires on the breadboard...
Nothing too fancy going on in this video, but I dig the patterns and sounds, so I just thought I'd share it...
- 4093 clock driving a 4006 & 4077 pseudo-random 4-bit generator
- those 4 bits, along with various clocks from the 40106 & 4040 drive 3 things:
1. 4017 & 4051 melody generator
2. 4017 & 4051 melody generator with clocked reset
3. R/2R ladder which feeds a triple-voice 40106 VCO
A blurry tour starts around 1m38s, and I let it do its stuff until I started tweaking knobs around 2m18s.
[ link if the embed doesn't work: http://youtu.be/x2vYEs_02aM ]
PostPosted: Sat Jan 07, 2012 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds nice. I thought I was watching my own vid for a sec there - with the similar synth name and green font. Lots of stuff on breadboard. Are you going modular, or will this be a self contained unit?
JacobWatters.com
PostPosted: Sun Jan 08, 2012 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, yeah, I still haven't come up with a name I'm happy with for this thing... maybe that's why I haven't made much progress Smile . CMOSter/CMOnSter are pretty obvious. As for green, it's my favourite colour and back in the old days of monochrome monitors I was a green-screen guy, not amber....
The long-range plan is to make it a suitcase synth with a bunch of patchable modules behind panels.
Audio files: 224
PostPosted: Mon Jan 09, 2012 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks and sounds great already. I love these kind of sounds. Smile
PostPosted: Wed Jan 11, 2012 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me again with a short little video of the CMOS/Lunetta thing making random birdlike sounds...
I believe this was a 4017 & 4051 melody generator fed by a pseudo-random 4-bit generator (using 40174 D-flip-flop & 4070 XOR)... those are the LEDs in the foreground. I didn't take good notes so I can't remember where the 4th bit goes, if anywhere... maybe it's connected to the reset...
The link if the embed doesn't work: http://youtu.be/PHgrVhb01I8 .
PostPosted: Wed Jan 11, 2012 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool sounds!
JacobWatters.com
micheline
PostPosted: Wed Jan 11, 2012 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow!
Audio files: 224
PostPosted: Sat Jan 14, 2012 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
garcho
PostPosted: Wed Jan 18, 2012 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Bravo!
Have you tried recording it and slowing it down? I heard a radio show a long time ago about recording bird songs; if you slow them down, new intricate melodies appear that would normally go by too fast for us humans to perceive. That was something that popped into my head right away, FWIW.
"The life of a repo man is always intense."
