Low Level DSP: Moog Ladder Filter
Page 1 of 1 [11 Posts]
ik
G2 patch files: 25
PostPosted: Sun Mar 13, 2005 10:36 am    Post subject: Low Level DSP: Moog Ladder Filter Reply with quote  Mark this post and the followings unread
Rolling Eyes
An excercise to go after the infamous 'Moog ladder filter'.
A cascade of four 1 pole filters coupled, then after clipping (x^3) the signal feedbacked to pole 1. Based on (but modified) the info published at musicdsp as well as in SynC Modular ...
Cutoff, Resonance, In, Out marked with '(deep)purple color'
(Cutoff: 0-1(64); Resonance: if >=2 starts to self oscillate ...)
ik.
Moog Ladder.pch2
Moog Ladder Filter excercise :-))
 Filename:  Moog Ladder.pch2
 Filesize:  1.79 KB
 Downloaded:  1547 Time(s)
ik
G2 patch files: 25
PostPosted: Sun Mar 13, 2005 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
... and the same from Clavia 1 poles ...
ik.
Moog Ladder 2.pch2
Moog Ladder from Clavia 1 pole cascade.
 Filename:  Moog Ladder 2.pch2
 Filesize:  1.39 KB
 Downloaded:  1402 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Mar 13, 2005 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
More great work thanks.
cebec
G2 patch files: 31
PostPosted: Mon Mar 14, 2005 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i like the way this filter sounds
ik
G2 patch files: 25
PostPosted: Mon Mar 14, 2005 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i like the way this filter sounds...
I wonder, how close it is to a REAL (hardware) Moog filter ...
Question Question
ik.
Audio files: 235
PostPosted: Mon Mar 14, 2005 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assuming we had someone, (who could that be?) that actually has a Moog Modular what kind of test could we use to compare the two?
I've tried tests like this before and there are lots of complications. What do you use for inputs. The Moog oscillators are not exactly like those on the G2. They are inacurate by comparison - some say this is charming. The noise generators sound different. How do you set a Moog filter to the same cut off as G2? Is and mp3 good enough to play back the results? etc. etc. etc.
cebec
G2 patch files: 31
PostPosted: Tue Mar 15, 2005 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Possibly it could be done with the VCO, VCF, VCA going directly to the recording device at an arbitrary level, say -5 dB on the devices input meters and rendered at a 44.1 kHz .wav.
The G2 would be recorded the same way...
Some sweeps up and down at various resonances might be a start...
I know, not a lot of fun... but if anyone with a Moog and some spare time might be willing to try it, it could be interesting.
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 15, 2005 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
guess whose studio is this one Very Happy
The Why Project
PostPosted: Tue Mar 15, 2005 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The studio of somebody who lives in it Laughing
Greetz,
The Why Project
ik
G2 patch files: 25
PostPosted: Wed Mar 16, 2005 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
...Possibly it could be done with the VCO, VCF, VCA going directly to the recording device...
Well, I don't have any hardware Moog, but downloaded Arturia's Minimoog V demo.
On oscilloscope, the output the two filters have VERY similar characteristics regarding cutoff and/or resonance change (I can post pictures if one interested, it will take some bandwidth...I dont know if it's a problem ....)
So this file is based on Arturia's MiniMoog V, anyone wish to check out
or if one (Question) could compare to a hardware Embarassed ...
ik.
mimiMoogy.pch2
MoogFilter testdrive.
 Filename:  mimiMoogy.pch2
 Filesize:  2.41 KB
 Downloaded:  1451 Time(s)
Audio files: 235
PostPosted: Wed Mar 16, 2005 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I did a test once, perhaps a pretty sloppy one envolving an early version of the Arturia, the NM1 and the Moog.
http://electro-music.com/forum/topic-70.html
