today> Bill Fox solo tonight! Chez Mosc
Would you like to see an AC mains DIY PSU design tutorial?
Page 1 of 2 [33 Posts]
Would you like to see a basic, AC mains DIY PSU tutorial?
Yes, please spill the secrets immediately!
84%
 84%  [ 11 ]
Wouldn't mind a refresher if you have the time.
0%
 0%  [ 0 ]
I'm fine either way.
15%
 15%  [ 2 ]
Not sure I need more PSUs any time soon...
0%
 0%  [ 0 ]
No thanks, I'm good.
0%
 0%  [ 0 ]
Total Votes : 13
MadScientist
PostPosted: Tue Jan 03, 2012 9:31 am    Post subject: Would you like to see an AC mains DIY PSU design tutorial?
Subject description: Will be designing a PSU for myself anyway, so...
I will be buying the components for a new dual polarity, mains powered linear PSU within the next few days, once a few other details have come to pass. This will be for my synth experiments.
Despite their obvious importance, then in my experience the design and building of linear PSUs tend to be one of the gray areas of electronics DIY. As such I was wondering if people here at E-M would like to see a 'Build-Along' of sorts? Many of the general rules of thumb on this subject you tend to find are actually not that great, and as a result many people end up with problems of various sorts when they build their own PSU(s).
Personally, when building something like this, I like to know what the rules actually are. Doing so then gives me the option to decide whether I actually want to follow them to the letter, or when I can cut some corners.
Did you know that:
  • There is such a thing as having too large a heat sink?
  • The data on many heat sinks are not to be taken literally?
  • Usually there is one optimal size for a smoothing capacitor - yet few books for electronics hobbyists will tell you how to find it?
  • Your mains transformer is probably too small? Very Happy
  • There are important differences between the families of three legged voltage regulators - which is also why their prices varies considerably?
  • The square root of two (1.41421356...) has very little relevance to real world PSU design?
  • At least one transformer manufacturer doesn't know how to use their own products? (*Very* reassuring that is... Rolling Eyes )
  • It is possible to design a linear PSU for higher - though perhaps not 'high' - efficiency?
If you answered 'No' to one or more of these questions, then you might want to consider letting me abuse the Queen's English in an attempt to explain these and many other fine points in the art of designing linear power supplies (How is that for a run-out sentence? Wink )
Please vote according to conscience and your personal preferences.
- Frank.
PostPosted: Tue Jan 03, 2012 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Please include fusing guidelines, too.
I have built the MFOS power supplies and they are very good. However, I had to make a "guestimate" on the transformer size.
This is an excellent idea -- might want to review safety tips/warnings for working with lethal voltage, too.
Paradigm X
PostPosted: Tue Jan 03, 2012 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes ! Im literally about to start, having put it off for 6 months due to concerns about safety.
Absolutely, ive been looking at these today, as it happens. WELL confused.
Cheers!
JingleJoe
PostPosted: Tue Jan 03, 2012 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Usually transformers have a VA or W rating (Volt-Amperes or Watts) and as one should know; Watts = V x I so if your transformer transforms 220V to 22V and you require 0.5A (500mA) then 22 x 0.5 = 11 so you need a transformer rated for 11 Watts.
I've built one or two or 203850928635 of my own power supplies before, all cobbled together from junk and they worked well enough but there was often alot of mains signal bleed through. More capacitors, flux capacitors if possible, would smooth this out.
MadScientist
PostPosted: Tue Jan 03, 2012 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Correct, but that is not sufficient information to judge which VA rating a transformer should have for a regulated DC power supply.
This is one of the classic mistakes, assuming it is this simple. Wink
Dougster
PostPosted: Tue Jan 03, 2012 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I had been toying with not replying to this thread, since I don't wish to give you any more relevance.
What is the purpose of this poll other than to draw attention to yourself?
In other words, as we merkans say, "put up or shut up."
Regards,
Doug
EDIT: To the casual reader, sorry about the snarkiness. Please read the copyright thread for background info.
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
Mooger5
PostPosted: Tue Jan 03, 2012 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting! Are we talking regulated or non-regulated?
The most complex power supply I´ve built was for a valve amp. I used Duncanamp´s PSU Designer to predict the ripple after a long chain of RC filters.
Building a better power supply may not be these users´priority; most will be happy with one that doesn´t hum, IMHO. But from my Hi-Fi background I have this notion that regulated is "essencial" but non-regulated just sounds "better". So, why not use two seperate PSUs, one regulated for CV and other critical functions and one non-regulated for the audio path?
EdisonRex
Audio files: 172
PostPosted: Tue Jan 03, 2012 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd suggest that you publish what you want to, as people here are able to cross verify what you publish with what else we know. I've been a proponent of overrating power supplies for a while, but there's plenty that can be said in the exposition.
Garret: It's so retro.
Paradigm X
PostPosted: Sat Jan 14, 2012 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
So is this happening then or not? Confused
Audio files: 327
PostPosted: Sat Jan 14, 2012 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm afraid that some reactions to MadScientist (in another thread mainly) may have led him to believe that this community is not always as friendly as it could be ... this whole situation is a bit disappointing Crying or Very sad
Anyway, so I'm afraid this will not happen.
Dougster
PostPosted: Sat Jan 14, 2012 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not so fast, don't give up yet....
Regards,
Doug (he says mysteriously...)
Blue LEDs are evil.
LFLab
PostPosted: Sat Jan 14, 2012 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
+1
To me it is a letdown to see that in a community where all kinds of topics can be discussed freely, a topic such as copyright leads to such reactions.
Whether or not the choice of topic was a handy one for a new member is certainly debatable, but any one of the senior members could have exercised a bit of restraint when replying.
PostPosted: Sat Jan 14, 2012 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Frank will be back. I've communicated a bit with him.
Dave Kendall
PostPosted: Sat Jan 14, 2012 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
+1 for some info here on PSU design, if you're up for doing it Frank. Thanks, it's a cool offer. Smile
I'm another one who's shied away from home-built PSUs so far .....
Something I'd be *very* interested in, is discussion/details of the sort of protection/short circuit circuitry you get on a Power-One HAA15 (mine's a MOTM 900). If you connect it the wrong way around, it just seems to shut off.
I've powered up the modular with +15V and -15V inadvertently connected the wrong way around to a new module a couple of times, and nothing happened. No power, no magic smoke. I would love to know how that works....
Info about building a "bomb-proof" power supply, that protected modules too would be a very popular thing for SDIYers I reckon.....
PS, I know it's Friday night (beers an all....) but has anyone else noticed that Dougster and EdisonRex's avatars are almost identical except for the background and some moustacheness?
Have they ever been seen together in the same room?
Is there a secret SDIY person cloning facility somewhere, perhaps on Kamino?
(OK, I'm going now.....Wink )
Dougster
PostPosted: Sat Jan 14, 2012 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, depending upon what you have, that may not actually be the power supply itself. Some modules are designed with diodes on the input to ensure that there is no damage if you accidentally connect the wrong polarity...
Regards,
Doug
Blue LEDs are evil.
Dave Kendall
PostPosted: Sat Jan 14, 2012 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Doug.
Most of my stuff is EFM or CGS, apart from a Paia MIDI2CV8, and my own MIDI2CLOCK. None of the modules have protection diodes, and they all have ferrite beads rather than 10-22ohm resitors in series with the power rails (ferrite beads have been retro-fitted along with 10uF caps to the EFM stuff.)
That's why I'm puzzled/intruiged by the HAA15... By all rights I should have generated some Magic Smoke by now with the odd reverse polarity hookup....
Dougster
PostPosted: Sat Jan 14, 2012 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wish I was as good looking as he is! (And had such the cool instrument...)
Rumour has it that, if we were to be in the same room, the laws of physics would break down and the universe would come to an end...
Regards,
Doug
P.S. I've been dredging my memory, is that sig quote from Dirk Gently?
Blue LEDs are evil.
Dougster
PostPosted: Sat Jan 14, 2012 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where's Tim Servo when we need him? Cool
I have the same MOTM 900 power supply. I just pulled it out of the rack and looked at it. Nothing obvious...
Regards,
Doug (Wonder if I should try plugging it in backwards...)
Blue LEDs are evil.
MadScientist
PostPosted: Sat Jan 14, 2012 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Normally I'd just do that, publish what I want. However in this case I have to spend a non-trivial amount of time preparing the article series. Thus I'd rather not risk having wasted the time, if the subject had previously been rehashed ad infinitum. Wink
For instance right now the next step for me is revisiting an old linear PSU simulation program I wrote a while back, in order to generate a number of graphs I need.
And yes, over-engineering linear PSUs turns out to be a really smart move in most cases, as I will also try to demonstrate. I happen to be a strong proponent of the judicious use of gentle overkill in DIY electronics in general (though in some cases trouble may arise from it). The added cost in doing so tend to be small, yet the gains in reliability and performance often quite the opposite.
This. Cool
Hadn't really planned for this to be an instantaneous thing, once the poll had ended. Additionally something else is bugging me in real life, which prevents me spending as much time on this as I'd like. My generally low noise level here on E-M is also an indication of this.
So no ETA for this yet, but it will be coming.
Electro80,
I am aware I also need to reply to your latest PM. Stay tuned, please.
- Frank.
LFLab
PostPosted: Sun Jan 15, 2012 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
apart from dimensioning of the psu, this thread is also a good place for other stuff like output protection and simultaneous shutdown and startup. had to put in some new discretes when one rail dropped out a while back. i have schematic somewhere i'll post it when i'm on my pc later on.
sizone
Audio files: 48
PostPosted: Sun Jan 15, 2012 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I, for one, would love to see you go ahead with this. It seems, no matter how hard I try, I always end up with +11.7v and -11.9v and I would at least like to know why.
LFLab
PostPosted: Sun Jan 15, 2012 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
There could be other reasons, but if you are using a regulated supply, it is necessary to hook up a load resistor before measuring the voltage, especially the 79xx series is noted for not being able to regulate properly if it is not delivering any current.
By the way, this is the simultaneous shutdown trick:
It's from a soundcraft psu, uses a positive regulator for both rails, and shuts down both if one is shorted. Not sure how critical the type of the transistors are, not very, I think (2SA and 2SC are not easy to get overhere, at least not all types).
LM338 is a 5A regulator, think you can do this with LM317 as well. Not sure if 78xx lends itself to the same trick.
Dave Kendall
PostPosted: Sun Jan 15, 2012 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Jarno - thanks for that diagram. Seems simple enough, and the +48V section looks like it could be easily discarded if not needed. Tweaking the circuit for ±15 shouldn't be too hard.....
Doug - the sig is a quote from Bishop, the android or "Artificial Person" as he prefers to be called, in the movie Aliens. Wink
Dougster
PostPosted: Sun Jan 15, 2012 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, thanks for that. Silly as it may seem, I've never seen that movie. For some reason I was thinking it was the electric monk in Holistic Detective Agency. Guess that tells you a lot about my movie and book habits, eh? Laughing
Back on topic, remind me if I don't remember to post the output mute circuit from the Roland TR-808...
Regards,
Doug
Blue LEDs are evil.
EdisonRex
Audio files: 172
PostPosted: Sun Jan 15, 2012 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, both Doug and I noticed that Laughing
The fact that we're near the same age too is funny (to us) and the twin sons of different mothers cliche has been brought up in the chat. But rest assured we are not actually doppelgangers. Wink
