JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
JingleJoe
Posted: Sat Jul 21, 2012 9:58 am Post subject:
I have named this device: Electron Fluctuator!
Find attached schematics and more demonstrations (but this time shorter).
| Description: |
| Filesize: |
913.75 KB |
| Viewed: |
629 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
power starving considerably shorter test.mp3 |
| Filesize: |
1.23 MB |
| Downloaded: |
1321 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
power starving pew dink pew.mp3 |
| Filesize: |
1.33 MB |
| Downloaded: |
1385 Time(s) |
_________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
attdestroyers
Joined: Mar 29, 2012 Posts: 47 Location: Malvern, Ohio
Posted: Sat Jul 21, 2012 11:44 am Post subject:
| Good work Joe. But, I don't have any BC182 transistors. Is it possible to substitute a 2N type? Any idea which one? I won't get to breadboard this till tomorrow, but it looks fun. |
JingleJoe
Posted: Sat Jul 21, 2012 4:29 pm Post subject:
You're damn right it's fun! I got totally carried away with that first demo, that's why it's almost 20 mins long Thanks again to Uncle K
Any transistor should do really, just check the power and current rating and do some calculations with ohms law to determine current through R1. Make sure everything is within specification, you know? off the top of my head 2N3904 should work as well as BC547 and BC337. BC182 is just a common tranny which I have lots of, different transistors might give different results due to differences in gain. Subsequently one may need different resistor values for RB and R1. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Sun Jul 22, 2012 2:07 pm Post subject:
| Quote: | | You're damn right it's fun! |
yes it is
I did some power starving experiments a long time ago with a WSG
suppling power to it through a vactrol , much fun to be had there too. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
JingleJoe
Posted: Sun Jul 22, 2012 2:49 pm Post subject:
That could make a nice additional feature to a WSG; supply the oscillators through the above transistor circuit
I took this device to my grandparent's house today (to do gardening, mostly ) my grandad had good fun playing with it too! He made a really nice little beat, a rhythmic sound by adjusting the LFOs very precisely, he somehow got it to sound like hi hat cymbals and snare drums too  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
diablojoy
Posted: Sun Jul 22, 2012 9:26 pm Post subject:
you could also take a look at ray wilson mod circuit for the WSG and try power starving through that though i have not looked at the current limitations of that one . would be similar i guess
Interesting to run a CV from a sequencer into such a circuit
with the vactrol i used the vactrol drive section of scott stites mutant filter
not 1v/oct of course but it did sequence the WSG frequencies in a weird and wonderful way.
your circuit would provide basically the same effect if instead of the LFO's you just had CV in jacks ? _________________ In an infinite universe one might very well
JingleJoe
Posted: Mon Jul 23, 2012 1:50 am Post subject:
Yes however the impedance is a bit low, I suppose one could just power the circuit directly from the LFOs if you buffer them, but I wanted a level control although the transistor is effectively my buffer here.
If I were to add external inputs to this I would mix them with 100k resistors and buffer them with an op amp voltage follower. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Mon Jul 23, 2012 2:29 pm Post subject:
Thanks for the appreciation Joe, but I really didn't do much. Just starved a couple of 40106 oscs of the pulses coming out of a 4017 through a transistor. I'm sure that's been done before. And it sounds like you've found a better way of doing that already.
Still, if I've inspired a new path of enquiry for you, then that's great.
I must admit that I've had some impedance issues as well. Just changing the output from a piezo to a ruby amp to the input of a mixer, created all kinds of changes in the sounds it produces. (not always in a good way either)
Meanwhile, I've had a whole load of personal problems lately, which have pretty much put a hold on doing anything in the lab for a while. So I look forward to following your progress vicariously, and hopefully bleeding back some of the knowledge I've inspired.
Keep up the good work!  _________________ What makes a space ours, is what we put there, and what we do there. |
JingleJoe
Posted: Mon Jul 23, 2012 10:56 pm Post subject:
You gave me the inspiration
This project is pretty much done and dusted, to solve the impedance issue I'd add an op amp buffer to the output which is powered from the main power rail, not the transistor. A 100k pull down resistor might be useful for it's input to stop it floating when the starved portion of the circuit is un-powered.
However I used up all the op amps in an LM324 for re-combobulating those LFOs so I was reluctant to add another op amp for buffering.
I've got some more stuff in the works, keep an eye out for it  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Tue Jul 24, 2012 2:58 am Post subject:
Maybe a really large pulldown, say 1-10M may let it float around just long enough to be extra interesting!?  _________________ What makes a space ours, is what we put there, and what we do there. |
JingleJoe
Posted: Tue Jul 24, 2012 3:09 am Post subject:
hahaha I was trying to avoid the glitches associated with floating inputs but you have brought out the lunetta spirit; the glitch gremlin!
If you wanted to get floaty weird voltages maybe some kind of capacitor power reseviour, a little filter or something on the buffer, between it and the transistor collector, although that may just smooth things out, maybe an LR filter would do interesting things?
I don't know I'm too sleep deprived to think anymore today  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
JingleJoe
