G2 blind users
Page 1 of 1 [19 Posts]
xav
G2 patch files: 7
PostPosted: Tue Mar 22, 2005 1:46 am    Post subject: G2 blind users Reply with quote  Mark this post and the followings unread
Is there any blind G2 user?
Jean-Philippe Rikiel came to visit me and fell in love with the machine. He would like to find a solution to patch and to use drop-down menus with his translation software "Jaws". If anybody has informations that could help us, it will be welcome.
His software is running with Windows xp. Here is a link to that soft:
http://www.freedomscientific.com/
Jean-Philippe isn't new to synthesizers. You have maybe used one of his sound, the Rikiel Bass, first edited on the original Dx7 and converted for the G2. You have probably seen him with african artists, such Youssou N'Dour.
You can find all you want to know about his career here:
http://takticmusic.com/artistes/rykiel/rykiel_frames.html
I'm sure the G2 community would benefit Jean-Philippe's expertise and knowledge.
Xavier
Audio files: 224
PostPosted: Tue Mar 22, 2005 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Xavier. Good to have you here.
I don't have any experience with aids for blind people using computers. I would imagine that in the case of the G2 editor which is almost totally graphical, it would be quite challenging. I hope someone else can come up with a suggestion.
From reading his web site, Jean-Philippe is certainly inspirational. Since the electro-music.com forum is primarilly text based, I would think there are tools which would enable blind people to read and participate here. Although I didn't write the forum code myself, I have hacked it up a bit to add some special features. If there is anything I can do to make this site more accessable, please let me know.
xav
G2 patch files: 7
PostPosted: Fri Mar 25, 2005 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Howard,
I hope Clavia will spend the same energy to add shortcuts to patch and change drop-down selectors. that could also help sighted users, when working with sophisticated patches.
I think the community could patch for blinds, if you don't mind with your forum as an interface.
xavier
Audio files: 224
PostPosted: Fri Mar 25, 2005 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure I understand this. Would we need to add any new features to the forum to enable this? How would the community "patch for blinds"?
xav
G2 patch files: 7
PostPosted: Sat Mar 26, 2005 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it isn't necessary to change anything.
If someone posts a patch (without the wires) and tells which output should be plugged to which input, I'm sure he'll find an answer with the patch completed.
But the first thing would be to find a motivation for Clavia to add shortcuts to wire modules.
This is my idea:
You focus the output of any module, and it proposes (with right clicking) a drop-down selection of any new module to add, and to insert if a wire is already plugged.
You focus any input of any module, and it propose a drop-down selection of any existing output of any existing module of the patch.
The benefit would also be ability to plug easy a complex patch that doesn't fit the screen.
Audio files: 224
PostPosted: Sat Mar 26, 2005 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, that is a good suggestion, IMHO. I think it would be useful for blind and sighted people as well. Why don't you post this in the Wish List?
xav
G2 patch files: 7
PostPosted: Mon Mar 28, 2005 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I proposed my idea to Clavia's programmers. The answer was polite, but they toldme they find it difficult at this moment
make such an adaptation of the software.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Apr 05, 2005 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just had a thought regarding G2 editing by the blind. If Clavia could implement an automation layer into the editor, the type that makes MS applications like Word and Excel accessible through scripting or real programming languages. It would then be easy (less difficult) to implement a speech activated G2 editor. A small vocabulary would enable adding, connecting and tweeking modules. Without compromising or exposing the internal workings of the editor or file system. The same mechanism would also tlrivialise the creation of DX7 patch importers, parameter randomizers and even partially functional NM1 converters. But that would just be a bonus Smile.
xav
G2 patch files: 7
PostPosted: Wed Apr 06, 2005 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the idea,
I don't really know how automation layer work. Would it be possible to automate so many possibilities to be able to patch anything of an existing patch?
It seems to be a nice direction.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 06, 2005 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
To be honest, I have used the automation features in Word and Excel a lot but have never written an application that can ‘expose’ its objects and methods.
For example, jscript code to start Excel and open a named workbook for access looks like…
Code:
var xlapp = new ActiveXObject("Excel.application");
var book = xlapp.Workbooks.Open(“bookname”);
I could not say how much work would be involved for Clavia in making the G2 editor an activeX-able application (or whatever MS call it now days) but if they use MS development tools, it is doable I think.
I imagine a speech session would go like, “new patch slotA”, “add oscA”, “add nordfilter”, “connect audioin to oscA1 out” etc.
I understand speech recognition can be very reliable with a limited vocabulary.
This I think would benefit not just the blind, but users suffering from OOS or whatever.
One existing feature of the G2 key that would help in this example is the Patch mode button. When this is pressed, the selected module’s controls are laid out on the knobs/switches in a predefined order. So after connecting “classicfilter2 fmod” to “ADSR3 out” you can just grab the second knob and tweak the decay time.
The task of creating a usable G2 system for the blind would not be easy, nor would using it. The open ended nature of the G2 would be very challenging.
Wan
G2 patch files: 46
PostPosted: Wed Apr 06, 2005 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly what i have been doing, to a certain level. As you may know (or not) i'm suffering from RSI and so try to minimise the use of my hands for use on windows.
So i used a speech recognition tool (Scansoft Dragon naturally Speaking) for the G1 editor. This tool allows the creation of macro's triggered by uttering a certain user definable speech command. In this macro's you can control the computer keyboard, mouse, the available active x controls (i guess they are that) etc.
For the G2 i don't have yet made these macro's cause it is getting slightly better with my hands and the development of macro's isn't that easy for me, it is again a lot of computer work:(. But i know it is possible...
Problem i see for using this for a blind person is that i do need visual feedback to see if the computer interprets my voice commands correctly. So i think this tool is not usable for a blind person. But maybe i am wrong?
Grtz Wan
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 06, 2005 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
The openness of the windows message queue is great for doing macro’s but I couldn’t figure how the click and drag patch cord connection mechanism could be done, without assistance from object automation. Did you work that out? Maybe we are closer than I thought. Couldn’t the Speech recognition use speech synthesis for feedback?
Wan
G2 patch files: 46
PostPosted: Wed Apr 06, 2005 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not really...there is an out-of-the-box command set to manipulate the mouse movement and i have used that. It is cumbersome though. In short it uses a grid that can be made smaller and smaller targetting in on a place on the screen, than click there, then target in using the grid on another position, than drag to there. So the drawing of 1 cable goes like this for instance (all utterances):
- mousegrid
- 9
- 4
- 3
- mark here
- mousegrid
- 6
- 3
- 2
- 1
- drag to here
A place on the screen is reachable within 3 to 4 steps using the mousegrid.
But drawing a lot of cables this way is not a fine thing to do.
In the attachment there is a screen shot of the macros i have made for the G1. That will give an idea of some of the possibillities.
Overview of voice recognition macros for the G1
 Filesize:  44.72 KB
 Viewed:  7006 Time(s)
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Wed Apr 06, 2005 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, overlooked this question.
No, the feedback is in the editor doing the right things. When i say f.i. "Minus 5" there must be a knob in a selected state to apply this macro to. If that isn't the case the macro is meaningless. To see if that state is established you have to see the editor. Hence the difficulty if you can't see. The editor is not anything that a screenreader can read, at least not by the tool i am using. My tool can read normal text using speech synthesis, but not any graphical information. Now are there screen readers that can do this?
Grtz Wan
Jean-Philippe Rykiel
PostPosted: Fri Apr 08, 2005 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Friends,
So here I am joining you on this list. It hasn't been too hard, except for filling the confirmation code field, but fortunately I have sighted friends around me to.
I just read the hall series of messages related to my problem, and I must say that it feels really nice in deed to see that many of you care.
That's right, the tool I'm using is a screen reader. Basically, it does two things : it replaces mouse movements with key commands, and it reads what ever it can and outputs it into Braille or voice. I don't use voice recognition for the moment.
Jaws, for that is its name, can also learn how to behave with graphics, and you can also write scripts for applications using non standard objects.
Thus, third parties have written scripts for applications such as Sound-Forge or Sonar, but that's a hell of a job and I haven't learned how to do it for the moment.
Meanwhile, what I thought of was a program that would just be a patcher, where only the name of modules would appear in standard name lists, a list of oscillators, a list of filters and so on. Then, it would have standard buttons like, "connect to next", "connect to previous", "insert", "remove", and other things like that.
All the editing could be done on the G2's front panel and that would be it.
I don't know how crazy it sounds, how much work it requires and if some one els than the Clavia team can do it. What do you say?
Also I'd love to send you a sample of my music, can I attach it to a post? How big can it be?
Best regards to all of you,
Jean-Philippe Rykiel, the blind one.
PostPosted: Fri Apr 08, 2005 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Jean-Philippe! Nice to have you here!
Sure you can attach a song to a post. Uploads takes some time because the file is bounced to another server after it is sent to thins server with the post. 5-15 megabyte should be just fine for a single post.
What you suggest is some sort text based interface to the editor, or rather a version of the Clavia G2 editor that has a text based interface. this is in fact pretty interesting, because this theoretically does touch upon some issues that have been discussed in other threads. Today the only way to program the G2 is by using a graphical interface with representations of the modules onscreen. Possibly extending the editor to have a textbased interface could open up the system more and one might even dream about "compiling" text patches into DIY modules.
Another thread here somewhere mentions the fact that after Clavia updated its editor, the new colorscheme proved to be hard to "read" for users who are colorblind. Clavia is using different colors to identify CV and gate signals etc. and the new colorscheme pretty much killed the interface for many who are colorblind.
Flickr
Audio files: 297
PostPosted: Fri Apr 08, 2005 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Jean Phillipe.
Regarding the simple editor program :
For non Clavia people it would be necessary to first reverse engineer the patch format (which tells how the patch structure and settings are stored into the patch file) before a usefull editor could be built.
This is a very time consuming task. For the NM Classic it was done, but that was easier as a patch file contains readable text. The G2 patch format however is binary, which means more work, and of course the patch format is inherently more complex as the synth itself is more complex.
To build the actual editor would be the easy part.
Jan.
xav
G2 patch files: 7
PostPosted: Mon Jun 27, 2005 10:31 am    Post subject: "g2" the return of the blind Reply with quote  Mark this post and the followings unread
Hello everyone,
Here is a message I sent about a week ago to Clavia on behalf of my blind friend Jean-Philippe Rykiel and to which I had no answer yet.  If you guys have
any idea ...
sincerely
Hello
As I mentioned in an earlier mail, we are looking for solutions to
help the blind French musician Jean-Philippe Rykiel, to access G2's
editor. This could also help visually impaired musicians who would like to
use the G2, (blind or low sighted ones.)
We miss hot keys that could connect modules to each other, and indications
that tells if an input or output is plugged, and to which other modules.
He is planning to order a customized script for his screen reader (Jaws),
to recognize all the graphical information of the editor. Since this
work is expensive, we would like to be sure of the best moment to do the
job, because any future change in the design of the interface could lead in
a big waste of money and time to fix compatibility issues.
Could you tell us if such changes are scheduled,
Jean-Philippe would appreciate your advice to choose the best moment to
collect graphical information.
Thank you
Best Regards
Xavier
deknow
PostPosted: Mon Jun 27, 2005 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
for years, my day job was training people to use dragon naturallyspeaking (and some customization). the problem i see is that although this is a synthesizer designed to make sounds, the interface to program the thing is inherently graphical. short of a touch screen that also gives tactile feedback as to what is on the screen, i don't see how one can program effectively without being able to see the editor.
i can imagine a blind user using the genetics stuff, but i think there would need to be some help in the patching stage...there are just too many ins and outs on too many possible modules with too many posible positions on the screen.
deknow
