today> Bill Fox solo tonight! Chez Mosc
vactrol panner
Page 1 of 1 [22 Posts]
diablojoy
PostPosted: Fri Feb 25, 2011 2:04 am    Post subject: vactrol panner Reply with quote  Mark this post and the followings unread
something i have been playing with this last week
vactrol type isnt fussy i am using NSL32 but could just as well be
vtl5c3, A slow closing vactrol like a vtl5c4 could be interesting also
the P2 connector goes to a B100k pot pin 2 is the wiper just reverse 1 and 3 if left / right is wrong way round . note with the pot in the centre and no cv input there is no output.or at least very little
CV input can be from an LFO output +5 to -5 volts though going to the rails will not hurt anything.
T1 and T2 adjust the sensitivity for the vactrols you can get them pretty good just by watching the panel leds PD-L / PD-R while adjusting P2 for the supplied voltage though the actual vactrol response is slightly different to normal leds so also use your ears
anyway hope someone can use this Smile
edit: 09/11/12 see post further down this page for latest rev
vactrol pan test lab.mp3
 Filename:  vactrol pan test lab.mp3
 Filesize:  2.61 MB
 Downloaded:  1993 Time(s)
ask where the hell am I
as good an answer as any
ericcoleridge
PostPosted: Thu Jul 07, 2011 2:29 pm    Post subject: Re: vactrol panner Reply with quote  Mark this post and the followings unread
wow! this is great!!! I never noticed it before. Is this for the schematic on Mark Verbos' site?
diablojoy
PostPosted: Thu Jul 07, 2011 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm must remenber to post the schematic for this Embarassed
No dont think i have seen that one, though it probably couldn't be that much different .
the idea for the basic vactrol drive circuitry initially came from when i was looking at Scott stites mutant filter though obviously i added quite a bit to that
this is the cct i used for my Blacet Time machine build where in that case i actually wanted silence when the pan pot was centered and when no cv is being applied as it was for the wet signal only.
i also added a gated inverter to the CV in on that build so i could use a cv from a sequencer and a clock output into the gate input to get the necessary negative excursions.
I was thinking of revisiting this one at some point to see if i can change the manual pan response using a dual gang pot instead for the case when you actually want an output with the pot centered though there is always going to be some compromise doing that because it is a vactrol cct.
ericcoleridge
PostPosted: Fri Jul 08, 2011 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im not sure where Mark took this from (maybe he made it up) but there's tons of vactrol panniers and faders in the Buchla 200 schematics obviously. There are two panners on the 206 dual mixer, and a fader in the 240 freq shifter/balanced mod.
ericcoleridge
PostPosted: Sat Jul 09, 2011 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember when Verbos' vactrol panner and fader were discussed before in these forums, a lot of people mentioned that they had difficulty getting them to work. For this reason, I never experimented with them much-- but I now have a need for some compact panner and fader circuits and so it's probably time to re-visit these vactrol circuits.
Have you tried making a vactrol fader by any chance?
diablojoy
PostPosted: Sat Jul 09, 2011 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahh sorry no i havent, nor is one on my agenda
for the forseeable future.
I am hoping to come up with a multiple mn3005 BBD cct , since JH seems unlikely at present to continue with his, anyway this will likely take up all of my spare time for the next few months at least.
diablojoy
PostPosted: Fri Dec 02, 2011 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
slight changes plus scheme
edit : deleted bad attachments
roglok
PostPosted: Sun Nov 04, 2012 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I've etched and built one of these but unfortunately the right channel doesn't work. While debugging I noticed some inconsistencies and an error on the PCB:
- The schematic uses 2N3904 throughout, but the board overlay specifies two 2N3904 and two 2N3906 transistors
- One 1M resistor is connected to the anode of the right Vactrol instead of +15V
- The 47K resistors going to GND in the pan pot voltage dividers are not connected to the pot lugs but to the positive and negative rails.
Did you ever build it using this layout, diablojoy? If yes, how does it need to be modified to work?
diablojoy
PostPosted: Sun Nov 04, 2012 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh dear sorry to hear that Embarassed .
it has been a long time since i did this, i will have to go over it tonight and get back to you .
there were 3 or 4 original prototypes but I definitely have a working version
diablojoy
PostPosted: Mon Nov 05, 2012 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
dammit Evil or Very Mad
the layout i posted was the wrong one [a failed version ]
for the very reasons you point out
I thought i had got rid of it of my drive edit : i was having a very bad day it seems i deleted the good one , will endevour to ressurect it.
really sorry for that. Embarassed
I also found something else in the scheme that needs attention
there are also 2 summing resistors and diodes missing for P2
not something that would actually prevent it working, just bad
so i will need to fix that on the scheme and repost the correct versions
and yes it should be 2 x 2n3904 and 2 x 2n3906.
roglok
PostPosted: Mon Nov 05, 2012 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey, thanks for your reply!
the circuit seems simple enough, but i don't know enough about electronics (yet) to connect the dots myself. so i'd be grateful for any help in making this work thumb up
diablojoy
PostPosted: Thu Nov 08, 2012 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
OK sorry roglok for the wait i had to redo this as i couldnt recover the original correct files
however not too bad the layout is basically as close to the one i had working as i can get. I etched and built it to make double sure anyway
so yes this one definitely works.
must get more vactrols
I think slow ones would be best with this.
but panning bouncy stuff is cool as well
cv source = +/-5v LFO signal is good
vactrol panner foil.pdf
 Filename:  vactrol panner foil.pdf
 Filesize:  19.32 KB
 Downloaded:  1174 Time(s)
vactrol panner component.pdf
 Filename:  vactrol panner component.pdf
 Filesize:  15.61 KB
 Downloaded:  1132 Time(s)
vactrol panner scheme.pdf
 Filename:  vactrol panner scheme.pdf
 Filesize:  24.56 KB
 Downloaded:  1256 Time(s)
roglok
PostPosted: Thu Nov 08, 2012 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. Thanks so much for taking the time!
However, before I start modding my board:
PCB and schematic are different again... In the current overlay, the Vactrol LED cathodes are connected to the panel LED cathodes. In the scheme the Vactrol LED is flipped...
Also, I think the parts overlay shows the transistors reversed...?
Thanks and sorry for bugging you!
diablojoy
PostPosted: Thu Nov 08, 2012 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe the parts overlay is correct
as i actually glued a printed version directly on the board before stuffing
to work from and it is working fine.
At the moment i print them directly from the pdf and use board laquer
to attach them [ must be printed on bubblejet with that way ] though just PVA glue would probably work as well [must try that soon ] or you could probably just use a self adhesive paper. drill the board first before attaching and then just use a sharp scriber to punch through the paper once its set definitely makes stuffing self etched boards easier and quicker.
Embarassed yep i didnt flip the orientations as i should have in the scheme will sort tonight
the panel LED's should be run in series with the vactrols and need to be installed for the unit to work with all anodes toward the +V behind the 470R resistors, hmm i should swap the connectors 180 degrees for the the panel LED's on the board as well too, those square pads are misleading
Haha no bugging just glad someone's taken some interest. Besides you found many issues that i otherwise would not have realised exsisted
so i get to learn as well.
diablojoy
PostPosted: Thu Nov 08, 2012 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK sorted finally i hope
dont know what drugs i was on but the scheme wasn't even close to being correct, luckily i didnt go off that when i redrew the board, i followed closely the traces of the existing original board.
anyway the scheme should now make a whole lot more sense.
also I flipped the panel LED connectors on the board so they are now less confusing, especially if installing LED's directly
cathodes are to square pads
that is the only change for the actual foil and component overlay
thomasdupouy
PostPosted: Tue Mar 14, 2017 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi !
i just do this circuit but one channel doesn't work really,
one LED blink but the other one stay bright all the time,
i check everything but i don't know where is the problem
any idea ?
thanks !
diablojoy
PostPosted: Tue Mar 14, 2017 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
What CV are you inputting - this circuit expects a bipolar CV
eg the output from an LFO +/-5V a sine wave or triangle is best to start with
also the manual pot should be centered at 12 oclock otherwise it will skew the pan right or left depending on its position
thomasdupouy
PostPosted: Wed Mar 15, 2017 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
i use a LFO (modulation oscillator on a buchla music easel)
i test the pot and it's just increase/decrease the light on one LED, the other LED stay blinking all the time
thomasdupouy
PostPosted: Wed Mar 15, 2017 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i just test it with my COTK LFO and it work perfectly, i think my buchla send too much voltage, do you know wich value on the schematic i can change to use with my buchla ? thank you !
thomasdupouy
PostPosted: Wed Mar 15, 2017 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
ok my voltage is 0-10V and your design work +5/-5 V i need to offest the signal... Confused
any schem for this ?
diablojoy
PostPosted: Thu Mar 16, 2017 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm from MFOS a good source of info
http://musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=VCLFO200607/VCLFO200607.php&VPW=1270&VPH=570
look for DC level shifter under HOT TIPS
Gain will need to equal 1 - use the fixed gain - RIN= RFB so same value
adjust offset voltage to get what you need - simple
thomasdupouy
PostPosted: Thu Mar 16, 2017 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you so much !
