today> Cancelled this week, Sorry... Chez Mosc
Bringing the Vocoder to life
Page 6 of 7 [166 Posts]
zthee
PostPosted: Sun May 06, 2012 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
So I did the changes suggested by Sound. The things I had to change in the changes was the noise level. Cause even with the noise level trimmer turned down it was still 4x higher than the replacement signal. So I reverted back to the 18K / 100K setting, which brought it down to a better level..
I'm not sure how to adjust the voiced / unvoiced detector. There's only like 3 different settings to it - Either there is no action at all, there is just some action (I.e. Say "T" and there will be a burst of noise, but it sounds imho a bit strange..) or a 3rd where it's a mix of everything. I'm not sure which I like the best. But if I set it to the 3rd option and then adjust the tone control to fine tune it better..
Here's a short MP3 clip http://thehumancomparator.net/music/living%20vocoder%203.mp3
zthee
PostPosted: Sun May 06, 2012 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
http://thehumancomparator.net/music/living%20vocoder%204.mp3
Turning the V/U threshold trimmer. Starts at 0, then to max.
keithwin
PostPosted: Mon May 07, 2012 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Good work zthee and sound, just soldering my 1% caps in today, still got the trims and other box caps to order. Have used 25V electrolytics instead of 35V, this shouldn't make a difference, it's what I had in but the paranoia is creeping in Sad
zthee
PostPosted: Mon May 07, 2012 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
This project is only paranoia Smile
I checked all bands yesterday - turned out band 6, 8 and 17 were dead. Quick fix though, pin 8 of 4558 were bent (same op amp, same location, same pin, three different channels).
Here's another function test with all bands operational http://thehumancomparator.net/music/living%20vocoder%205.mp3
jwilsey
PostPosted: Mon May 28, 2012 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds amazing! Thanks for posting.
SolderSmoke
PostPosted: Fri Jun 08, 2012 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone did a suggestion for a frontpanel yet?
The patchpanels (Ghielmetti) seems hard to get. Anyone figured out a different solution, like analog matrix?
Luka
PostPosted: Fri Sep 07, 2012 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just acquired a pcb for this project
i just wanted to tip my hat to sound and zthee for paving the way through the troubleshooting. thanks for helping out
does anyone have a panel completed / case yet?
is there anyone in australia who wants to join in on capacitor buying
there is a price break at 250 which halves the cost of the caps
problemchild
melbourne australia
vtl5c3
PostPosted: Wed Oct 24, 2012 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone in the US ordered the 1% caps? I'm trying to order them from RS electronics' german site, but it looks like they only ship to germany. I went to the UK site and found the same caps for almost double the price, so that's out. And their US affiliate is Allied, who doesn't have those caps. Any recommendations?
Luka
PostPosted: Thu Oct 25, 2012 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
James from willzyx has a good deal on the caps
Im getting mine in the next few weeks
problemchild
melbourne australia
Luka
PostPosted: Sat Mar 02, 2013 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have the manual for ems 3000 and/or 5000 vocoders in english?
problemchild
melbourne australia
vtl5c3
PostPosted: Sat Mar 02, 2013 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I"m pretty sure this one is for the 5000:
https://sites.google.com/site/analogvocoderinfo/analog-vocoder/ems-manual
Luka
PostPosted: Sun Mar 03, 2013 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
bad producer gave me that link earlier today as well
it is all starting to make more sense - time to start a panel design
has anyone thought about having led bar displays for the envelope detectors similar to the buchla 296e?
if so, would you need a bar graph driver for each channel or could you do it an easier way?
problemchild
melbourne australia
The Bad Producer
PostPosted: Sun Mar 10, 2013 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't think of any other way of doing it - than bar graph drivers...
are you really thinking of doing that?
Shocked
If you did that would it probably be best to have that whole section powered from a different 'dirty' PSU...
The Bad Producer
PostPosted: Sun Mar 10, 2013 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I should add that my vocoder has been half finished for nearly a year whilst I've been moving in and out of different houses. I have a nice new workshop now, so have pulled it onto the desk again for finishing, can't remember where I got to though!
The Bad Producer
PostPosted: Sun Mar 10, 2013 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, I'm trying to get my head around the panel design for this as I near the end of soldering and beginning of testing. I thought I'd make a design for each part of the schematic to help me envisage how best to arrange everything, what to include etc..
Has anyone finished and got a panel done?
Be good to hear any thoughts on sections as I put them up over the next days...
I begin with the Speech Input Amplifier:
(posted this on muffs too)
StephenGiles
PostPosted: Tue Mar 12, 2013 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
The trick is notes, notes and more notes - I have often told myself when I've been in the same boat!
The Bad Producer
PostPosted: Tue Mar 12, 2013 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you're right - I've found all my notes too, but still feel a bit disorganised!
Did you finish yours?
Luka
PostPosted: Wed Mar 13, 2013 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
looks good
might be interesting to have a feedback input / aux input as well Smile
i have that on my fs1
problemchild
melbourne australia
emdot_ambient
PostPosted: Wed Mar 13, 2013 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
If you did that would it probably be the best thing in the world!
Fixed that for you. Wink
The Bad Producer
PostPosted: Wed Mar 13, 2013 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
True!
I've done a bit more today on this, and I'll amend that panel Luka - do you mean like a switch and pot to allow the output to be mixed back into the input?
Luka
PostPosted: Fri Mar 15, 2013 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
trying to draw a signal flow diagram
got most of it done except -
where does the voiced and unvoiced outs goto?
edit - wait im blind - of course they go to the mode sections in the compander module
problemchild
melbourne australia
Luka
PostPosted: Fri Mar 15, 2013 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
here is what i can gather from the schematics
let me know if anything is wrong / missing
<<removed>>
problemchild
melbourne australia
The Bad Producer
PostPosted: Sun Mar 17, 2013 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good to me, but I can't double check it at the mo from this computer, I have done something the same, but it's too shoddy to post! I'll look it up when back at home next week...
Luka
PostPosted: Mon Mar 18, 2013 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
removed the image above
the more i work on this the more errors i found Smile
one point of confusion at the moment is the pause bus
regarding the the filterbank pots / slider
is that marked as PB on the schematics?
and
does CW of the pot / slider join to both the PS bus AND channel analyzer output?
problemchild
melbourne australia
Luka
PostPosted: Fri Mar 22, 2013 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
bump for edit
and new question in previous post
problemchild
melbourne australia
