The site will be down for cutting over to a new server on Tuesday, May 26, at 10 PM EDT (2 AM GMT)
Direct Entry of Values via QWERTY
Page 1 of 1 [5 Posts]
cebec
G2 patch files: 31
PostPosted: Mon Apr 25, 2005 12:28 pm    Post subject: Direct Entry of Values via QWERTY Reply with quote  Mark this post and the followings unread
I'd like to be able to enter values directly into any gray value box from a QWERTY keyboard.
I'd also like to know why the OSCs are limited, by default, to 12.5 kHz at the upper range.
Rob
G2 patch files: 109
PostPosted: Mon Apr 25, 2005 1:39 pm    Post subject: Re: Direct Entry of Values via QWERTY Reply with quote  Mark this post and the followings unread
By connecting a Constant module to the top blue pitch input on an osc, and setting this module to a value of +12, the whole osc shifts up an octave and the range goes to 25kHz. Which btw is beyond my hearing capabilities. Wink
Audio files: 236
PostPosted: Mon Apr 25, 2005 5:06 pm    Post subject: Re: Direct Entry of Values via QWERTY Reply with quote  Mark this post and the followings unread
That's an unusual wish. Curious. Why would you want to control a G2 from a QWERTY keyboard?
Still, assuming there is a great reason, you could write some simple routines in Keykit to send out MIDI from the computer.
jamos
G2 patch files: 41
PostPosted: Mon Apr 25, 2005 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tis request makes perfect sense to me. If one wants an envelope attack time of 0.5 sec, it's easier to type 0.5 than to slide the little dial around.
Audio files: 236
PostPosted: Mon Apr 25, 2005 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed Of course. It does make sense... Embarassed
