linear VCO Schematic
Page 1 of 1 [9 Posts]
itist
PostPosted: Tue Dec 31, 2013 12:09 pm    Post subject: linear VCO Schematic Reply with quote  Mark this post and the followings unread
here are two schematics with an LTSpice Simulation.
It looks goad at the first sight and i will build them on Breadboard and will do some real life measurements.
The graphic shows a linear sweep with an control voltage from 125mV to 1V
Here you can follow the progress..
http://itist.de/2013/12/2-linear-voltage-controlled-oscillators-vco/
Greetz
Oliver
VCO1 Schematic
 Filesize:  12.35 KB
 Viewed:  350 Time(s)
VCO1 SAW output
 Filesize:  10.59 KB
 Viewed:  246 Time(s)
VCO2 Schematic
 Filesize:  10.23 KB
 Viewed:  317 Time(s)
VCO2 SAW output
 Filesize:  14.16 KB
 Viewed:  252 Time(s)
http://www.itist.de
https://plus.google.com/+ItistDe
http://www.youtube.com/user/DerITist
https://www.facebook.com/deriTist
itist
PostPosted: Wed Jan 01, 2014 3:33 pm    Post subject: Breadboard Reply with quote  Mark this post and the followings unread
This is a picture of the two VCOs on breadboard.
Test Results comming soon...
more infos at:
Greetz
Oliver
Both VCOs on breadboard.
 Filesize:  38.63 KB
 Viewed:  8444 Time(s)
Output VCO2
 Filesize:  83.2 KB
 Viewed:  247 Time(s)
Output VCO1
 Filesize:  72.46 KB
 Viewed:  232 Time(s)
http://www.itist.de
tasteless
PostPosted: Thu Jan 02, 2014 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooh , Nice work !
Definitely got My attention.
itist
PostPosted: Thu Jan 02, 2014 10:51 am    Post subject: VCO Designs Reply with quote  Mark this post and the followings unread
tasteless wrote:
Ooh , Nice work !
Thanks,
i found another linear VCO its from the Korg Trident. Will transfer it into LT Spice and build on Breadboard too.i'll try to make a collection of VCO Designs.
Happy 2014
Greetz
Oliver
http://www.itist.de
itist
PostPosted: Fri Jan 03, 2014 2:07 pm    Post subject: Build third VCO on Breadboard Reply with quote  Mark this post and the followings unread
i have built the third VCO (Korg Style) on breadboard.
The simulation did not work but real life circuit runs.
more infos at:
Greetz
Oliver
Waveform output breadboard
 Filesize:  80.24 KB
 Viewed:  236 Time(s)
http://www.itist.de
itist
PostPosted: Sat Jan 04, 2014 4:56 pm    Post subject: Audio Samples on youutbe Reply with quote  Mark this post and the followings unread
i uploaded a short video on youtube.
http://youtu.be/HtZ-OVa7F20
Greetz
Oliver
http://www.itist.de
acidblue
PostPosted: Thu Jan 30, 2014 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
What voltage are you using?
+12/-12, +15/-15 ?
itist
PostPosted: Thu Jan 30, 2014 11:36 pm    Post subject: Supply Voltage Reply with quote  Mark this post and the followings unread
i am using +15/-15V
Greetz
Oliver
http://www.itist.de
fantozzi
PostPosted: Wed Feb 05, 2014 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
For your collection
simulated, breadboarded
 Filesize:  78.17 KB
 Viewed:  288 Time(s)
 Filesize:  73.58 KB
 Viewed:  229 Time(s)
