Joined: Apr 03, 2004 Posts: 24419 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sun Feb 23, 2014 5:54 pm Post subject:
Wren latest version - 2025.4.10.0 Subject description: 2025.4.10.0 |
for downloads: https://bluehell.nl/wren/
for info: https://bluehell.nl/blogje/
As of version 2022.1.5.0 32 bit versions are no longer supported.
The changelog: https://bluehell.nl/blogje/
The help: https://bluehell.nl/wren/wiki/
Wren version 2022.3.28.0 or later makes use of an istaller - updates can be done from Wren itself.
Wren version 2025.4.10.0 or later also publishes a simple zip file again for manual installation. _________________ Jan
cebec
G2 patch files: 31
Posted: Tue Feb 25, 2014 6:22 am Post subject:
Very nice, thanks!
Are there near-term plans for alternate knob control modes (via the mouse), e.g., vertical and horizontal in addition to circular? _________________ http://www.soundcloud.com/cebec |
Audio files: 297
Posted: Tue Feb 25, 2014 12:47 pm Post subject:
Ok, I will consider that, it never occurred to me people actually use that
In fact I just added the modes which was half an hour of work or so, but will have to mess a bit to make it usable ... which is not trivial it seems ... and will have to check if the mode is always set over all knobs .. with adding modules & such. _________________ Jan
cebec
G2 patch files: 31
Audio files: 297
Posted: Tue Feb 25, 2014 4:37 pm Post subject:
It was not trivial indeed ... update posted to https://bluehell.nl/wren/
Not quite what I'd want, but workable I think.
edit : url update.
edit: another url update _________________ Jan
cebec
G2 patch files: 31
Audio files: 297
Posted: Sun Mar 09, 2014 3:19 pm Post subject:
New version 2014.3.9.0
Added a couple of modules mainly and a search function.
The new modules are : Rectifier, MinMax, Integrator/Differentiator, MIDI note receiver, MIDI CC receiver, MIDI note transmitter, MIDI CC transmitter.
The MIDI modules work with MIDI over TCP, and this needs support by an external program. I made my netMIDI server available from my site, but the format used should be compatible with the MidiTangle program too.
http://bluehell.electro-music.com/wren/forums.html has some more info on this.
edit : url update. _________________ Jan
Audio files: 297
Posted: Fri Mar 14, 2014 12:19 pm Post subject:
Bugfix - see first post in this topic. _________________ Jan
Audio files: 297
Posted: Fri Mar 28, 2014 3:17 pm Post subject:
Added stereo to wave players and there is a new 6x6 matrix mixer, chainable, and it has a control input for each knob.
Edit: there was an unintended dependency on my Led unit, providing the MIDI LEDs, I removed that one and made a new source code release. This does not really affect the program itself, some round LEDs are square now. _________________ Jan
Audio files: 297
Posted: Tue Apr 01, 2014 1:41 pm Post subject:
New version 2014.4.1.0 - see first post for all details. Fresh source code was posted for this as well.
The main new feature is the HrastOsc made by HrastProgrammer, this is an anti-aliased multi waveform oscillator. Thanks for that Hrast  _________________ Jan
BobTheDog
Posted: Tue Apr 08, 2014 3:10 pm Post subject:
Interesting stuff Jan.
Can XE5 build it for OSX? |
Audio files: 297
Posted: Tue Apr 08, 2014 4:59 pm Post subject:
Yes it can .. but not this source code unfortunately .. it needs a different component set for that and then my code uses a lot of winapi stuff too.
Oh and I could not test it ... it wants 10.6 minimal, I have 10.5.8. _________________ Jan
BobTheDog
Posted: Tue Apr 08, 2014 11:08 pm Post subject:
Ah, Ok.
I thought I was being optimistic  |
Audio files: 297
Posted: Tue Apr 29, 2014 1:47 pm Post subject:
New version uploaded .. quite some changes ...
Key items would be ... Hrast Filter added and old patches are incompatible, sorry for that, but had to do that to make the knobs work better.
Some modules got removed, but most became variations of new more general modules.
Hope I didn't introduce too many new bugs  _________________ Jan
Joined: Apr 24, 2009 Posts: 2494 Location: Bristol UK
Audio files: 495
Posted: Tue Apr 29, 2014 3:27 pm Post subject:
Looks like quite an overhaul... And I like the new look.
Now where did I put that spare time I set aside... _________________ Muied Lumens Sub Forum
Bandcamp |
hrastprogrammer
Audio files: 64
Audio files: 297
Posted: Wed Apr 30, 2014 11:04 am Post subject:
Thanks! _________________ Jan
Audio files: 297
Posted: Wed Apr 30, 2014 2:32 pm Post subject:
Some small bug fixes ... _________________ Jan
Audio files: 297
Posted: Mon May 05, 2014 5:04 pm Post subject:
And a couple more buggies killed in 2014.5.5.0 ...
Also made the sample rate and buffer size configurable ... the synth needs to be stopped to change those, but even then it may crash later on,
Best to quit wren after a change there and then start it again.
It does sound better at higher sample rates and its less glitchy with larger buffer sizes, but the latter will add latency, and the first reduces the possible patch size. _________________ Jan
Audio files: 297
cebec
G2 patch files: 31
Audio files: 297
Posted: Sat May 24, 2014 1:43 pm Post subject:
cebec wrote: | Good stuff and love the demo! |
Oh, hey, somehow I didnt see this .. thanks! _________________ Jan
Audio files: 297
Audio files: 297
Audio files: 297
Posted: Thu May 29, 2014 3:28 pm Post subject:
Some minor changes, see first post in topic. _________________ Jan
