Joined: Apr 03, 2004 Posts: 24604 Location: The Netherlands, Enschede
Audio files: 310
Posted: Sat Oct 05, 2013 5:00 pm Post subject:
Subject description: New Techno Trance Demo |
| THeff wrote: | [...]that's why the file is big [...] |
Don't worry about big, we're not running out of disk space soon.
Will listen later
Edit: Nice track! _________________ Jan
Joined: Apr 24, 2009 Posts: 2518 Location: Bristol UK
Audio files: 505
paulstone
Posted: Wed Nov 06, 2013 1:05 pm Post subject:
| fantastik DIY |
paulstone
THeff
Audio files: 33
Posted: Thu Nov 14, 2013 6:33 pm Post subject:
Thanks for the kind words Muied Lumens!
paulstone,
Nice looking PCB, glad it's working for you.
I will be posting the PCB and build info for the sub oscillator divider soon.
-Theff |
paulstone
Posted: Thu May 01, 2014 10:37 am Post subject:
| THeff wrote: | Thanks for the kind words Muied Lumens!
paulstone,
-Theff |
Hi Theff , no news ?
ciao |
THeff
Audio files: 33
Posted: Tue May 06, 2014 6:55 pm Post subject:
Hi paulstone,
I will try to post the info in the next couple of weeks. I have been out of town and super busy a work. There hasn't been much interest in the subosc divider so I have not been very motivated to post it.
-Theff |
skylab76
Posted: Sat May 10, 2014 11:05 pm Post subject:
Is there a single strip board version of the Poly Arp?  |
isak
Posted: Sun May 11, 2014 9:42 pm Post subject:
Hi THeff.
I finally manage to complit the vco build.
I must say...I love it!
The square sounds very very good, specially with a bit of PW.
As you said it was easy to tune.
I have one thing with the Tri, the top of the Tri is not spiky like it should be, the spike of the Tri is in the opposit way arround, and I actually can hear this, do you have Any idea why it happanes?
Again, I thank you for this amazing vco.
Isak E. _________________ http://www.myspace.com/mgmtrance |
paulstone
Posted: Sun May 11, 2014 11:43 pm Post subject:
| THeff wrote: | Hi paulstone,
-Theff |
hi THeff
no problem i have already made one , but thanks for your reply
ciao
P. |
THeff
Audio files: 33
Posted: Wed May 14, 2014 7:13 pm Post subject:
Hi paulstone,
I'm glad you got the osc divider working, it's a great little circuit.
Isak,
I'm not quite sure what you are seeing with the triangle output but, it sounds like it is folding back on itself. I have never seen this on any of the eight boards that I built so I'm not sure what would cause it.
I can only suggest that you double check the components in the triangle section and make sure there are no solder splashes shorting the PCB traces since they are pretty close together.
-THeff |
isak
Posted: Sun May 18, 2014 2:13 pm Post subject:
hi Theff.
thank you for your reply.
i'll do my best to find the problem and let you know.
isak E. _________________ http://www.myspace.com/mgmtrance |
isak
Posted: Tue Jun 10, 2014 6:35 am Post subject:
Hi THeff.
i didnt manage to fix the issue yet.
i thought maybe a pic of the tip tri wave shape will help?
this is what i see:
and the top it is not steady, it always moves.
any ideas?
cheers. _________________ http://www.myspace.com/mgmtrance |
Posted: Tue Jun 10, 2014 7:52 am Post subject:
| Is there any trim for the triangle? I've seen sort of similar things in other VCOs where the up ramp and down ramp sides of the triangle didn't meet correctly, normally there's a trim to line them up.... |
isak
Posted: Tue Jun 10, 2014 8:35 am Post subject:
Yes, there is a trim, but when I trim it to be centered the top of the Tri is going inside and it's hearible!
Have a look!
THeff
Audio files: 33
Posted: Sun Dec 27, 2015 6:41 pm Post subject:
New song Subject description: I made a new recoding today. |
Greetings all,
I haven't posted anything in a very long time so I thought I would drag out the PolyArp and see what I could do today. I found a MIDI file lurking on my computer with no name, just a number. It has a lot of cool arpeggios so I made a recording of it. All of the sounds are from the PolyArp, except the drums.
Since it didn't have a name, I called the song ArpAmbience. If you recognize it, please let me know.
Cheers and Happy New Year!
THeff
| Description: |
| Filesize: |
177.06 KB |
| Viewed: |
292 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
ArpAmbience192.mp3 |
| Filesize: |
7.08 MB |
| Downloaded: |
719 Time(s) |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Mon Dec 28, 2015 1:09 am Post subject:
| isak wrote: | Yes, there is a trim, but when I trim it to be centered the top of the Tri is going inside and it's hearible!
The Tri/Sine wave converter on the 2600 isn't perfect - it's not exactly a high end design. I have the same issue (a very slight overtone) on a perfectly cloned VCO/converter - I just accept it as part of the "character"  _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
isak
paulstone
Posted: Mon Dec 28, 2015 12:23 pm Post subject:
Hi guys
happy new year !
W arp clone thanks again to Theff for the vco and also Andy for the 4023 filter , love both !!
if you have others DIY pcb clone (any type) for the arp world , please posted here
ciao
Paolo |
stringsthings
Posted: Fri Jan 01, 2016 12:38 pm Post subject:
THeff,
this is some awesome synthy stuff !!
I was searching around for Bergfotron info and ran across this thread. Love the demos. And that synth is so impressive. I'm just getting into synth DIY ( pretty experienced in general electronic DIY ) and Im putting together a few VCO's and power supplies to get started.
Maybe someday in the future, I'll borrow one or more of your ideas here !  |
THeff
Audio files: 33
Posted: Sat Jan 02, 2016 6:00 pm Post subject:
Thanks stringsthings,
I wasn't sure how playable it was going to be due to the pitch drift of the four analog VCOs, but I am very pleased with the results. I made an attenuation patch cord so that I could plug a guitar tuner into the Sine output of each oscillator and that makes tuning fast and easy. I hope you build a cool synth in the near future.
Regards,
-THeff |
