flonky
Joined: Apr 03, 2004 Posts: 24511 Location: The Netherlands, Enschede
Posted: Wed Jun 25, 2014 8:47 am Post subject:
Re: 2 Osc stereo signal flow? Subject description: How to procede a patch with panning for each osc |
| flonky wrote: | | How do I procede to feed those two outputs into an envelope (or a filter in between), which has just one input? |
You need to use two, with all controls and inputs being the same .. or vary them a bit for liveliness ...
In the case of an envelope ... its possible to use one, but hen you need a multiplier module for the 2nd channel which is contolled by the ENV output of the envelope module (2nd from right at bottom).
Or turn the thing inside out, and use envelope and or filter before the pan module .. you still need two then of course, but its more clear when the two parts start to differ in their settings .. probably. _________________ Jan
flonky
Posted: Wed Jun 25, 2014 8:59 am Post subject:
This seems quite complicated and complex to use two filters, envelopes, etc. in order to be able to just pan two oscillators.
Panning two oscillators isn't such a big demand for a synth.
Strange... |
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Wed Jun 25, 2014 9:15 am Post subject:
Hi Florian,
My guess is that you want to scroll from 1 sound to the other.
Otherwise, what is the point to separate signals and let them come together in 1 device(module).
You can find the X-Mixer in the mixer map.
2 separate ins to 1 out. |
flonky
Posted: Wed Jun 25, 2014 9:22 am Post subject:
| In fact the idea is to spread to oscillators, slightly detune each one and then pan a bit to the left and a bit to the right... |
Roland Kuit
G2 patch files: 127
Posted: Wed Jun 25, 2014 11:23 am Post subject:
That is what I meant, yes, thank you  _________________ Jan
flonky
Posted: Wed Jun 25, 2014 11:36 am Post subject:
| Roland Kuit wrote: | | So you mean this? |
Thanks for your help!
It's getting close, I learned some new stuff but...
... how do I insert a filter (with its own envelope) that affects both channels L and R? |
r o l a n d k u i t
Joined: Jul 18, 2014 Posts: 58 Location: The Netherlands / Sweden
flonky
Posted: Fri Jul 18, 2014 2:18 am Post subject:
| flonky wrote: |
Does anybody have an idea? |
r o l a n d k u i t
flonky
Posted: Fri Jul 18, 2014 7:27 am Post subject:
Thanks for your time and patience! I'm currently learning...
From your patch I learned that for two panable oscillators I need two separate filters each with its own envelope, two separate LFOs with all their controls etc.
Now I wonder why it is so complicated and complex to build a synthesizer with the G2 with two oscillators each with its own panning?
In my eyes it's a quite usual and common synthesis concept to have two oscillators that you can detune and pan then both running into a filter etc. (e.g. Sylenth1, Virus TI, Twin2, Synthmaster, Omnisphere, Dune2)
A simple two oscillators subtractive synth is easy to build with the G2 but once you want to be able to pan the two oscillators it gets really confusing and complex and you have to build modules for each oscillator.
Weird... |
r o l a n d k u i t
Posted: Fri Jul 18, 2014 8:12 am Post subject:
It is as complicated as 'under the hood' of e.g. Sylenth1, Virus TI, Twin2, Synthmaster, Omnisphere, Dune2. Here, you only have to tweak knobs but a fixed structure is below. Altering the structure by knobs and switches.
Maybe you will find this a downsite.
The upside is, when understanding patch structures, you can make far more complex/interesting things than the synths mentioned above.
Your own things where your imagination (and DSP) is the limit. |
