today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
The GM Voice
Page 13 of 13 [305 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13
sompost
PostPosted: Thu Jan 08, 2015 2:50 am    Post subject: Comatose DB60XG clone (part II) Reply with quote  Mark this post and the followings unread
This is post 300 in this thread! Celebrayshun!!
Anyway, for the benefit of those zero to one people who care -- or may run into the same problem with their DB60XG/XR385 board -- here's what I've discovered.
On http://www.vogons.org/viewtopic.php?f=5&t=37241 I found somebody who appears to have the same problem (or, rather, I seem to have the same as he).
When I measure the voltage on pin 8 of the AK4510 on the silent board, I get about 1.4V. It should be either 0V or 5V. I also fail to get 2.5V at pin 1 which is what the AK4510 apparently is supposed to output there. The crackling board does have 2.5V on pin 1 of the AK4510.
Diagnosis: AK4510 on the silent board is kaput.
I also found that the crystal close to the XQ036A0 IC on the crackling board is torn off. I cannot tell whether I got it that way or if it happened later. I can't find the piece, so I'll have to order replacements.
I'll report on my findings if anyone cares to know. And more so if nobody does! Twisted Evil
Dan Lavin
Audio files: 21
PostPosted: Fri Jul 29, 2016 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
For anyone interested in building a GM Voice...maybe don't! Fluxamasynth has revision 3 which includes a midi in socket with an opto-isolator circuit. All you need to do is add a power supply. In addition, they've updated the synth to the SAM2695. Hard to beat for US$39.95 each.
https://moderndevice.com/product/fluxamasynth-shield/
Synth DIY since 1977!
PostPosted: Fri Jul 29, 2016 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks interesting. It's a bit cheaper than the Roland M-GS64, which also can handle 64 voices, has the MT-32 soundset (among other Sound Canvas variants). I looked at the documentation to see the midi implementation (for CCs and sysex), but couldn't find it. Any idea where I can find it? Thanks.
Steve
Addendum: OK; found it. It's in the SAM2695 datasheet--chapter 3, pp. 26-29, if anyone else is interested.* At a quick glance, it seems that the FX uses some standardized CCs, and other voice settings use NRPN and/or sysex. If the shield's library uses those, I didn't see them in the library code. However, if the SAM2695 if fully implemented, perhaps coders can add those in. (Just wondering.)
And it's only 64 voice if you don't use effects; 38 with effects.
*http://www.dream.fr/pdf/Serie2000/SAM_Datasheets/SAM2695.pdf
Dan Lavin
Audio files: 21
PostPosted: Thu Jan 19, 2017 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a guy that has a line of newer GM Voice compatible soundboards based on the SAM-series of ICs:
http://www.serdashop.com/S1DREAMBREAKOUT
Looks like the GM Voice will live on for a few more years yet!
DonPedro
PostPosted: Sun Feb 19, 2017 1:20 pm    Post subject:
Subject description: SW60XG as standalone MIDI Synthesizer
I wanted first to introduce myself. I am 48 now. I am working with PC's almost 30 years and from the very beginning was interested in computer music (sound cards). The very first application to convert digital signal to analog music was COVOX attached to LPT Wink. In late 90's I bought SW60XG as an addition to AWE64Gold. SW60XG as you might know is not daughter card - it is ISA card. I never trew it away nor sold, it waited in basement for more interesting time to handle with her. Lately I build a retro PC to set there SW1000XG which is very cool. But I still want to make use of those old SW60XG!
I saw on youtube video of making SW60XG standalone synth but... you all know the audio output of this card is horrible.
I would like to ask you for help in attaching to this card an optical/electrical SPDIF Out. Maybe it is not so hard to do?
Link to video:
https://youtu.be/k3DrNlqle1A
BTW: dream SAM2695 is already obsolete, new chip 5504EK has 81 v. polyphony and 24bit DAC + USB and 106dB S/N
...and I've read almost all the thread and gone to many links collecting some interesting docs and apps Wink[/url]
