today> Twyndyllyngs Chez Mosc
TTSH rev.2 Build Thread
Page 1 of 2 [48 Posts]
LED-man
PostPosted: Fri Jan 16, 2015 12:52 pm    Post subject: TTSH rev.2 Build Thread
Subject description: TTSH rev.2 Build Thread
due to Muffs Database Issues, here is the new Build thread rev.2
(backup here: http://electro-music.com/forum/post-407150.html#407150 and on my website)
General TTSH postings like Availability and more here:
http://www.muffwiggler.com/forum/topic-82997.html
TTSH Ver.2 (7.1 on pcb)
Released: 5.January 2015
Release Info:
Changes between first Version and rev.2:
- Powersection, two 1 inch voltage converter, embedded powerregulator like nordcores v1 addon pcb, 3x SMD inductors/chokes and more
- Amplifier : new design without cooling, other Amplifier Transistors and some other parts in this section
- LED Driver redesign
- multiples on pcb
- speaker holes
- switches: you get with the pcb kit few small pcbs with - this are used like a washer for the switches, in result switch mounting is easier as in TTSH rev.1 (pics on my website)
- some minor fixes
______________________________________
Schematic v2 (7.1):
http://thehumancomparator.net/wordpress/wp-content/uploads/2014/05/ttshv2schematics.pdf
________________________________________________
Jon /Zthees Buidling guide (26.Jan.2015 uncomplete)
http://build.thehumancomparator.net/
my own Building guide for Users with good experiences in DIY:
https://www.dsl-man.de/display/DSO/TTSH+rev2+Buidling+Guide
_________________________________________________________
Mainboard BOM
http://thehumancomparator.net/wordpress/wp-content/uploads/2015/01/ttshv2BOM.pdf
dont worry if you miss 2x 100K resisitors and 1x 1M , 1x 12K resistor, TL071 - thats only needed when you complete the TL071 section on frontpanel pcb side
1x 10K resistor left
VCO Sub pcbs BOM
http://thehumancomparator.net/wordpress/wp-content/uploads/2015/01/4027v2BOM.pdf
please add: 6x 100nF SMT c0g caps in size 805
mouser part 100nF 77-VJ0805Y104JXXPBC
10nF works fine too (its only a decoupling cap)
3x Timing cap 680pF needs a polypropylene, polystyrene or silva mica (7.5mm footprint)
mouser: 80-PHE450HK3680JR05
notice: the usage of 1k87 tempco 3300ppm instead of 3500ppm works fine too.
you can try the usage instead of SMT inductors/chokes this:
http://www.reichelt.de/index.html?ACTION=3;ARTICLE=86466;SEARCH=L-HBCC%20100
(add enough soldercore to the pcb pads, bent the leads and solder this to the pads)
DIFF from Version 1to version2
(first TTSH from early2014 to second from early 2015)
http://thehumancomparator.net/wordpress/wp-content/uploads/2014/05/v1-v2-diffferences.pdf
rare partkit: http://www.thonk.co.uk/?s=ttsh&submit.x=0&submit.y=0&post_type=product
full partkits, cases: http://www.synthcube.com/cart
____________________________________________________________
Studio/Roadcase Cases opt. Tolex : https://www.dsl-man.de/display/DSO/TTSH+Case
synthcube.com plans to offer cases too
_____________________________________________________________
known Issues and more:
1.
You dont need TTSHv1. Bugfixes in rev.2 to get a working TTSH
all known Issues are fixed in rev.2, except the Noise gain/distorted - for my usage its the default good ( https://www.dsl-man.de/display/DSO/TTSH+known+issues#TTSHknownissues-3fix )
2.
Measurement of DC Regulator output:
use for measurement the TP 15V to ground and TP -15V to ground (not TP1 or TP3 )
THATS very important to measure -15/+15V
otherwise you risk expensive damages or blown caps. (safe your eyes)
3.
if you plan to add the VCO Sync option, dont cut the legs from all VCO subboards too short (see VCO sync option here)
please pm me, if you want to add/correct here some Infos
Modifications (no bugfixes)
AR Envelope:
https://www.dsl-man.de/display/DSO/TTSH+Mod+AR+Envelope
VCO Sync:
https://www.dsl-man.de/display/DSO/TTSH+Mod+Sync+Option
Reverb Op-amp:
https://www.dsl-man.de/display/DSO/TTSH+Reverb+Driver+Mod
Gatebooster:
https://www.dsl-man.de/display/DSO/TTSH+Gatebooster
pcb groupbuy:
ultravox
PostPosted: Fri Jan 16, 2015 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks LED-man for keeping us updated! thumb up
(I'm ultravox from muffs)
LED-man
PostPosted: Fri Jan 16, 2015 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see you here.
In next week i get my pcbs and can share further pics.
Maybe at the end of next week i get a tolex case.
i have a woodworker and a tolex guy/company.
its not cheap. Around 350-450€ with invoice, depends on the case typ.
ultravox
PostPosted: Sat Jan 17, 2015 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
My Rev 2 kit is in route and I have all the components on hand including the 1" dc-dc converters. I'll also post updates and pictures when I start my build.
Altitude
PostPosted: Sat Jan 17, 2015 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Woot. Moving on up Smile I hope he can get that database sorted out since a loss like that is devistating. I need another DIY music forum about as much as I need a hole in my forehead but whatever Smile
Mine's en-route as well since I got in early. We will see how it compares with Rev 1.
Rigo
PostPosted: Sat Jan 17, 2015 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
There are a lot of usernames shared between Muffs and EM Wink
One of the next weeks everything will show up and I can start building ... Thank you LED-man !
PostPosted: Sat Jan 17, 2015 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last update from Mike was that a lot of stuff is just gone. Sad
Altitude
PostPosted: Sat Jan 17, 2015 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
lot of what stuff? save a couple of caps, everything was in the stock
PostPosted: Sat Jan 17, 2015 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I should have made my quote more clear, was responding to this:
Answer is, not likely to get any better than it is right now, and that's months of stuff just gone, a lot of it in the DIY forums.
Altitude
PostPosted: Sat Jan 17, 2015 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yikes. Not good.
sduck
PostPosted: Sat Jan 17, 2015 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, this is completely wrong. There is a complete backup of everything, including all the missing stuff. And he's working with a professional database guy specifically to see about restoring everything. I don't know any details beyond that. I could be wrong, and that big year long hole might not get fixed. I hope it does.
We'll see how splitting this thread off from the much more populated group works out. I understand the (somewhat knee jerk) reaction that prompted it, been seeing a lot of that. Personally I don't place any more faith in this sites longevity than I do anywhere else. But it certainly is less of a target, considering how few people use it.
Anyway, I'll keep an eye out here, help out if I can, post lots of questions If I can, etc.
PostPosted: Sat Jan 17, 2015 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that clarification; I was making my comment based on limited public statements by Mike, and was unaware of the backup or the involvement of a professional DB person. That's quite good news.
sduck
PostPosted: Sun Jan 18, 2015 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, there's a ton of conflicting info depending on what you read and when you read it. According to what has transpired just this evening, it may be restored fairly soon, although we'll see - that's what Mike was saying 3 days ago also.
LED-man
PostPosted: Sun Jan 18, 2015 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Mike have to invest yet a clustered database and other processes.
The forum database was destroyed due to wrong server configuration.
He wrote that he dont have 4.6gb db backup at beginning of his thread.
Electro music is a great forum too.
i post my ttsh and other projects on sequencer.de too since few years.
knowledge sharing can be used on many platforms to reach more users.
i hope the best for muffs and looking forward that he invest there money in modern Hardware/Software.
I miss the Standard SSL login as default too.
otherwise the risk of Session capturing and more.
sduck
PostPosted: Sun Jan 18, 2015 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is incorrect. I suspect you may have missed some ironic humor and sarcasm that was involved in that.
Doesn't matter, this is also a great place to have a secondary thread on this.
sonicwarrior
PostPosted: Sun Jan 18, 2015 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
In an international forum (foreign language = missing subtle stuff, wonder how many US people are speaking second languages as there seems to be barely any understanding for this) and with this serious matter one should be cautious with ironic humor/sarcasm.
Satindas
PostPosted: Mon Jan 19, 2015 10:45 am    Post subject:
Subject description: Did I miss something?
Did I miss something? There seems to be a few here stating "mines on route", but I've been checking the TTSH shop everyday since the supposed 1/1/15 opening date and I never saw anything other than "closed". I've got another builds worth of parts here (minus the changes in rev2) and really hoping they don't end up in the "may come in handy bin"!
PostPosted: Mon Jan 19, 2015 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
My understanding is that Jon, in order to avoid the shipping problems he had with rev 1, is packing and shipping everything himself. He is also only putting the number that are ready up on the website. So the small numbers ready at any given time disappear almost instantly as soon as someone notices they're available.
cycle is like this:
pack a few
put them up for sale
they sell out
lather, rinse, repeat
As frustrating as this model is for those who want it, I suspect he got a LOT of hassle over how it went last time, months between order and delivery, stop ships when things were damaged in various transit, etc. So it's kind of damned if you do, damned if you don't. He's opting for personal control....
sduck
PostPosted: Mon Jan 19, 2015 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know based on an email from Jon, they've only been on sale once so far, on the 5th. Perhaps someone who has better communication with him (LED-man?) can clarify this.
Satindas
PostPosted: Mon Jan 19, 2015 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
In light of the problems Jon encountered with Rev1, I fully understand his predicament if he indeed wishes to retain "personal control". Having said that, I'm slightly disgruntled by the fact that having followed the development of this project from its early days and having already had to wait way beyond the planned release date of the first batch, I now have to constantly check up on availability with no guarantee that I'm even gonna get a look in. I for one, would be happy to be on a waiting list and suck it up until payment is requested. It seems a bit unfair that some noob with a pack of 500 resistors and his grandads hot iron can get wind of this tomorrow and jump the queue just because he happened to get lucky. Am I being unreasonable?
LED-man
PostPosted: Mon Jan 19, 2015 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got few kits today.
Jon sells the kits in February too.
he check every panel by hand before shipping.
 Filesize:  631.15 KB
 Viewed:  402 Time(s)
trotz
PostPosted: Mon Jan 19, 2015 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been checking continuously...
I couldn't believe when I just read that some lucky guys have received ther v2s! :'(
I also would like to be on a list (I thought I was in one already) and then wait no matter for how long.
Checking the site every few hours can't be any good for nobody Wink
pedro trotz's website
sduck
PostPosted: Tue Jan 20, 2015 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
A few kits!?! No wonder no-one else can order them - you bought them all. Laughing
I hope someone can find out a solid date that they'll go back on sale. Wink
LED-man
PostPosted: Tue Jan 20, 2015 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
More than 50orders was shipped at the same time as i got my groupbuy panels/pcbs.
LED-man
PostPosted: Tue Jan 20, 2015 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Today i soldered for a friend the SMD parts.
The 100uH chokes was very hard to solder.
 Filesize:  201.26 KB
 Viewed:  464 Time(s)
