today> Twyndyllyngs Chez Mosc
Aristoteles Logic Synth
Page 1 of 1 [20 Posts]
Dogenigt
PostPosted: Sun Jul 13, 2014 9:07 pm    Post subject: Aristoteles Logic Synth
Subject description: Dögenigts modular lunetta (WIP)
Hail - cult of lunetta! Smile
Here I will be posting updates on my lunetta modular, which I chose to call Aristoteles, danish name for the ancient greek Aristotle who founded the logic statements as we know them today. The synth is also using CMOS logic to determine the states of the outputs.
It's all described on my blog www.dogenigt.com which I will be linking to. It contains all the documents from the building process, along with videos and schematics.
Schematics:
http://data.xn--dgenigt-q1a.dk/Elektronografi/Aristoteles%20Logic%20Synth/schematics/
The modules will be (in order from top left and down) the following:
- 8 x 40106 oscillators with PWM control and inputs to the freq pots, i.e. for vactrol (DONE)
- 4040-divider with 12-step rotary switch. (DONE)
- 4040-divider with 12-step rotary switch + output for each of the 12 stages.
- 4017-based 10-step counter with output for each step and reset input. (DONE)
- 8 logic gates: 6 x 4081 AND-gates, 1 x 4093 NAND-gate and 1 x 4070 XOR. (DONE)
- 4046 PLL "glissandi gen" module with HI and LO pots + outputs from some of the pins.
- CMOS "rungler" with 4021 shift reg and 4046 internal osc with external clock.
- 4049 "distortion" module with white noise acting as random clock gen.
- 4049 "distotrtion" module gaining external input to clock.
- 8 channel mixer with sallen-key filter and volume for each channel. (DONE)
- Main volume + mono output module. (DONE)
- Power module with starve pot and starve button. (DONE)
Update #5: Step Sequencer. - 27th of January, 2015
Dögenigt.com: 4017-based 10-step counter with output for each step and reset input.
Update #4: Logic Gates Module. - 15th of January, 2015
Dögenigt.com: 8 x AND-gate module.
Update #3: Divider module. (simple) - 4th of September, 2014
Dögenigt.com: 4040-divider with 12-step rotary switch.
Update #2: Oscillator module. - 12th of July, 2014
Dögenigt.com: 8 logic/square oscillators with PWM, range knob and momentary buttons.
Visit this post on my site with all the details, schemes, pics, vids etc.
Update #1: Mixer module. - 22th of May, 2014
Dögenigt.com: 8-channel mixer with sallen-key LP-filters + volume knob on each channel
www.dogenigt.com
Everything should be made as simple as possible, but no simpler. - Albert Einstein
commathe
PostPosted: Sun Jul 13, 2014 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! I've actually been planning on doing the exact same thing, inspired by the dlb electronics site. Make a site documenting a modular as I go along.
Unfortunately I don't seem to be able to connect to your site... I'm in China. Don't know if the host you are using is blocked here.
Tomoroh Hidari
PostPosted: Mon Jul 14, 2014 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
nice choice of name!
still busy learning and building smaller, standalone devices but surely planning to start a modular sometimes. so your blog is very helpful! thanks!
http://blog.ivorybunker.com/
http://tomoroh.ivorybunker.com/
http://tomorohhidari.bandcamp.com
Dogenigt
PostPosted: Mon Jul 14, 2014 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Weird... Confused Try http://dogenigt.blogspot.com/
Glad you could use it - I am updating the original post with the planned modules so you know what's coming up Cool
www.dogenigt.com
commathe
PostPosted: Mon Jul 14, 2014 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bingo! It's blogspot that is blocked here.
Dogenigt
PostPosted: Tue Jan 27, 2015 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Updated the top post with the latest additions, it's starting to look n sound beasty! Cool
www.dogenigt.com
SUGARAT
PostPosted: Wed Jan 28, 2015 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
looks sick. Cool idea using the 4049 as a random clock.
Dogenigt
PostPosted: Wed Jan 28, 2015 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's one of the coolest modules if you ask me. I can't wait to combine it with the AND-gates letting through the oscillators or clocking the 4017 with it.
Here's a recording of the noise/random clock driving a 4046 PLL:
https://soundcloud.com/dogenigt/liquidcircuit001
www.dogenigt.com
SUGARAT
PostPosted: Thu Jan 29, 2015 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great sounds. And those are all cool ideas. I bet you could use it as data in on a shift register and then use an osc to clock the "speed" of the noise.
A module with multiple random outs at both different and the same clock divisions would be super useful, I think.
synaesthesia
Audio files: 85
PostPosted: Thu Jan 29, 2015 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Lots of updates to your Logic Synth since I checked your site last time.
Yeah, (the 4049 random clock) that's one of the coolest modules if you ask me.
I think I found all updates, but missed the one describing the 4049 random clock. Can you share that one too?
Dogenigt
PostPosted: Thu Jan 29, 2015 10:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't finished this module on stripboard yet, only on testboard but I've done a schematic for it you can take a look at.
At the top of this topic, in the first post, you can see all the planned modules and the ones I've done has DONE written next to them Smile
Thanks for stopping by!
Dogenigt
 Filesize:  150.37 KB
 Viewed:  517 Time(s)
www.dogenigt.com
DUBmatze
PostPosted: Thu Jan 29, 2015 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice thing! i like it.
(... in your shematic you shorted all the outputs of the 4069 and 40106 to Ground ? )
Dogenigt
PostPosted: Thu Jan 29, 2015 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! Grounding the unused pins is done to prevent noise from floating in/outputs and can also reduce power consumation (so I was told) Wink
www.dogenigt.com
commathe
PostPosted: Fri Jan 30, 2015 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
You should ground inputs, but not outputs!
Dogenigt
PostPosted: Fri Jan 30, 2015 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! Makes sense with the schmitt trigger, if the input is pulled down or set to low. But in the case of the 4069/4049 I think I read somewhere that unused op amps should be shorted to be disabled... right? scratch
Nice to have it clarified - specially before I go to work with this circuit! Maybe I should post all my beta schemes to have your feedback.
www.dogenigt.com
PostPosted: Fri Jan 30, 2015 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Unused opamps are often configured as voltage followers and then grounded. But the 4069/4049 aren't opamps,
although the 4069UB can be (ab)used to behave like one. Shorting outputs is something you want to avoid with these chips,
which is also why you can't just connect outputs together. (with the exception of connecting gates parallel for a larger output current)
commathe
PostPosted: Fri Jan 30, 2015 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
You shouldn't ground an unused op-amp either! Shocked Generally you configure it as a voltage follower, but connect the output *only* to the inverting input. That way the op-amp neither sinks or sources any current. (well, almost none)
Also, PHOBoS is correct that using an inverter as an amplifier is just making it behave sort of like an op-amp. It's not an op-amp at all.
revtor
PostPosted: Sat Jan 31, 2015 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Dogeninght -you've got a great blog site there, awesome projects.
Keep up the good work!
~Steve
beep blurp flurrrp fiszzzzp pow bakka wakka wakka -A synth freaks mental notes.
droffset
PostPosted: Fri Mar 20, 2015 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
What a cool machine, well done.
Edit: Spelling mistakes.
Dogenigt
PostPosted: Wed Jun 03, 2015 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Schematics from my prototyping notes for all modules now available on my server:
www.dogenigt.com
