2 NM's / only 1 expansion
Page 1 of 1 [8 Posts]
crawling wind
PostPosted: Mon Jan 12, 2015 11:54 pm    Post subject: 2 NM's / only 1 expansion Reply with quote  Mark this post and the followings unread
Hello - it's been a while...I just hooked my NM1 kybd and recently acquired rack together for the first time! The expansion is currently in the rack. My thinking is that it would be best in the keyboard, but I'm curious what others have done in the same situation. Thanks! Greetz!
msy2
PostPosted: Mon Jan 19, 2015 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I've moved an expansion from the the rack to the keyboard before. Very easy. Just open them both up and it should be easy to see how to do it.
crawling wind
PostPosted: Mon Jan 19, 2015 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for replying - the question was more about if there is an advantage to having it in one or the other when using together as a pair. I will probably move it from the rack to the keyboard but I was just curious if anyone had an opinion.
cappy2112
PostPosted: Sun Feb 15, 2015 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you know that you can buy the expansion boards for the Nord Modular 1 from Encore Electronics?
They aren't cheap, but we all didn't jump into this hobby because it was cheap.
crawling wind
PostPosted: Wed Feb 18, 2015 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do know about that, but thank you for the reminder.
cappy2112
PostPosted: Wed Feb 18, 2015 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.encoreelectronics.com/cont_dsp0.html
Audio files: 279
PostPosted: Thu Feb 19, 2015 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
As the expansion just adds extra polyphony, it's probably more useful in the keyboard, assuming you'll be using it to play notes Smile
cappy2112
PostPosted: Thu Feb 19, 2015 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
If I'm not mistaken- doesn't it allow you to play more complex patches?
I seem to remember some patches not working on unexpanded NM1s
