Touch sensitive mini synth
Page 1 of 1 [14 Posts]
nicolas3141
PostPosted: Mon May 25, 2015 3:38 am    Post subject: Touch sensitive mini synth Reply with quote  Mark this post and the followings unread
In the same sort of vein as my bleepy machine of last year, this is a similar mini-synth, but this time touch controlled. With reasonably large touch plates made of something that is not too good a conductor you can get some measure of control. Stainless steel is ideal. Not quite play-a-tune control, but fun nevertheless. Springy touch plates allow LFO type effects by bouncing. VCO+VCF
Nicolas
nicolas3141
PostPosted: Mon May 25, 2015 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is the big brother with 2xVCO+VCF+VCA
Nicolas
PostPosted: Mon May 25, 2015 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like nice devices, and a good idea to have that output transformer.
Have you got any sound samples?
Edit .. oh wait .. I now re-realize I heard some .. hmm or did I .. I saw some ...
nicolas3141
PostPosted: Mon May 25, 2015 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
No sound samples yet for this one. Will see what I can do next week. The vco is a normal saw sound, the filter is a weakish bandpass which can sound a bit resonant if you treat it right. Not the best sounding filter out there, but I am challenging myself with what I can achieve with a single quad opamp chip and nothing else other than simple 2 legged stuff Smile
nicolas3141
PostPosted: Tue May 26, 2015 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a stripboard layout. Not verified yet as the prototype I have built is a bit messier. Offboard connections not shown, but should be easy to work out.
Nicolas
nicolas3141
PostPosted: Tue May 26, 2015 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
There were some errors in the BOM I posted earlier, so I have removed those and am uploading this corrected version. The filter needs to be on the edge of oscillating to sound interesting, but if it persists in oscillating all the time you will need to reduce R14. I found 600k to be just right on my prototype. Needs some experimentation so perhaps putting a trimpot in there would be a good idea.
Nicolas
nicolas3141
PostPosted: Tue May 26, 2015 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
corrected version. I have tweaked a few of the component values in the BOM. If you have trouble with the filter oscillating too much try a smaller value for R14. TP4 and TP5 are not very useful. TP1,2,3 are the main ones. They work well if big enough to contact your whole palm for the most effect or just a single knuckle for the most minimal effect with a reasonable range in between. If your touch plates are smaller you may want to try reducing C3 and increasing R16, but I really encourage you to try good big touch plates as they make it much more playable.
Nicolas
 Filesize:  107.4 KB
 Viewed:  377 Time(s)
dougseidel
PostPosted: Tue Jun 23, 2015 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! that is a really fun circuit! I made a dual version, which is fun to play.
L´Andratté
PostPosted: Tue Jun 23, 2015 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing, thanks!
Your circuits will be a fully featured modular synth soon.
And I keep being inspired by your design philosophy.
Would love to hear/see more of the resulting music...
PS: It seems, there are some photos missing in the first posts, or is it me missing something Razz
wackelpeter
Audio files: 10
PostPosted: Wed Jun 24, 2015 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="nicolas3141"]No sound samples yet for this one. Will see what I can do next week. The vco is a normal saw sound, the filter is a weakish bandpass which can sound a bit resonant if you treat it right. Not the best sounding filter out there, but I am challenging myself with what I can achieve with a single quad opamp chip and nothing else other than simple 2 legged stuff Smile[/Quote]
so no mice are included?
https://www.youtube.com/watch?v=F9nGyPz9uT0 Very Happy
animalman
PostPosted: Thu Jun 25, 2015 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like good fun. Sorry my ignorance, but is there a way to build this without the output transformer? And can someone tell what is the transformers function?
Hi-fi snake oil dudes often mention how warm audio sounds just running it through transformers Razz
Starspawn
PostPosted: Thu Jun 25, 2015 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, also if one wanted to use it as LFOs would increasing C3 work?
wackelpeter
Audio files: 10
PostPosted: Fri Jun 26, 2015 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-64453.html&highlight=
in the first post Nicolas mentions it's function...
nicolas3141
PostPosted: Sat Sep 26, 2015 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are building this as a separate unit with output to headphones then the transformer can be avoided. Or add a battery powered amp like an LM386 and include a speaker in the unit, to do this just use a cap between the LM324 and LM386 to avoid any DC bias.
The transformer is only necessary if you want to connect this up with other non-battery-powered gear such as effects/mixer/amp/PA/etc.
Nicolas
